#29 | |
Site Moderator
Drives: Stuff
However, removal of heat from the system comes AFTER removing it from the pad and caliper.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#30 | |
Drives: Legacy GT
So, for some applications it is worth going to the slotted rotor for more than just the slots because you get a better alloy and directional vanes. However, for the FRS/BRZ I am not sure if they are using it yet. For the STi and EVO, the 126 rotor (slots) is very different from the 120 rotor. |
#31 | |
Drives: FRS, M3
Like you said, a rotor's job is to act as a heatsink because there is heat energy created by means of friction. This heat is then cooled down by the ambient air floating around the rotors. For example, why do people get Big Brake Kits for better stopping power? Because the bigger rotor is able to absorb more heat and there is a larger cooling surface. But along with heat, there are also hot gasses/debris that are emitted from the point of friction. These hot gasses/debris often get trapped between the rotors and brake pads and create "glazing" on the brake, increase temperature, and give a slugglish brake feeling. So in the past, racing teams thought that cross drilling the rotors would help dissipate the heat better. But like you said as well: Less Mass = Less Energy Absorb = Poor Heatsink. However, with a slotted/vented style rotor, you can keep the same amount of surface area on the rotors while dissipating hot gasses/debris. Ever wonder why the slots are directional and kind of look like a propeller? It's because while the rotors spin, it forces cool air to be sucked in at the center, and hot hair to dissipate out just like any propeller/turbine/hairdryer etc. If you look almost all the racecars nowadays, they are mostly running slotted rotors. Take a look at these massive brakes on a NASCAR vehicle: -Frank Last edited by ModBargains; 10-18-2012 at 12:46 PM. |
#32 |
Drives: FRS, M3
I don't think it comes to that actually at all. I think it comes down to what you want out of your braking system. If you want to prolong the life of your brake pads and are satisfied with the stock braking system, a regular rotor would do just fine. But if you are looking for more of a bite and don't mind replacing brake pads sooner, a slotted rotor is going to give you increased bite, but it will eat away your brake pads sooner.
A slotted rotor is not a "bad idea" if increased braking performance is what someone is looking for. -Frank Last edited by ModBargains; 10-18-2012 at 12:49 PM. |
#33 | |||||||
Site Moderator
Drives: Stuff
Before reading this reply understand that I'm not against slotted rotors when used correctly.
![]() Quote:
NASCAR also does this: ![]() I haven't seen a BRZ with that level of brake cooling yet (nor do I expect I ever will). Here's my problem with slotted on this car on the track (again street use doesn't matter, just watch drilled rotors to check for cracks over time, but whatever the heck you want for looks), these cars, much to my surprise, simply don't have enough mass up front IMO to handle tracks that are tougher on brakes. They need more mass or better cooling through brake ducts (ie real cooling). This is one of my rotors after a day at Sebring: ![]() The other side is the same. I have no doubt those rotors were glowing a nice shade of red going into 17 and 6 at least. So with stock size rotors we already don't have enough mass IMO so removing ANY mass is going to reduce that capacity that's already borderline. I'm perfectly fine with slots or j hooks on wider/larger rotors and with cooling, just not as stock replacements for track use.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles Last edited by Dave-ROR; 10-18-2012 at 02:22 PM. |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | gmookher (10-22-2012) |
#34 | |
Site Moderator
Drives: Stuff
Man I can't even remember how many times this topic has been discussed here already.
-Dave
#35 | ||
Drives: FRS, M3
Again, I'm just here to help educate enthusiasts on what brake options are available to their FRS / BRZ and it's up to them to make a decision. I'm not here to argue or force you to accept that slotted rotors are the best for you. But again, I'm here to contribute to the forums and provide value. The Stoptech Power Slotted Rotors not only increase bite and help wipe away debris/gasses between the pad and rotor, but the hats come e-coated so they do not rust which is another advantage over stock rotors. Also, each power slot rotor has center split castings to provide proper heat transfer compared to the stock rotor. So there are other benefits going Stoptech Replacement Powerslot Rotors vs. stock rotors. -Frank |
#36 |
Site Moderator
Drives: Stuff
Hard to reply to those nested replies..
