Old 10-19-2012, 01:23 PM   #43
low trq
Drives: 2013 Honda Fit sport
Originally Posted by 2point0 View Post
I can see what you mean, but the quality will just depend on the shop and the price, most likely. As for re-sale, keep the stock parts and sell your aftermarket stuff. You'll likely get more back that way.
And really, why would you sell this car?!?
either the car or the exhaust will be gone in 5 years. I get bored quick.
low trq is offline   Reply With Quote
Old 10-19-2012, 02:01 PM   #44
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Originally Posted by low trq View Post
You spent $400? Why not just buy an axle back thats built for your car and it will have re-sale value when you decide to get rid of it?
It will only cost $150 more for a Nameless catback.
It's a full catback. 2.5" tubing all the way to the cat.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 10-19-2012, 02:02 PM   #45
low trq
ooooh, thats a pretty good deal then.
Congrats
Old 10-19-2012, 02:31 PM   #46
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
LOL it's amazing no one suggested, just replace the tip. It's not like OP is looking for any gain of hp or tq. Just looking for cosmetic stuff. Exhaust tips will be much cheaper rout imo
He wants a different exhaust sound as well
Sent from my Dell Streak 7 using Tapatalk 2
MattF is offline   Reply With Quote
Old 10-19-2012, 02:39 PM   #47
gmookher
is a joe s muffler shop system for me?
cheaper, yup, sure, building something to fit is pretty basic, most monkeys with a pile of tubing and a blowtorch can accomplish this for a few dollars quickly. doesnt make it an exhaust 'system' tho
you do get what you pay for. this int just a sound device, its part of your power equation. theres more to it than slapping it together, really.
Good question is whats the difference between my local shop grabbing some school bus tubing, tossing it on a reamer/bender, and strapping on a generic can, and a true tuner built system? No not one made by borla or magnaflow.
Most muffler shops arent using mandrel bent tubing. Most havent tested flow rates on bends, piping or volumes, when they grab a tube and craft it ad hoc-theres everything wrong with it, its Way different in the way power is gained using an exhaust than where power can actually be lost or unaffected, and all you pay for is more sound. No attention is paid to tuning out resonant frequencies of the tubing. No attention is given to flow,pulses, waves or their reflections.
There are several stainless alloys which are commonly used in exhaust systems. In order of reducing temperature capabilities, they are 347, 321, 316 and 304. In addition, special variations in the basic alloy chemistry (carbon, nickel, titanium and niobium) are available to enhance the high temperature strength of these alloys. Not sure what the muffler shop is using likely not stainless. Again, for going to the mall, hey, whatever floats your boat. But if you want to make power, its not that easy to do it right.
There are two separate components to the exhaust event that require more tuning than can be done by said shop welder standing under your car with a tube and a torch.
The first is the removal of exhaust gasses from the cylinder, which occurs as a pulse of hot gas exiting the cylinder and flowing down the header primary tube.
The second is the (much faster) travel of the pressure wave in the port caused by the pressure spike which occurs when the exhaust valve opens, and the various reflections of that wave.
Taking proper advantage of these pressure waves (component two) can produce dramatic improvements in clearing the cylinder (component one) and can strongly assist the inflow of fresh charge.
The 'made to fit' pipes lenght or an angle a few inches this way or that way CAN affect things. The way a cut end of pipe protrudes into the path of airflow does matter to some people. The lack of proper pulse is easy screw up. It costs power and economy.
A tuned, well fabbed, flowing tested setup may cost a little more, but the gains are real and can be more functional with other mods when they are matched up nicely.
I mean you can do what you want its your car
The Following User Says Thank You to gmookher For This Useful Post:
low trq (10-19-2012)
Old 10-19-2012, 07:38 PM   #48
ESC POD
ESC POD's Avatar
Drives: Sterling Silver BRZ
Originally Posted by bcmakesiteasy View Post
the axelback from nameless is 550, and I was thinking of getting the invidia catback for around the same price. The thing is, I was considering just the muffler only because it would cost around 200 bucks and that way I can save a few hundred for some cosmetic mods.
Go with the Nameless...you will not be disappointed. I mean no disrespect, but 'just a muffler' on this car...is just a little too hokey. Again, no disrespect...just an opinion. Nameless, for the price- You will be exceptionally pleased when you get it in the mail...Built in the USA too!!
Activating: ESC POD...let's Drive!!
ESC POD is offline   Reply With Quote
Old 10-19-2012, 08:30 PM   #49
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
opinions on getting JUST a muffler
Am totally agree with you! When company create an exhaust system they perform research and tests for it.
Your choice It's depending what you want to do with your car :p
o= FR-S =o
Mikepage is offline   Reply With Quote
opinions on rims whitefrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-08-2012 02:58 AM
Color Opinions chipz91 Scion FR-S / Toyota 86 GT86 General Forum 25 07-30-2012 06:27 PM
Hello need opinions ABacic90 Scion FR-S / Toyota 86 GT86 General Forum 4 06-21-2012 04:23 PM
Looking for opinions on what my dealer sent me on another BRZ order. joshua BRZ First-Gen (2012+) — General Topics 19 04-17-2012 03:07 PM
Need your opinions on a new look for the site FT-MH Scion FR-S / Toyota 86 GT86 General Forum 27 03-19-2011 04:47 PM
