Old 10-09-2012, 05:24 PM   #29
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
can have stretched tire / with good fitment...and still look great.
but yes, performance will be compromised.
Touge Factory is offline   Reply With Quote
Old 10-09-2012, 05:39 PM   #30
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Edit: This dude's 18" x 9.5" Work Kiwani wheels are both badass and functionally fit the car
http://www.ft86club.com/forums/showthread.php?t=19038
I'd be much likelier to order some of these!
Jeff86 is offline   Reply With Quote
Old 10-17-2012, 11:59 PM   #31
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Can you do a 18x8.5 and a 18x10.5 package?
Tansey86 is offline   Reply With Quote
Old 10-18-2012, 01:26 AM   #32
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
I have 9.5" wide +38 Work Kiwamis on my 86 now......10.5" @ +22 would be immense but would require flares to fit. You are looking at 28.6mm sticking out of the guard further (which mine is flush at present) and 12.7mm inside wheel further would have to check clearance of that.
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 10-18-2012, 02:30 AM   #33
ebphoto
Drives: FR-S, NA8, S13
i run x9.5 +25 and.... yea the 10.5 would require a gross pull at least and tons of camber.
ebphoto is offline   Reply With Quote
Old 10-18-2012, 11:01 AM   #34
Tansey86
Tansey86's Avatar
So why make such a wide wheel for a car if it wont fit? I've seen 18x10's on this car, is it the offset that doesn't allow it?
Old 10-18-2012, 12:40 PM   #35
ebphoto
they can be made to fit... they just wont bolt right on.
some people are into fitment some arent.
it is the offset.. the +22 in a 10.5 is ~16mm more aggressive than my setup in the rear.. going off that it seems like it would require a 215 or 205 and a good bit of camber and fender work to fit.
these wheels werent made specifically for the car, they were made because everyone loves more concave... id guess this size would be special order for 5x100.
hopefully someone proves me wrong and can fit these with no widebody and less than 5 degrees of negative camber..
Old 10-18-2012, 01:00 PM   #36
jm1681
Drives: MKVI VW GTI
Originally Posted by Touge Factory View Post
Mother of god...
jm1681 is offline   Reply With Quote
Old 10-18-2012, 01:27 PM   #37
Touge Factory
Drives: ZN6
Staggered setup is available in many combinations.
Most Work Wheels can be ordered in 5x100, however they keep the 18x8.5 and 18x9.5 CR-ultimates readily available in the states due to confirmed fitment and clearance.
Same with the 18x10 Work XD9's.
You can order all of the Work Emotion series in the 5x100. Just need to have patience.
Old 10-18-2012, 01:43 PM   #38
Tansey86
Tansey86's Avatar
Id like to run the 18x10.5's in the back without a stretched fitment and very little if any camber. Can the offset and everything be setup to have these wheel fit comfortably in the rear with say a 305/35/18
Old 10-18-2012, 02:05 PM   #39
hippari
I Love your GUCCI Wheels!
hippari's Avatar
Drives: Raven Black FR-S
Send a message via AIM to hippari
with over fenders and no drop maybe.
I think it should be pretty obvious that this fitment is more for style than anything else when applied to this car.
@jinxyboi | @_iLLdynasty
Rice for the Rice God
hippari is offline   Reply With Quote
Old 10-18-2012, 02:24 PM   #40
Tansey86
Tansey86's Avatar
Or people who need a lot of tire in the back for a high hp build.
Old 10-18-2012, 02:29 PM   #41
hippari
hippari's Avatar
Then they should run a 10.5 wheel with +35 or +40 offset instead of +22 so they can actually fit that tire on the car.
Old 10-18-2012, 02:49 PM   #42
Tansey86
Tansey86's Avatar
Well that's what I was asking, I was wondering if an appropriate performance oriented offset was available. I apologize if I came across unclear.
FS:Toronto BNIB bronze 18'' Work Emotion Kiwami (ultimate CR, DEEEEP CONCAVE) Saibot Canada Classifieds 14 09-26-2012 05:51 PM
FS:Toronto BNIB bronze 18'' Work Emotion Kiwami (ultimate CR, DEEEEP CONCAVE) Saibot Wheels and Tires 7 09-18-2012 12:37 AM
Work CR Kiwami/Ultimate danscar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 09-11-2012 12:24 AM
Work Emotion CR KAI Ultimate Luke.Cariveau Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 08-23-2012 02:18 PM
Work Emotion CR Ultimate BRZ ad Hanzo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 07-18-2012 01:59 AM
