Old 10-09-2012, 06:48 AM   #15
roddy
roddy's Avatar
Drives: '13 Ultramarine
My car came from the factory over filled (between 1/4-1/2 quart) and I never had any issues because of it. Others have reported the same. That said, your bumper does look pretty ugly...are the insides of your exhaust tips greasy with oil residue?
Old 10-09-2012, 07:46 AM   #16
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Originally Posted by einzlr View Post
Haha yeah that could do it and could be unrelated to the oil level. You said you noticed the oil level when you picked up your car, right? If they put in new oil and filter, they would have allowed for the filter to soak up some oil, hence filling past the "full" mark. Have you checked the level again after driving it for a while?
I noticed this a couple of days after the car was picked up (yesterday)
Later today I will take a pic of the current level.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 10-09-2012, 10:06 AM   #17
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
That much shouldn't really make much of a difference as long as you don't beat on it nonstop. But if your worried just jack it up and drain a little bit
Old 10-09-2012, 10:13 AM   #18
YourFearlessLeader
Team ScioNRG President
YourFearlessLeader's Avatar
Drives: 2017 WRB BRZ
To be honest, from my experience with the EJ engine series they are very tolerant to being over-filled. In the turbo WRX/STi you might get some blow by, but never really any engine issues.
The FA20 I really cant say, I guess time will tell.
2017 Subaru WRB Limited BRZ w/ PP
YourFearlessLeader is offline   Reply With Quote
Old 10-09-2012, 02:11 PM   #19
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Generally, the oil being a little bit low is better than being too high. The quote from the Forester forum covers this, but the crank can aerate the oil which means you have air where oil should be and that can cause an issue. Aerated oil will not have as much pressure and you can run dry in some spots.
To be safe I would have the dealership drain some oil and tell them that there is a high mark on the dipstick for a reason if they contest it. Also make them note that the oil was high for their records in case there are any warranty issues in the future.
-Zach
RallySport Direct is offline   Reply With Quote
The Following User Says Thank You to RallySport Direct For This Useful Post:
@Art_Mighty (10-10-2012)
Old 10-10-2012, 01:06 PM   #20
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Update!
Yeah there was WAY too much oil in there. I didn't want to go back to a dealership and have them make the same mistake so I bought one of these...
... and pulled out over a quart of oil until the dipstick read in-between the dots!
So now a few follow up questions:
I'm pretty sure the smoke I saw last week from the motor was probably oil blow by. Should I consider the oil in the engine "good" or has it been aerated and should be changed?
Is there any other follow up I need to consider?
Old 10-10-2012, 01:25 PM   #21
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
What did the tailpipes look like?
That almost looks like fresh oil from road construction...
I can't see how a 1/2 quart would do that. Mine came with that much overfilled and I extracted it when I got home.
Car already had 50 miles on it and the tailpipes are clean....
CircuitJerk is offline   Reply With Quote
Old 10-10-2012, 01:36 PM   #22
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
The back of the car was oily but the tail pipes actually were dirty and rusty?
Now that I have all of that excess oil out of the car I'm going put a few hard rev happy miles into the car and see of anything funny comes out of the tail pipe...
Old 10-10-2012, 01:57 PM   #23
CircuitJerk
Pull my finger...
Hopefully it's all good for Sunday
Old 10-10-2012, 02:07 PM   #24
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Originally Posted by 70NYD View Post
Check your air filter
You might find that the access oil has good all the way down there if it looks the bad on the back
Also your cat will be affected
I did check the air filter and it looked pretty clean. I replaced it just in case.
Old 10-10-2012, 02:08 PM   #25
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Indeed. I just posted in the other thread about that. I think we're good to go...
Old 10-10-2012, 03:18 PM   #26
RallySport Direct
You don't need to worry about changing the oil because it will settle and the air will come out on it's own.
Just keep an eye on the level and when you check it, do it about 2 mins after you shut the engine off to get an accurate reading. It can take some time for it to all drain back into the pan after it is shut off.
-Zach
Old 10-10-2012, 03:54 PM   #27
CBR600RR
Drives: Raven Black
I'd keep an eye on your dipstick and watch for any abnormal oil consumption. if you are burning oil - ask for a new engine
The Following User Says Thank You to CBR600RR For This Useful Post:
@Art_Mighty (10-11-2012)
Old 06-15-2014, 12:14 PM   #28
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Hey @@Art_Mighty, what was your outcome?
blackfireball5 is offline   Reply With Quote
BRZ / FR-S Boxer Engine Dyno Powerband revealed Levi Engine, Exhaust, Transmission 217 06-01-2012 12:20 AM
total noob with boxer engine NickDude84 Engine, Exhaust, Transmission 35 04-27-2012 08:51 PM
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 12:04 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 10:55 PM
More proof of FT-86 Boxer engine appears in logo Hachiroku Engine, Exhaust, Transmission 33 01-03-2011 01:47 AM
