Old 10-09-2012, 02:19 PM   #15
Argento_FR-S
Drives: Scion FR-S
I have the TSW Nurburgring 17 x 8 +35 with a 245/40R17 coming and should be installed this weekend. Will post pics if I'm not to busy putting miles on them.
Argento_FR-S is offline   Reply With Quote
The Following 3 Users Say Thank You to Argento_FR-S For This Useful Post:
diirk (10-15-2012), fl_speed001 (10-09-2012), giraffee (10-10-2012)
Old 10-09-2012, 09:50 PM   #16
fl_speed001
Drives: Whiteout FR-S
Rock on, I have been wanting to see these! Pls post pics!
fl_speed001 is offline   Reply With Quote
Old 10-09-2012, 11:51 PM   #17
fishek
Drives: H8R FR-S
Me too!
fishek is offline   Reply With Quote
Old 10-10-2012, 12:32 AM   #18
dolph
Drives: 2013 BRZ, 2004 WRX
I really want to see 17's as well, but in the mean time, here's some 19" TSW Nurburgrings on an argento.
dolph is offline   Reply With Quote
Old 10-11-2012, 03:51 AM   #19
giraffee
giraffee's Avatar
Drives: Slowly
That's the pearl, not argento
giraffee is offline   Reply With Quote
Old 10-11-2012, 06:04 AM   #20
Akired86
Akired86's Avatar
Drives: 2013 Scion FR-S Asphalt
I have Enkei RPF1 17x8 +35 offset, waiting for the centric ring on the wheels. Once I get them I'll post some pics on the wheels.
Akired86 is offline   Reply With Quote
Old 10-13-2012, 09:51 AM   #21
Argento_FR-S
Drives: Scion FR-S
TSW Nurburgring Bronze 17 x 8 +35...
8 Megapixel Droid Camera with almost no sunlight left. I will be taking it to the mountains today and getting some daylight photos.
The Following User Says Thank You to Argento_FR-S For This Useful Post:
giraffee (10-15-2012)
Old 10-13-2012, 04:20 PM   #22
dabocx
dabocx's Avatar
Drives: Scion FRS
My friend has some 17X8 +32 that he might now use. I want to slap on the stock tires on them and see how that fits.
dabocx is offline   Reply With Quote
Old 10-14-2012, 01:33 AM   #23
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
I believe the RPF01 is coming out in 17x9 +35. that's the one you want since the narrower widths are going to look similar (not flat/concave).
dori. is offline   Reply With Quote
Old 10-15-2012, 07:27 AM   #24
Akired86
Akired86's Avatar
Is there any reason why someone would use a 17x9" wide? Beside looks, I mean wider tires/rims doesn't mean better handling moreover it heavier and diameter of the wheel changes, this could result slower less fun to drive car not to mention higher fuel consumption. But then again it your money, think before you spend those hard earn dollars!
Old 10-15-2012, 08:38 AM   #25
Foobar
SLO NO MO
Foobar's Avatar
At this point it's for looks, but once folks are laying down 500+ horsepower on the ground, they'll probably want big sticky drive tires.
Old 10-15-2012, 10:31 PM   #26
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
They are coming out in +45 next month at TireRack. +35 will limit tire size unless if you run high camber and it'll be useless up front. Of course some people are into that. There are a few that run +35 RPF1 17x9 on this site, so I'm sure you can source some out if you want that offset. The face/concave will be the same +35 vs. +45.
JimmyMac is offline   Reply With Quote
Old 10-17-2012, 01:27 AM   #27
diirk
diirk's Avatar
Drives: 4Runner
How do you figure this? 17x8 +35 will fit fine and allow a 245/40-17 to be run with maybe -2°of camber. Unless everyone else is wrong.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 10-17-2012, 01:42 AM   #28
JoeBoxer
JoeBoxer's Avatar
I saw another wheel in 17x8 +35 you guys might be interested in, Neuspeed RSe05.
http://www.neuspeed.com/880502s-rse0...eel.html#popUp[products]/1/
17.5 pounds, black or gunmetal, and 57.1 center bore is 1mm more than ours so shouldn't need hubrings.
Wheel Directory: WedsSport TC105N 17x8.0 +42 Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 94 06-21-2019 04:33 AM
FS/FT: 17x8 +35 TE37 Bronze bAS1c Wheels and Tires 17 05-02-2014 11:52 AM
Wheel Directory: Advan RG II 17x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-11-2012 07:28 PM
17x8 +35, will it rub? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-31-2012 03:26 AM
17x8.5 wheel selection Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 06-10-2012 03:13 AM
