Old 12-03-2012, 06:28 PM   #15
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by wparsons View Post
Will the fronts clear 17" wheels? Looks good!
I had 17s on my 2010 STi so I would think it'll work on the BRZ too. Just make sure your wheel spokes can clear Brembos.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 12-03-2012, 09:42 PM   #16
dorifuto
If in doubt,flat out
dorifuto's Avatar
Drives: 2013 brz
It may have been covered but what changed on the 08+ Sti calipers? Car looks awesome too, nice job.
dorifuto is offline   Reply With Quote
Old 12-03-2012, 09:48 PM   #17
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Car looks really solid, brakes fill up the wheels nicely and the drop is perfect!
Circuit Motorsports is offline   Reply With Quote
Old 12-03-2012, 10:28 PM   #18
Hanakuso
Did you get a chance to see the weight difference? I'm thinking of changing the rears
Hanakuso is offline   Reply With Quote
Old 12-03-2012, 10:47 PM   #19
OrbitalEllipses
Drives: Attitude
Internally? Probably nothing. That was the year the new chassis debuted, with the new multi-link rear and new rear knuckles. The change was presumably to accommodate the new structure in the rear (bolt spacing of the calipers changed while fastener size remained the same). 08+ STI brakes are actually still pretty expensive. You can fit 04+ STI fronts AND rears, but the rears from any GD chassis STI (2004-2007) will require a special adapter bracket that you can find from several vendors (Ken @ KNS Brakes being my favorite and possibly the designer of said bracket). GD STI brakes are cheaper. I actually have a full set leftover from a project I never got done on my WRX.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
dorifuto (12-03-2012), GTB/ZR-1 (12-03-2012)
Old 12-03-2012, 11:26 PM   #20
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Looks great!!
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 12-03-2012, 11:35 PM   #21
OrbitalEllipses
Drives: Attitude
You're adding weight over stock by going to the Brembo calipers/rotors. The calipers might be aluminum (still heavy and big) but god those discs are huge and heavy.
Last edited by OrbitalEllipses; 12-04-2012 at 03:28 PM. Reason: ROFL aluminum calipers whoops
Old 12-04-2012, 09:13 AM   #22
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
Do you have a DBA Part number for the rotors used or did you get them custom drilled for the 5 x 114.3???
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 12-04-2012, 10:21 AM   #23
nix
nix's Avatar
Drives: AVO BRZ
Looks really great man. I plan to follow suit shortly.
Can anyone more knowledgeable than me comment on the result that inverting the tapered pistons on these will have?
nix is offline   Reply With Quote
Old 12-04-2012, 10:44 AM   #24
1strwdcar
Drives: 2013 scion frs Whiteout
How much you have in the project
1strwdcar is offline   Reply With Quote
Old 12-04-2012, 11:56 AM   #25
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Your avatar needs to eat a cheeseburger but still
Old 12-04-2012, 12:24 PM   #26
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You're adding weight over stock by going to the Brembo calipers/rotors. The rotors might be aluminum (still heavy and big) but god those discs are huge and heavy.
Calipers are aluminum. I think someone posted the numbers and you are definitely adding some weight to the front and the rear with this setup. If you are worried about it, you can offset some of it by going with a more expensive aluminum hat rotor.
Old 12-04-2012, 12:26 PM   #27
King Tut
NASA SpecE30 Racer
King Tut's Avatar
If you swap bleeders, than the pistons are in the same orientation as they are on the STI so you should get nice even pad wear.
Old 12-04-2012, 12:27 PM   #28
King Tut
NASA SpecE30 Racer
King Tut's Avatar
As long as the DBA part number has a -10 at the end, then it is dual drilled for 5x100 and 5x114. Here is the part number for the rear rotors:
DBA 42656S-10
brakes, caliper, sti, swap
STI front brakes on BRZ (confirm) michael317 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 123 05-23-2016 01:41 PM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 06:20 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 11:08 AM
