Old 11-20-2012, 11:12 AM   #1
wbradley
Sarcastic SOB
wbradley's Avatar
Stock projectors FR-S, suitability for HID??
Since this seems to be brought up regularly on various threads, I wanted to know from people that have tested HID's in their FR-S if they have found there to be unacceptable light dispersion or glare.
Those with tech qualifications that have looked at the cutoff etc please chime in.
Opinions welcome but really looking for technical specifics.
Hopefully we will get some decent input here and I will give my experience later in the thread.
The Following User Says Thank You to wbradley For This Useful Post:
TheGuyWithTheFireStorm (11-20-2012)
Old 11-20-2012, 11:15 AM   #2
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
I have them in mine. I think they have a pretty normal light spread pattern. Definitely not like a civic without projectors. There's some video on YouTube of someone with them showing how much glare there is. Look at that and decide if that's good for you or not.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
The Following User Says Thank You to Tim_Asphalt_FRS For This Useful Post:
Old 11-20-2012, 11:20 AM   #3
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
They are fine for me I have the kit from TheRetroFitSource and they are great.
The Following User Says Thank You to JoeBoxer For This Useful Post:
Old 11-20-2012, 12:57 PM   #4
NemeGuero
flatten squirrel finders at least
NemeGuero is offline   Reply With Quote
Old 11-20-2012, 01:02 PM   #5
wootwoot
Drives: FRS
You may want to consider heat as well. I have read one case of a guy damaging his housing because the HID's run hotter. This as well as glare should be your primary issues of concern when doing a conversion.
Old 11-20-2012, 01:26 PM   #6
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
False. 35 watts HID will run colder than halogens. More energy is converted into light it would be stupid to think it also creates more heat. 50 watts will run hotter though but do that at your own risks, especially if you don't upgrade the stock wiring.
As far as the stock projectors go, even without modification they are quite descent for HID, not as good as retrofit but they are good.
Rayme is offline   Reply With Quote
Old 11-20-2012, 01:46 PM   #7
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
How do I flatten the squirrel finders without baking the headlights?
VADER is offline   Reply With Quote
Old 11-20-2012, 01:46 PM   #8
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
Quick way to do this without baking?
Old 11-20-2012, 01:49 PM   #9
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Push with a flathead
86_ZN6 is offline   Reply With Quote
Old 11-20-2012, 01:53 PM   #10
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
So I blindly stick a flathead in there and push down? details plz haha sorry I'm a noob and don't want to break anything
Old 11-20-2012, 02:29 PM   #11
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
bump.. installing HIDs now and need answer to above question
Old 11-20-2012, 02:34 PM   #12
NemeGuero
you should be able to see them. But yes, just flatten the bent up plate of metal as best you can.
Old 11-20-2012, 04:48 PM   #13
wbradley
Sarcastic SOB
wbradley's Avatar
I'm hoping a lot more people chime in here.
I pushed the squirrel finder down with my index finger. Easy!
Old 11-20-2012, 06:49 PM   #14
d1ck
Drives: Black 2013 FRS
The stock halogens are 55Watt, and are less efficient than HID's. (More wasted energy). Any normally available HID kit (35watt/50watt) will produce less heat and more light than a halogen.
The wiring is a non issue as well, as it's suitable for the 55watt stock bulbs, therefore the 35 or 50watt HID's would be using less power than the stock bulbs.
d1ck is offline   Reply With Quote
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 03:14 PM
Projectors DRL LEDs from Lisa@TrueStreetIndustries misterknee Cosmetic Modification (Interior/Exterior/Lighting) 0 11-19-2012 01:31 AM
FS: Ecutek Cable, stock axleback exhaust, stock springs Philly Canada Classifieds 4 11-02-2012 08:50 PM
Getting the most out of the stock FR-S Projectors. BlaineWasHere Cosmetic Modification (Interior/Exterior/Lighting) 16 07-09-2012 10:09 PM
[SYD] Swap my stock GTS 17" for your stock GT 16" wheels eckoflyte AUSTRALIA 11 06-18-2012 08:17 AM
