Old 05-31-2012, 10:31 AM   #1
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Work Emotion CR Ultimate BRZ ad
Hanzo is offline   Reply With Quote
Old 05-31-2012, 06:54 PM   #2
merlin2111
merlin2111's Avatar
Drives: Widebody '94 Miata R-Package
Very nice wheels.
I <3 my Miata.
But I <3 my new BRZ even more!
merlin2111 is offline   Reply With Quote
Old 06-01-2012, 01:36 PM   #3
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Bery nice... too bad you can't have any aggressive concave wheels due to the stupid bolt pattern
just... semi-concave
Snoopyalien24 is offline   Reply With Quote
Old 07-03-2012, 09:29 PM   #4
harajukukei
Drives: MB c230k
SARD makes a pcd converter if you absolutely must have 114.3
http://www.sard.co.jp/after/products...k/PCD/PCD.html
harajukukei is offline   Reply With Quote
Old 07-03-2012, 09:43 PM   #5
Snoopyalien24
Mr. Sarcasm
But you have to do too much
From @vividracing
The problem used to be the front hubs did not fit the 5x114.3 coil overs. So it would mean you needed to find a set or redrilled STi hubs.
You would need:
5x114.3 Hubs (new seals and bearings if used)
5x114.3 Brakes (brake lines, Calipers, Brackets, Rotors)
5x114.3 Axles (ends would be different but not sure on the r200)
5x114.3 Wheels
5x114.3 Coil overs (mount point to hub)
What I recommend is for everyone to hang tight. The wheel companies are playing catch up. Once they do the same wheels in 5x114.3 will be here for the 5x100. The nice part of 5x114.3 is the easier bear change, longer service life and wide wheels. Wide wheels are not going to matter much as there is only so much room for them. And your not making enough power to spin them. Remember light wheels for light power.
But this is pretty good
http://www.ft86club.com/forums/showthread.php?t=9330
Old 07-04-2012, 10:35 AM   #6
JDMSushi
JDMSushi's Avatar
Drives: JDM86
Few more to add
JDMSushi is offline   Reply With Quote
Old 07-04-2012, 10:55 AM   #7
Vino
3stars & a sun
Drives: FRS
Nice
Vino is offline   Reply With Quote
Old 07-04-2012, 11:40 AM   #8
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Those look good, a little more concave would be nice though.
Circuit Motorsports is offline   Reply With Quote
Old 07-04-2012, 12:13 PM   #9
Kenno
Kenno's Avatar
Drives: Toyota 86 GTS 6M
You can get the deep concave in 5x100 from WORK, it's a custom job.
Kenno is offline   Reply With Quote
Old 07-04-2012, 12:25 PM   #10
Snoopyalien24
Mr. Sarcasm
Any idea how much a wheel for that custom 5X100 concave action?
Old 07-05-2012, 12:25 PM   #11
harajukukei
Drives: MB c230k
anybody know the wheel sizes and offsets for the chargespeed car? the fitment is absolutely perfect.
Old 07-05-2012, 12:29 PM   #12
harajukukei
Drives: MB c230k
Old 07-05-2012, 02:15 PM   #13
Turbowned
Turbowned's Avatar
Guess I'll be sending money to Chargespeed once I get a BRZ!
Old 07-16-2012, 03:37 PM   #14
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
I emailed Work about weight of the 17x7 wheel, thinking it would be pretty light.
Answer: Emotion CR Ultimate 17x7.0 would come in around 18.48lbs.
That makes no sense according to the wheel weight chart - 18 lbs is the same as a Rota Torque which is like half the price.
Why is it like pulling teeth to get accurate weights?
Khyron686 is offline   Reply With Quote
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +30 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 11-20-2015 12:12 AM
Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +18 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 103 11-21-2013 03:28 AM
Work CR Kiwami/Ultimate danscar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 09-11-2012 12:24 AM
WORK Emotion Kiwami - 18x8.5/9.5. Staggered For FRS/BRZ *** Available Now *** RavSpec Wheels and Tires 59 07-24-2012 12:07 PM
WORK Emotion CR Ultimate Matte Black (MBL) Finish Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 26 06-05-2012 01:43 PM
