Old 08-12-2012, 02:15 PM   #1
Luke.Cariveau
"Fast Looking Slow Car"
Luke.Cariveau's Avatar
Drives: 13' BRZ
Talking Work Emotion CR KAI Ultimate
Here are some Emotion CR Ultimates in Matte Black
Specs:
Front; 18x8.5 +47 Offset W/ Goodrich Sportcomp 2 235/40
Rear; 18x9.5 +39 Offset W/ ^ 245/40
image host
hosting images
image upload
Luke.Cariveau is offline   Reply With Quote
Old 08-12-2012, 02:16 PM   #2
Luke.Cariveau
Drives: 13' BRZ
Coils on the way. too much space in there
Old 08-12-2012, 02:45 PM   #3
Luke.Cariveau
Drives: 13' BRZ
Forgot to say,
Front is semi-concave and rear is deep-concave.
Old 08-12-2012, 05:16 PM   #4
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Needs more low.
Black on Black. Nice looks good.
I'm a lil bias having CBS as well.
Need side profile pics when low comes.
Forgot to say,
As far as I know the changing the "disk" just moves the entire wheel in or out.
Being that what I think "disk" is. Simply put the thickness of the center of the wheel.
Changing the "disk" would make the material on the inside of the wheel, that gets matted to the rotor thinner or thicker.
Just a guess but, basically a built in spacer (or reverse). Dynamically changing offset.
^Correct me if I'm wrong.
All that just to ask you. > Do you know the measured difference between each type of concave(on the same width and offset wheel)? Flat, Semi and Deep?
Thanks for sharing.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 08-12-2012, 05:27 PM   #5
Luke.Cariveau
Drives: 13' BRZ
Originally Posted by Floggin Tires View Post
Needs more low.
Thanks for sharing.
I do not but here is the spec sheet off of the work website.
The rears had to be custom drilled but it was easy and work did it on site.
Old 08-12-2012, 05:32 PM   #6
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Great choice. :happy0180:
ill86 is offline   Reply With Quote
Old 08-12-2012, 05:34 PM   #7
ill86
ill86's Avatar
Drives: iG FR-S
Any straight on shots to show poke and concave?
Old 08-12-2012, 05:38 PM   #8
Luke.Cariveau
Drives: 13' BRZ
Let me take some, Ill post them in a minute.
Old 08-12-2012, 05:52 PM   #9
Luke.Cariveau
Drives: 13' BRZ
Here's some pictures of the poke/concave.
Not the best photographer but you can basically tell.
photo upload
Old 08-12-2012, 08:22 PM   #10
ill86
ill86's Avatar
Drives: iG FR-S
Thank you! Excellent pics.
The rear fitment looks perfect to me. Is the front a little tucked?
How do you like the staggered fitment?
Old 08-12-2012, 10:30 PM   #11
Luke.Cariveau
Drives: 13' BRZ
The front is flush. The staggered is nice, I wanted a little wider in the rear for a more aggressive look. since i'm not a track guy and haven't pushed the vehicle to its limits i have no real opinion on the fitment other than its looks.
Old 08-13-2012, 04:27 AM   #12
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Hate to ruin your fun but ive got the exact same setup but once you lower the front and ad a bit of - camber you are going to wish you would have gone with a different offset. Ill take a picture of how my front sits but i feel its pushed way inside a spacer could help.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 08-13-2012, 07:47 AM   #13
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
love the concavity.
just a minor nitpick: there are small differences between the CR Kai and CR Kiwami. Basically v1 and v2 of the same wheel.
dori. is offline   Reply With Quote
Old 08-13-2012, 10:33 AM   #14
Luke.Cariveau
Drives: 13' BRZ
Oh no not at all, I'm adding coil-overs to drop it slightly. Not enough to drastically change the vehicle but something to help minimize that wheel gap by about 50%
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x8.5 +47 / 18x9.5 +38 FML Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 91 06-13-2015 08:48 PM
WORK Emotion CR Ultimate (Kiwami) - 17x9 +38mm 5x100 IN STOCK NOW RavSpec Wheels and Tires 14 12-01-2012 12:26 AM
Work Emotion CR Ultimate BRZ ad Hanzo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 07-18-2012 01:59 AM
Subaru BRZ on WORK Emotion CR Ultimate (GTS) Hanzo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 07-12-2012 04:00 AM
WORK Emotion CR Ultimate Matte Black (MBL) Finish Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 26 06-05-2012 01:43 PM
