Old 10-27-2012, 01:46 PM   #15
steeloyangster
steeloyangster's Avatar
Drives: 14' FRS 6MT; 16' WRX 6MT
It's flat so it's got a lower CoG, the pistons are opposed to each other so there's less material on the crank to balance engine vibration making the overall engine weight lighter and spins more freely because of less weight/material to move. Other than that I don't think there are many other benefits of a boxer. Versus an inline 4 I think there's a negative in that there are more moving parts such as the need for 4 CAMS vs just 2 if it were a DOHC configuration. There are always advantages vs disadvantages on motor designs. I used to be a big fan of the WANKEL because of it's only 3 major moving parts but the lack of torque, dependability, life expectancy, and gas mileage made me get rid of my second gen RX7.
steeloyangster is offline   Reply With Quote
The Following User Says Thank You to steeloyangster For This Useful Post:
ZakD (10-27-2012)
Old 10-27-2012, 02:11 PM   #16
Dimman
Kuruma Otaku
Dimman's Avatar
Problem is they're wide and can't be pushed back as far for balance when front mounted and interfere with more advanced suspension options in the front because of it.
Because titanium.
The Following User Says Thank You to Dimman For This Useful Post:
Giccin (10-29-2012)
Old 10-27-2012, 02:37 PM   #17
ZakD
ZakD's Avatar
Drives: Toyota Yaris 1.3
Is the WANKEL what is referred to as rotary engine? Those seem to really be out of the scene.
Sent from my MB525 using Tapatalk 2
ZakD is offline   Reply With Quote
Old 10-27-2012, 02:50 PM   #18
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Yes, they are the same.
whaap is offline   Reply With Quote
Old 10-27-2012, 02:55 PM   #19
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
The pistons are held together with a unicorn horn. Duh.
Beyer Subaru is offline   Reply With Quote
The Following 5 Users Say Thank You to Beyer Subaru For This Useful Post:
Craig (10-28-2012), Guff (10-27-2012), pyro530 (10-27-2012), Snoopyalien24 (10-27-2012), st162celica (10-28-2012)
Old 10-27-2012, 03:03 PM   #20
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
It allows the shifter to be mounted right on the tranny instead of using cables
Rayme is offline   Reply With Quote
Old 10-27-2012, 03:17 PM   #21
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
The FA20 are special for throwing out the famous idle dip and CEL light from factory.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following User Says Thank You to DaJo For This Useful Post:
Tomzilla (10-29-2012)
Old 10-27-2012, 03:23 PM   #22
fatoni
Originally Posted by SuperDave View Post
says the guy who drives an inline engine.
and that car with an inline engine has a lower cog than the frs.
that has nothing to do with it being a boxer motor as far as i know. im pretty sure thats a function of the engine being up front and the drive wheels out back
The Following User Says Thank You to fatoni For This Useful Post:
Allch Chcar (10-29-2012)
Old 10-27-2012, 04:13 PM   #23
Carban
Grease Monkey
Carban's Avatar
Drives: Whiteout FR-S
LFA, Porsche 911 GT3, and Ferrari 360 are the only cars built w/ a lower CoG than the FRS. I like miatas, Yours may be modified lower, but who cares that wasnt the question.
...oh ur so wrong
Boxer engine: flat design so its mounted lower, minimal vibrations, the square 86x86 bore and stroke provide wonderful balance throughout the engine and also reduces vibration, not to mention subaru has mastered the horizontally opposed.
"Using the boxer engine also allows it and other major components to be moved farther back toward the vehicle’s center point, resulting in an extremely neutral-handling chassis that laughs at the thought of understeer."
BADABING BADABOOM
R.I.P. '92 Honda Prelude you will be missed
Carban is offline   Reply With Quote
Old 10-27-2012, 04:59 PM   #24
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
Having owned one of the lowest stock Miata's ever produced, I think I am certified to add my two cents here.
If I recall correctly all miatas have a CoG height higher than even an s2000. I cant find the exact numbers right now, my google-fu is weak. The s2000 is higher still than a Porsche Cayman, and the FT86 cars are supposedly lower than all of the models mentioned above.
Now, obviously CoG height is not a 100% indication of overall performance, but I can safely say the FRS out-performs any miata I have ever owned -stock-.
EDIT: found some data finally
460mm for the FS is roughly 18.1in, whereas the Cayman is 482mm. Im having problems finding credible sources for s2k and mx5 though. Conjecture seems to indicate 20-22'' for the S2k which I have a hard time believing.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
The Following 2 Users Say Thank You to mattles For This Useful Post:
einzlr (10-27-2012), ZakD (10-27-2012)
Old 10-27-2012, 05:05 PM   #25
Dimman
Kuruma Otaku
Dimman's Avatar
...oh ur so wrong
BADABING BADABOOM
Then why does it only have the same F:R balance as an iron-block, long inline-6 powered Supra?
Marketing hyperbole. Try again.
Edit: According to Keith Tanner (look him up), first gen Miatas' cogs was ~17" stock.
Because titanium.
The Following 2 Users Say Thank You to Dimman For This Useful Post:
fatoni (10-27-2012), Guff (10-27-2012)
Old 10-27-2012, 05:46 PM   #26
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
The fact that it's a boxer has no real correspondence with how it has a directly mounted shifter. Like fatoni said, that's because it's FR.
Honestly, what like about boxers is just the ridiculous noise they make. And fact that nobody knows what the hell they are.
It's unique. Not as unique as wankel-magic-pixie-unicorn-triangle engines, but unique nonetheless.
- The Ancient BRZ Sacrament
by Zaku
The Following User Says Thank You to Guff For This Useful Post:
SpeedR (10-28-2012)
Old 10-27-2012, 05:57 PM   #27
Palmy
Palmy's Avatar
Drives: '12 86 GTS (AUDM)
If by "unique" you meant "mass produced" then yeah.
Are boxer engines rare in the US?
Palmy is offline   Reply With Quote
Old 10-27-2012, 06:10 PM   #28
Guff
Guff's Avatar
Drives: BRZ LZR
Meaning they are not as common as inline or V-type engines.
Perhaps uncommon is a better word. Although as an FR Boxer, I suppose it is quite unique.
by Zaku
What happens on a Boxer engine when there's too much Oil? @Art_Mighty Engine, Exhaust, Transmission 29 06-15-2014 04:36 PM
What makes Weds AMF Series so special? vividracing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-21-2012 05:47 PM
total noob with boxer engine NickDude84 Engine, Exhaust, Transmission 35 04-27-2012 08:51 PM
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 12:04 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 10:55 PM
