Old 10-27-2012, 11:51 AM   #1
ZakD
ZakD's Avatar
Drives: Toyota Yaris 1.3
What makes the Boxer engine so special
Hi guys.
You can post your thoughts on the boxer engine here.
Posted an elementary explanation of the boxer engine on our blog. Let me know your thoughts. Thanks
http://www.durbansouthtoyota.co.za/b...-boxer-engine/
Sent from my MB525 using Tapatalk 2
ZakD is offline   Reply With Quote
Old 10-27-2012, 11:55 AM   #2
fatoni
nothing really. as far as i can tell its a pretty normal engine. there may be some subtle advantages but from an overall perspective its not important enough to be a deciding factor
Old 10-27-2012, 11:56 AM   #3
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Low profile allows for a much lower COG than most engines.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 10-27-2012, 12:07 PM   #4
wbradley
Sarcastic SOB
wbradley's Avatar
its a flat engine
Old 10-27-2012, 12:15 PM   #5
mkiisupra
mkiisupra's Avatar
Drives: 83 Toyota Supra, 16 FR-S RS2.0
IIRC, the flat or horizontally-opposed design may deliver more torque for a similarly displaced inline or v cylinder design. Perhaps due to where the power is delivered from the piston/cylinders relative to the rotational cycle of the crankshaft.
mkiisupra is offline   Reply With Quote
Old 10-27-2012, 12:20 PM   #6
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Packaging. You can mount one longitudinally in the space of a transverse 4.
The lower CG is a benefit as well, which is why you see them a lot in motorcycles.
Old 10-27-2012, 12:28 PM   #7
FRiSson
Drives: FR-S MT
what about a 4-cylinder radial engine?
FRiSson is offline   Reply With Quote
Old 10-27-2012, 12:32 PM   #8
Celicadude
Drives: Celica gts
Also less vibrations since horizontally opposed pistons cancel the vibrations out, or so subaru says. Blah Blah Blah sciencey stuff Boxer Hooray!!!!!
Celicadude is offline   Reply With Quote
Old 10-27-2012, 12:34 PM   #9
White Shadow
Drives: 12,000 miles per year
This ^^^^
That's definitely the biggest advantage.
White Shadow is offline   Reply With Quote
Old 10-27-2012, 12:44 PM   #10
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
As far as power goes for NA it is not as powerful as a Honda VTEC K series engine, but as far as we all can see the Boxer engine does seem to make/hold more power when going forced induction with just stock internals.
LeeMaster is offline   Reply With Quote
Old 10-27-2012, 12:49 PM   #11
fatoni
Originally Posted by White Shadow View Post
This ^^^^
usually what happens is that the engine is so wide that it ends up being placed higher in the car negating any cog advantage you would gain otherwise.
Old 10-27-2012, 12:54 PM   #12
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
Yep. Pretty much this is all
RedRocket is offline   Reply With Quote
Old 10-27-2012, 12:57 PM   #13
RedRocket
RedRocket's Avatar
Only it doesn't. Have you looked under the hood? It's low
Old 10-27-2012, 01:14 PM   #14
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
says the guy who drives an inline engine.
SuperDave is offline   Reply With Quote
What happens on a Boxer engine when there's too much Oil? @Art_Mighty Engine, Exhaust, Transmission 29 06-15-2014 04:36 PM
What makes Weds AMF Series so special? vividracing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-21-2012 05:47 PM
total noob with boxer engine NickDude84 Engine, Exhaust, Transmission 35 04-27-2012 08:51 PM
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 12:04 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 10:55 PM
