Old 10-11-2012, 03:36 PM   #15
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
My understanding was that the top bolt is 16mm but you can use a 14mm straight bolt in its place and the play that you get is your camber adjustment. I believe this is what's outlined for factory-style alignment.
The eccentric bolt (16mm I think) would go in the lower hole.
Correct me if I'm wrong, I seem to hear conflicting reports on this.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 10-11-2012, 03:50 PM   #16
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Top hole is 16mm and bottom hole is 14mm.
I am just using Subaru 14mm crash bolts on the 16mm top hole, so gaining camber by the smaller bolt having room in the larger hole.
From looking at eccentric camber bolt pics, it seems the "lobe" would probably be 16mm (max that can fit the top hole) and the "shaft" would be something smaller like 14mm?
I would think that allows greater adjustment than the 14mm straight crash bolts, since you not only gain camber from the smaller bolt in the larger hole like the crash bolts, but also have the lobe part to push the hub even more inward.
brz7400 is offline   Reply With Quote
Old 10-11-2012, 04:29 PM   #17
gmookher
sorry, both bolts upper and lower are the same, and the correct application regardless of what ever may be listed is the KCA416, it goes in the upper hole.
You do NOT take out a shouldered 16MM bolt and replace it witha loose fitting 14mm, not on my car.
you DO take the 16mm andreplace it with a KCA416
Its your car and your safety..
Old 10-11-2012, 06:08 PM   #18
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
Where did you get your KCA416s from? Most everywhere I look they only have the 414s..and whiteline wants $80 to ship them here..which is obscene.
Old 10-11-2012, 06:14 PM   #19
JM Auto Racing
JM Auto Racing's Avatar
Drives: 2010 Dodge Ram
Send a message via AIM to JM Auto Racing
we have them in stock. Pm us if your interested.
JM Auto Racing is offline   Reply With Quote
Old 10-11-2012, 07:24 PM   #20
beebo
Drives: Whiteout Scion FR-S
I just got my 16mm camber bolts installed today. I ordered them off nissanraceshop.com. excellent service. They had overcharged me by accident and i didnt even know it until they called me to tell me. they refunded the extra charge and overnighted the bolts to me! i would recommend them!
beebo is offline   Reply With Quote
Old 10-11-2012, 07:33 PM   #21
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
too expensive for camber bolts
Old 10-11-2012, 09:40 PM   #22
gmookher
click on the word camber bolt in my signature
Old 10-11-2012, 10:41 PM   #23
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
i got mine @TiTAN Performance for cheap price
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 10-11-2012, 10:43 PM   #24
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
yea but the 14mm
Old 10-12-2012, 02:47 PM   #25
jumbaco
jumbaco's Avatar
Drives: FD
try their website. They have a few dealers in NY.
http://www.whiteline.com.au/dealer2012.php
jumbaco is offline   Reply With Quote
Old 10-12-2012, 02:49 PM   #26
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
I found them and for a really good price
Old 07-06-2013, 06:21 PM   #27
40flash
John 1:12
40flash's Avatar
Drives: Pearl white BRZ Limited
I haven't taken the upper bolt out of my BRZ yet but many cars have a slotted or oblong upper hole,(taller top to bottom) which allows for a 16 mm bolt to fit into a 16 mm hole even though there is a lobe that would be larger than 16mm. As you then rotate the bolt, the lobe pushes on the slot and moves the hub in and out. Hope that helps you understand how they work. Don't think I'd put a 14 mm bolt in a 16 mm hole. It isn't as safe and fine tuning the adjustment would be much harder than it needs to be if you have the correct part.
If someone can confirm that the upper hole is slotted, (oblong) then this pair should work. Ingalls part number 81260 $25 - free shipping at Amazon.
[ame="http://www.amazon.com/Ingalls-Engineering-Caster-Camber-Adjusting/dp/B001UCD6ZS/ref=au_as_r?ie=UTF8&Make=Subaru%7C13&Model=BRZ%7C2 1598&Year=2013%7C2013&carId=002&n=15684181&newCar= 1&s=automotive&vehicleType=automotive"]Ingalls Engineering 81260 Caster/Camber Adjusting Kit : Amazon.com : Automotive[/ame]
Ingalls also makes adjustment bolts for non slotted 16 mm applications.
40flash is offline   Reply With Quote
Old 07-07-2013, 12:03 AM   #28
40flash
John 1:12
40flash's Avatar
Update:
I now have better info and need to update the info I gave out in my first post right above this one.
I took out both the upper and lower bolts and inspected them and the hole they came out of. Both holes are round and not slotted as I thought they might be based on prior experience with other manufacturers. Since they are round, Any bolt with a lobe that makes the bolt larger than the size of the hole will not fit. The bolts are definitely not the same as someone posted earlier. The lower bolt is straight and is 14 mm. The upper bolt is both 14 & 16 mm. The first inch or so is 16 mm and then tapers to 14 mm. The upper hole is 16 mm all the way through so the bolt only makes contact with the hole for the first half, then it's in the air for the other half. Anyone knows that a chain is no stronger than it's weakest link. That being the case, the bolt isn't much if any stronger than a straight 14 MM bolt in my opinion. If it were to break, (very unlikely) it would fail at the point that it tapers down to 14 MM. After seeing this, I have changed my opinion and now think that the 14 mm bolt is nearly the equal in strength and should be no safety issue. Don't sue me, It's just my opinion but I would have no qualms about driving with it. There is simply no way with out running you car in to a stationary object to snap this bolt if torqued properly. I don't care what kind of sticky tires you have, you can't generate enough load to break these bolts. Still, adjusting camber with a 14 mm bolt in there will be trial & error until you get lucky and arrive at what you are looking for. I'd still recommend a 16 mm adjustable camber bolt but it needs to be one designed for a round hole. You can find them at the amazon link above and I'm sure many other outlets. Hope this helps.
Crash bolts alignment change ABQautoxer Tracking / Autocross / HPDE / Drifting 39 03-24-2014 05:45 PM
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 06:06 AM
Another crash bolts alignment thread jeebus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 10-28-2012 12:29 AM
seat bolts? zooki Cosmetic Modification (Interior/Exterior/Lighting) 3 08-29-2012 06:00 PM
replace front crash bolts to add camber? Matt Andrews Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 06-15-2012 10:05 AM