As for the OP, I already said multiple times for the street run whatever, it's not going to make much difference either way, so this left the street awhile ago I think. Brake ducts, I will if I have to.. I'd prefer not to because they get annoying and I don't feel like dealing with it, which is why I'm increasing disc mass on my car instead (width, not diameter really). I don't forsee a problem after that point so thankfully I would have to remove my fogs and deal with hose routing/securing, potentially limited steering angles, etc due to ducts. I also never said slotted decrease cooling, I said they decrease heat capacity because they have less mass unless mass is added somewhere else useful (which would be bad if it was added in the vanes, and it wouldn't serve much purpose in the hat). Capacity and cooling are two different things. On a car where it's borderline not being enough anyways I just don't think the slight benefits (bite, debris removal) offset the potential negatives (less heat capacity which will cause other components to run hotter), stress risers, etc. I'm sure I'm not the only one here who is upgrading front components due to the limited heat capacity of the stock front brakes, so again, removing mass is something I would *never* consider except for testing. I'd be more than happy to test it for you and gather data if I intended to keep stock components. If you want to provide the rotors I'm sure we can find someone to test it out. I'll supply temp paint and caliper strips if needed but won't send out the pyrometer... I like bite for feel reasons, however distances aren't changed in any meaningful way. The driver has way more impact on that so I guess to me braking performance, if tires can be locked, comes down to: heat management, modulation, lifespan and feel in that order. :shrug: People can buy what they want, I agree there, I just want to make sure people really understand what they are buying. Some brake "upgrades" remind me of all of these chassis braces. People want dynos, videos, first person impressions, etc when buying a $300 intake but will buy brakes and braces without any understanding or proof that what they are buying does anything postive for them.
-Dave
#37 |
Drives: Attitude
Did someone legitimately bring up pad off-gassing in a modern day pad/rotor argument about whether or not slots are bling bling?
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | chulooz (10-18-2012) |
#38 | |
Drives: FRS, M3
I understand what you are saying about decreasing the rotor disc mass, but again the amount of material that is actually taken off by going with slotted rotors, I think, is not going to negatively affect the heat capacity by much at all. I guess only test data will show that though. I think people should always do their research before buying any product whether it's an intake or chassis bracing. As far as chassis bracing, there are ways to test how much benefit it would provide. For example, Cusco explains how there chassis braces works...it's actually pretty information: http://www.jdm-option.com/eng/pr_CUSCO/towerbar.html -Frank |
#39 | |
Site Moderator
Drives: Stuff
Comparison, assuming I can crosslink Jeff's pics here: ![]() Vent pic - stock: ![]() Replacement AP disc: ![]() Also using AP 4 pots with pads that have 15mm friction pucks vs the OEM 10mm friction puck.
-Dave
#40 |
Drives: FRS, M3
Looks promising! Keep us updated!
-Frank |
#41 |
Drives: Whiteout FR-S
Thanks for all the info guys, I gained a lot of knowledge from this thread I wasn't expecting. Sorry if it had all been explained before but I feel comfortable with purchasing the centric blanks now, one of the rare cases where cheaper seems to be better for my uses.
| The Following User Says Thank You to JoeBoxer For This Useful Post: | TAP Auto Parts (10-19-2012) |
#42 |
Drives: On track
As long as you use at least the Centric Premium level rotor, it should be as good as an off the shelf oem rotor in our experiences with S2000 racing, which is not far off from the FRS/BRZ in concept. The right slotted design has its benefits, but from an OEM sized brake setup, we generally stick with OEM or equivlent blanks to keep costs in check as long as they are taking the heat without cracking frequently.
| Son of a @#$*&!!! I found out my dealer drilled holes on the front bumper | RYU | Scion FR-S / Toyota 86 GT86 General Forum | 40 | 09-12-2012 07:23 AM |
| Front Rotor Specs - Yes i searched. | njccmd2002 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 09-03-2012 01:58 AM |
| ($10 Discount on 2nd slot) CDC Autox Sat Aug 11th Hylton HS Woodbirdge, Va | echan | Mid-Atlantic | 0 | 08-09-2012 10:57 PM |
| License Plate Holes pre-drilled straight from Japan? | Motopythons | CANADA | 3 | 07-05-2012 10:15 PM |
