Old 11-17-2012, 02:07 PM   #85
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
Nope tried the TSB fix today multiple times no luck. I suspect its an issue with the knockoff Chineese cable.
I had the same experience. No dice on trying to change the IDs in the ECU.
I used the cable and software to record my existing TPMS sensor IDs. I'm also planning to order an ATEQ Quickset. I'll go to the dealer now, and have them reprogrammed. Then in the spring I can use the QuickSet to switch between the two sets of IDs that I have.
What a pain in the ass this is. Why can't Toyota and Subaru implement TPMS ID change procedures that can be completed by a consumer?
NRGBalanced is offline   Reply With Quote
Old 11-17-2012, 02:16 PM   #86
Foobar
SLO NO MO
Foobar's Avatar
OK, no go for me either. I agree with neutron256, I think our Chinese Mongoose cables are missing whatever functionality Toyota requires to do a TPMS write.
I'll be ordering the ATEQ Quickset as well, but since I don't need to change out my tires until the spring, I'll wait until then.
Old 11-17-2012, 02:44 PM   #87
dsgerbc
Drives: BRZ(sold), STI
I'll try flashing something with Techstream + Tactrix2.0 on Monday. So far I only used it to verify stuff, and change a few settings, like opening both doors with one button press.
Old 11-17-2012, 03:18 PM   #88
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I'll be curious to see what you find. I've been able to get everything except programming TPMS. If you can get it to work I might invest in a Tactrix 2.0 cable.
Old 11-19-2012, 09:07 PM   #89
xcelir8brz
Drives: 2013 BRZ Limited
I received my cable and latest version of Techstream with the Scion codes (despite me having a BRZ Limited).
All I can say on how excited I am at all the options I tweaked as well as been able to monitor and test is... HOLY FUCKING SHIT THIS IS COOL! Well worth the $32 cable and latest Techstream I got off of EBay.
Wow.
xcelir8brz is offline   Reply With Quote
The Following User Says Thank You to xcelir8brz For This Useful Post:
developer (11-19-2012)
Old 11-19-2012, 09:19 PM   #90
White Shadow
Drives: 12,000 miles per year
Question for anyone who has the TIS Lite:
Can you bleed the master cylinder/ABS module with this software? Lots of Toyota cars and trucks need to be bled with the aid of a computer or Toyota scan tool if you happen to get air into the master cylinder and/or ABS module. A friend of mine has a Snap-On Modis scan tool that can do it, but it's like $8000. If TIS Lite can do it, I'm buying it for sure.
White Shadow is offline   Reply With Quote
Old 11-19-2012, 10:14 PM   #91
Future
Future's Avatar
Drives: BRZ!
Wow.
What can and can't you do?
Many will likely say the FR-S/BRZ needs more power and while more wouldn’t hurt, those folks (the same ones who have probably never driven on a track) are missing the point.
Future is offline   Reply With Quote
Old 11-22-2012, 01:09 PM   #92
celica73
Got my cable and loaded the software onto my daughter's netbook (the only XP computer we have). So far so good.
The instructions say to select "Europe." Anyone confirm if this is needed? I tried North America and had no issues with the BRZ. It loaded up as a FRS and I could see everything, no issues. Did a little logging of oil temperature.
However, with my '06 Tundra I had all kinds of crashes and issues. When I switched to "Europe" it seemed to work a lot better and 6 years later, I can finally unlock all the doors with a single press on the remote.
So, "Europe" or "North America."?
Next up will be a longer drive with some data logging on the BRZ.
Old 11-23-2012, 12:33 AM   #93
ft_sjo
Drives: GT86
Does this engine actually have an oil temperature sensor, or is it just a mapped value?
Old 11-23-2012, 08:41 AM   #94
celica73
It has a sensor (right below the oil filter). I was surprised too.
Does anyone know what the Subaru equivalent to Techstream is? I've got an Outback that has some things that need reprogramming.
Old 11-23-2012, 01:27 PM   #95
xcelir8brz
It is NOT the Lite version. I can do everything I want to accept TPMS (from what I gather so far).
Old 11-23-2012, 01:29 PM   #96
xcelir8brz
In good with the dealer. There is no equivalent. What they have doesn't even work with the BRZ (tried it three different visits). Talked to the mechanics. They actually had to order Techstream for this car.
Old 11-23-2012, 01:29 PM   #97
xcelir8brz
North America for BRZ.
Old 11-26-2012, 08:48 PM   #98
TemeCal
Drives: 86
Anyone have any luck with the TPMS IDs? It doesn't sound like it, from the several that tried it. Just hoping I don't need to take it to the dealer...
Thanks!
TemeCal is offline   Reply With Quote
Production Toyota FT-86 Details and Design Previewed by Toyota Sports Vehicle Boss ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 541 11-18-2011 09:04 PM
Toyota FT-86 G's Sport Concept moved to Toyota Mega Web showroom at Odaiba Kenji FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 23 05-02-2011 01:11 AM
Toyota FT-86 G-Sport Concept car displayed with AE86 at Toyota Amlux, Tokyo Kenji FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 03-08-2010 11:09 PM
Report: Toyota chooses alternative Toyota FT-86 design (by Calty studio)! Nemesis Scion FR-S / Toyota 86 GT86 General Forum 128 02-19-2010 11:36 AM
