Old 12-04-2011, 02:20 PM   #1
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Next Gen Boxer Engine 4U-GSE
U
The 0.7 L (697 cc) Aircooled Flat-Twin U Producing 28hp was produced from 1961 through 1966, and was found in the Toyota Publica
2U
The 0.8 L (790 cc) Flat-Twin 2U twin Carb 45hp, was produced from 1965 through 1969. and was found in the Toyota Sport 800, also known as Yota-Hachi (Toyota8).
2U-B
Same as the 790cc 2U, produced from 1966 through 1976, the output for the B was bumped up 49 hp (37 kW) at 5400 RPM.
4U-GSE
Appearing in the Toyota 86 (also known as the Toyota GT86 in Europe, Scion FRS in the USA and Subaru BRZ), the 4U-GSE is a boxer type engine with 4 cylinders and a bore and stroke of 86mmx86mm. It features direct and port injection systems D4-S, with a maximum power rating of 200HP (147kW) at 7,000RPM and a maximum torque rating of 151 lb.-ft (205 N-m) at 6,600RPM.
Potential Models
4U-GZSE
A potential future candidate to a high performance model 4U, featuring a TRD supercharger to bump up Torque which lacks some in the GSE.
I made this up from Wiki information, but does Subaru Feel and respond to this? The engine was built by FHI Subaru however it takes a Toyota Engine code, Rather Subaru engine code which we have been using previously as FA20.
WingsofWar is offline   Reply With Quote
Old 12-04-2011, 03:04 PM   #2
old greg
Rocket Surgeon
Drives: PSM GGA OMG
I think that along with the nameplate neutral 'AS1' designation, we should refer to the engine as the F-U.
It is reasonably common practice for a co-developed engine to be referred to by different designations by the companies involved. Nissan and Renault for instance do this quite a lot.
old greg is offline   Reply With Quote
Old 12-04-2011, 03:21 PM   #3
Dimman
Kuruma Otaku
Dimman's Avatar
Should be 4U-GZSE or GSZE for the Supercharged model...
Because titanium.
Old 12-04-2011, 03:39 PM   #4
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
it should be but its not..the 2GR-FSE is also D4S Supercharged in some cars.
FE is the current TRD supercharged Designation
SE is the D4S Designation
They havent use Z for quite some time
Old 12-04-2011, 03:45 PM   #5
Dimman
Kuruma Otaku
Dimman's Avatar
Tradition-wise, G is performance, F is fuel economy, Z is supercharged, T is turbocharged, S is direct injection, E is electronic injection.
2GRFE under your nomenclature would imply that the V6 Camry is supercharged...
Edit: the lack of the Z designation has to do with a lot of the supercharged Toyota motors have been post-factory, TRD install on a standard FE motor for example. Motor was not designed with supercharging in mind.
Because titanium.
Old 12-04-2011, 03:50 PM   #6
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
ahhh your right! thanks for the correction
Old 12-04-2011, 04:58 PM   #7
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Are you trying to apply Toyota engine designations to a Subaru motor?
Kostamojen is offline   Reply With Quote
Old 12-04-2011, 05:41 PM   #8
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
No that is the engine code. At least per Toyota. Not sure if Subaru will keep FA20 (would assume so).
Video here:
[U2b]WNF9GcZfueE[/U2b]
tranzformer is offline   Reply With Quote
Old 12-04-2011, 05:56 PM   #9
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
Oh this is for the people that are still in denial that this car is a Subaru?
It would be more efficient to say FA20
quik1987 is offline   Reply With Quote
Old 12-04-2011, 06:11 PM   #10
coyote
coyote's Avatar
Drives: Slowly
coyote is offline   Reply With Quote
Old 12-04-2011, 07:03 PM   #11
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
for me id prefer to say FA20
Old 12-04-2011, 07:05 PM   #12
tranzformer
Drives: Zoom Zoom
That is what I will be saying.
Old 12-04-2011, 07:22 PM   #13
coyote
coyote's Avatar
Drives: Slowly
I'll be calling it the item for sale on eBay.
Old 12-04-2011, 08:33 PM   #14
Kostamojen
Maybe this is the Yamaha engine code?
Photos of Subaru Boxer 1.6L Direct Injection Turbo DIT Engine from 2011 TMS Hachiroku BRZ First-Gen (2012+) — General Topics 21 12-01-2011 07:52 AM
Porche boxer vs Subaru boxer Shevon Engine, Exhaust, Transmission 22 08-10-2011 12:43 PM
Toyota Reconfirms Production 2012 FR-S / FT-86 Boxer Engine, 6MT, 6AT, LSD Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 30 05-02-2011 03:30 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 10:55 PM
More proof of FT-86 Boxer engine appears in logo Hachiroku Engine, Exhaust, Transmission 33 01-03-2011 01:47 AM
