Old 11-20-2012, 08:57 PM   #15
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by wbradley View Post
I'm hoping a lot more people chime in here.
I pushed the squirrel finder down with my index finger. Easy!
Did you remove the headlight to do this or was it still on the car?
Old 11-21-2012, 12:25 PM   #16
wbradley
Sarcastic SOB
wbradley's Avatar
push your longest skinniest finger in the hole where you pulled out the bulb. On the inderside ofthe hole inside there is a light gauge metal plate that is horizontal (like a table) underneath. Bend it all the way down with your finger.
Or, take your front bumper apart and bake open your headlights and install HID projectors like some people tell me MUST be done.
Still waiting for more input on that topic here....
Old 11-21-2012, 12:28 PM   #17
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by d1ck View Post
The stock halogens are 55Watt, and are less efficient than HID's. (More wasted energy). Any normally available HID kit (35watt/50watt) will produce less heat and more light than a halogen.
The wiring is a non issue as well, as it's suitable for the 55watt stock bulbs, therefore the 35 or 50watt HID's would be using less power than the stock bulbs.
Hey there boy, looks like one of the very few Newfs on the forum. I am guessing you are in St John's.
Maybe you can drive the Targa Newfoundland route some time. Just not like the Bozo from Alberta who put a million $ Ferrari in the drink back in 2011.
Old 11-21-2012, 01:32 PM   #18
d1ck
Drives: Black 2013 FRS
I've participated for the last two years! I was navigating in 2011, and driving in 2012. The nearest track is in Nova Scotia which is lots of driving and an expensive ferry ride away, so I've got to take what I can get. Targa really is an amazing way to spend a week out of the year.
d1ck is offline   Reply With Quote
Old 11-21-2012, 04:09 PM   #19
finch1750
finch1750's Avatar
I plan on prjectors eventually and plan on blacking them out at the same time. But I won HIDs at the last meet so I figured I would just install and bend the squirrel finder as a temp thing. Seems like the frs projectors take them relatively good. Thanks for the info
Old 11-21-2012, 04:20 PM   #20
wbradley
Sarcastic SOB
wbradley's Avatar
You must get a bit of attention with that car. Couldn't be more that a few in the province at this point I'd bet.
No track in the whole province eh? We at least you got plenty of long roads!! Not worth leaving the province for sure.
Old 11-21-2012, 05:04 PM   #21
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I took apart my headlights and installed HID projectors.
Old 11-21-2012, 05:04 PM   #22
chuyjr85
Drives: Firestorm Red FR-S
Originally Posted by NemeGuero View Post
flatten squirrel finders at least
Whats the point of doing this? I installed an hid kit on my frs without any modification and it looks fine to me.
chuyjr85 is offline   Reply With Quote
Old 11-21-2012, 05:11 PM   #23
wbradley
Sarcastic SOB
wbradley's Avatar
It takes minimal effort and I am sure most people do care whether they are creating light pollution for other drivers.
If you shine your lights against the wall at night compared to mine, you will see mine throw almost zero light above the cutoff whereas yours have rectangular projections above the left and right side. This can be viewed as indirect but still harsh light off an HID bulb to oncoming traffic. Bending down the squirrel finder took 2 seconds and took away that projection.
The projector still might not be perfect for throwing 35W HID light, I don't know. That's why I am asking in this thread.
Old 11-21-2012, 06:40 PM   #24
acro
Drives: GT-86
y not show us the pic with your hid's against a wall?
acro is offline   Reply With Quote
Old 11-21-2012, 06:57 PM   #25
Celica00
Celica00's Avatar
Drives: 86
using the table as an analogy, do you bend it so that the table top would be leaning to front or rear of the car? and how many millimeters do you tilt? sorry if this is hard to understand
Celica00 is offline   Reply With Quote
Old 11-22-2012, 11:13 AM   #26
wbradley
Sarcastic SOB
wbradley's Avatar
When you stick an index finger in the hole you will feel the squirrel finder at the bottom. If you push it down with your finger tip it will bend down in the direction of the front of the car. Takes minimal effort and bend it as far as it will go.
Sorry I cant take a decent pic AFAIK as the car is garaged for the winter now and my garage is packed with junk against all the walls. I used the wall of a school nearby to check the cutoff and also parked the FR-S with the lights on and passed/approached/drove away from it with my other vehicle to see if I could catch some unacceptable harsh glare. I didn't find it "off the scale".
Old 11-22-2012, 03:02 PM   #27
mach330
Drives: Ultramarine frs
I can't feel this. How far in am i suppose to feel for that squirrel finder?
Tap'd from my G-Nex
mach330 is offline   Reply With Quote
Old 11-28-2012, 06:12 PM   #28
NemeGuero
See all that mess above your cutoff line? the squirrel finders bounce light upwards from the projector.. into the eyes of oncoming cars. Its okay when using halogen bulbs but not HID bulbs.
NemeGuero is offline   Reply With Quote
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 04:14 PM
Projectors DRL LEDs from Lisa@TrueStreetIndustries misterknee Cosmetic Modification (Interior/Exterior/Lighting) 0 11-19-2012 02:31 AM
FS: Ecutek Cable, stock axleback exhaust, stock springs Philly Canada Classifieds 4 11-02-2012 09:50 PM
Getting the most out of the stock FR-S Projectors. BlaineWasHere Cosmetic Modification (Interior/Exterior/Lighting) 16 07-09-2012 11:09 PM
[SYD] Swap my stock GTS 17" for your stock GT 16" wheels eckoflyte AUSTRALIA 11 06-18-2012 09:17 AM
