#15 |
Drives: '13 BRZ Ltd WRB
I had 17s on my 2010 STi so I would think it'll work on the BRZ too. Just make sure your wheel spokes can clear Brembos.
#16 |
If in doubt,flat out
Drives: 2013 brz
It may have been covered but what changed on the 08+ Sti calipers? Car looks awesome too, nice job.
#17 |
Car looks really solid, brakes fill up the wheels nicely and the drop is perfect!
#18 |
Did you get a chance to see the weight difference? I'm thinking of changing the rears
#19 |
Drives: Attitude
Internally? Probably nothing. That was the year the new chassis debuted, with the new multi-link rear and new rear knuckles. The change was presumably to accommodate the new structure in the rear (bolt spacing of the calipers changed while fastener size remained the same). 08+ STI brakes are actually still pretty expensive. You can fit 04+ STI fronts AND rears, but the rears from any GD chassis STI (2004-2007) will require a special adapter bracket that you can find from several vendors (Ken @ KNS Brakes being my favorite and possibly the designer of said bracket). GD STI brakes are cheaper. I actually have a full set leftover from a project I never got done on my WRX.
#20 |
Track Junkie
Drives: Faster than the Stig!
Looks great!!
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
#21 |
Drives: Attitude
You're adding weight over stock by going to the Brembo calipers/rotors. The calipers might be aluminum (still heavy and big) but god those discs are huge and heavy.
Last edited by OrbitalEllipses; 12-04-2012 at 02:28 PM. Reason: ROFL aluminum calipers whoops |
#22 |
Australian and Proud !!!!
Drives: 2012 Toyota 86 GTS Aero Kit
Do you have a DBA Part number for the rotors used or did you get them custom drilled for the 5 x 114.3???
BONKRS for life
#23 |
Drives: AVO BRZ
Looks really great man. I plan to follow suit shortly.
Can anyone more knowledgeable than me comment on the result that inverting the tapered pistons on these will have?
#24 |
Drives: 2013 scion frs Whiteout
How much you have in the project
#25 |
Drives: Whiteout FR-S
#26 |
NASA SpecE30 Racer
Calipers are aluminum. I think someone posted the numbers and you are definitely adding some weight to the front and the rear with this setup. If you are worried about it, you can offset some of it by going with a more expensive aluminum hat rotor.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#27 |
NASA SpecE30 Racer
If you swap bleeders, than the pistons are in the same orientation as they are on the STI so you should get nice even pad wear.
- King Tut
#28 | |
NASA SpecE30 Racer
DBA 42656S-10
- King Tut
| Tags |
| brakes, caliper, sti, swap |
| STI front brakes on BRZ (confirm) | michael317 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 123 | 05-23-2016 12:41 PM |
| GTS Front Brakes + Rotors + Pads | GC GTS Aero Kit | Australia Classifieds | 2 | 11-16-2012 05:20 AM |
| R35 Brembo Brakes - Full set | 2013GTRNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-06-2012 10:08 AM |
