CANADA Canada
Old 10-14-2012, 11:01 PM   #1
grgonium
grgonium's Avatar
Drives: Whiteout FR-S
Bluetooth
How is it? Does it work well with audio streaming? Work good with phone calls? Does the caller hear alot of road noise?
Tried a search, came up empty. Unless i missed it.
grgonium is offline   Reply With Quote
Old 10-14-2012, 11:03 PM   #2
InstinctRacer
Solar System Surfer
InstinctRacer's Avatar
Drives: 2013 Whiteout FR-S A/T
I hear the callers voice so clearly I usually have to turn down the volume..
InstinctRacer is offline   Reply With Quote
The Following User Says Thank You to InstinctRacer For This Useful Post:
grgonium (10-14-2012)
Old 10-14-2012, 11:41 PM   #3
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
I use it to stream music off my phone almost every time I go home from work. Works great! Calls great! Pioneer is the bomb!
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following User Says Thank You to DaJo For This Useful Post:
grgonium (10-15-2012)
Old 10-15-2012, 12:51 AM   #4
Jlturner
Jlturner's Avatar
Drives: Scion fr-s
No complaints, everything works great.
Jlturner is offline   Reply With Quote
The Following User Says Thank You to Jlturner For This Useful Post:
Old 10-15-2012, 10:49 AM   #5
grgonium
grgonium's Avatar
Good to hear. Thanks.
Old 10-15-2012, 03:13 PM   #6
dadream
Drives: SCION FRS (Raven Black)
Same here. quality is amazing.
only thing though, i sometimes have trouble with my contact list. sometimes it transfers and works fine, other times the radio won't even let me press on the "contact" button... i have a galaxy S3 phone. used to have a BB Curve and same thing then.
anybody have the same sort of issue with cellphone contacts??
dadream is offline   Reply With Quote
Old 10-15-2012, 04:02 PM   #7
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
I stream music everyday and the sound is amazing.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 10-15-2012, 05:13 PM   #8
grgonium
grgonium's Avatar
So for those streaming music through Bluetooth, is there a difference in quality if you plug it in via USB?
Old 10-15-2012, 05:43 PM   #9
RPhong
Drives: 2013 Ultramarine FR-S
Sound quality seems about the same to me. Only thing is that you control music via the phone when connected by bluetooth whereas it is controlled by the HU when connected by USB.
RPhong is offline   Reply With Quote
Old 10-15-2012, 05:48 PM   #10
TemeCal
Drives: 86
The reason why you can't access certain functions (like pair a new device, address book, etc...), is because it's disabled when you're moving. When you are at a complete stop, all functionality will be available. Once you start moving again, it's gone.
With that said, I'd love to find a bypass...like the other Pioneer aftermarket units are capable of. Best thing to do now, is assign your most common contacts to your speed dial buttons. Those are accessible when in motion.
TemeCal is offline   Reply With Quote
The Following User Says Thank You to TemeCal For This Useful Post:
dadream (10-19-2012)
Old 10-15-2012, 08:18 PM   #11
Lithandril
Drives: Asphalt fr-s 6mt
there is a way to bypass it, you'll need to pull the HU out and ground the wire that connects to the ebrake that disables those functions.
Lithandril is offline   Reply With Quote
Old 10-15-2012, 08:22 PM   #12
JDMenrique
DEEEERP
JDMenrique's Avatar
Yeah, I have no problems with it. Everything works as advertised and I am pretty happy with it.
JDMenrique is offline   Reply With Quote
Old 10-15-2012, 08:29 PM   #13
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
Great system. Calls are clear, and music etc plays well. The phone quality is much better then the high end arsenal deck i had in my old car.
Ravenlokk is offline   Reply With Quote
Old 10-15-2012, 08:36 PM   #14
Bleevin
Drives: 2013 FRS - Whiteout
If you have the Bespoke unit only Iphone's are reconized through USB... but you can still charge your android phone via usb...
Bleevin is offline   Reply With Quote
BRZ/Bluetooth/iPhone Silver Bullet BRZ Electronics | Audio | NAV | Infotainment 4 03-06-2014 02:10 AM
Cant use headunit with bluetooth. xdbuix Electronics | Audio | NAV | Infotainment 13 10-11-2012 09:22 PM
Bluetooth/Nav inimitable Electronics | Audio | NAV | Infotainment 40 09-26-2012 09:35 PM
FRS bluetooth set up jym89709 Electronics | Audio | NAV | Infotainment 16 09-08-2012 04:04 PM
Anyone else having bluetooth problems? Scooter Style Electronics | Audio | NAV | Infotainment 8 08-03-2012 07:38 PM
