Old 09-13-2012, 05:46 PM   #1
feedbag
Seasoned Spirit
Drives: 2013 DGM BRZ Premium
[REQ] BRZ Halo Lights always on w/ Ignition
Hey, has anyone made it so that the halo lights (or whatever you want to call them) are always on when the car's running?
I'd imagine it's a fairly easy mod but I'm afraid to go off and do it without any guidance -- LEDs can easily be burnt out if you don't give them the proper voltage / amperage, also there's the fact that some of you probably know of some convenient wires to tap in the area, so I thought I'd put a request out there and hope that somebody's done it before :P
feedbag is offline   Reply With Quote
Old 09-13-2012, 06:45 PM   #2
Roborat
Drives: Scion FR-S firestorm red
You can look up my thread I did this mod, but with Halos for my FR-S. I would say u would have to isolate those wires cut them and plice them into the same wires I used. This is not very simple but can be done. I haven't seen the BRZ wiring though.
Roborat is offline   Reply With Quote
Old 09-13-2012, 11:59 PM   #3
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Can't you just throw a relay off the DRL's and have that switch the Halo's on? Snip the Halo positive lead, throw it on the relay, then find a switched or even constant and put it on the relay?
michaelahess is offline   Reply With Quote
Old 09-17-2012, 01:01 PM   #4
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Can this be setup with Toyota Techstream ? *
TIE Pilot is offline   Reply With Quote
Old 10-03-2012, 04:57 AM   #5
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
Bump nobody?
RAWR BRZ is offline   Reply With Quote
Old 10-03-2012, 08:17 PM   #6
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
This is something I definitely plan to do, along with the LED strip, just haven't gotten around to doing it yet. Ill post a basic DIY when I do though if no one else has done it yet.
Flat Black VW is offline   Reply With Quote
Old 10-03-2012, 09:34 PM   #7
RAWR BRZ
Thanks! It would look sick
Old 10-03-2012, 10:26 PM   #8
gmookher
what led strip?
Old 10-03-2012, 10:49 PM   #9
Flat Black VW
Originally Posted by gmookher View Post
what led strip?
I guess it may not be considered an LED strip to everyone but the lights in the lower portion of the bumper, above the limited's fog lights. I dont like that they turn off when the headlights turn on.
The Following User Says Thank You to Flat Black VW For This Useful Post:
DrDuquette (09-06-2013)
Old 10-04-2012, 12:09 AM   #10
dsgerbc
Drives: BRZ(sold), STI
Possibly, but I didn't see when I was poking around.
Did some quick looking at the circuit diagram. One would have to energize the tail relay to have halo lights on (along with side markers and tail lights).
The relay is inside the body ecu by the left driver's knee box. One has to ground pin 50 of 3A connector to energize the tail relay.
In the same connector on different pins there is a signal that energizes some ignition relays, so I'm guessing it should be good.
So throw another relay that's activated by pins 15&12 of 3A and connects pin 50 to Ground. To be completely safe maybe some diodes are needed into whatever connects to pin 50 (can't find what it is), not sure. It's been a while since I did any wiring.
Now someone should try it
The Following User Says Thank You to dsgerbc For This Useful Post:
TIE Pilot (10-04-2012)
Old 10-04-2012, 10:21 AM   #11
dsgerbc
On a second thought (given that I didn't find where the pin 50 goes, unless it's unused completely), it's probably safer to wire the relay trigger to some ignition lead on the 3C connector and make the relay connect that wire to 3C pin 12 or 13 (forgot exactly which one feeds the halo lights).
Old 03-20-2013, 03:55 AM   #12
taiguochin
Drives: 2013 Subaru BRZ Limited WRB
Was so excited to see this post! Did anyone ever get this done??? Please respond!
taiguochin is offline   Reply With Quote
Old 03-20-2013, 01:09 PM   #13
Flat Black VW
Ill get around to it eventually, pretty low priority for me. Been busy at work lately, but eventually I will do it.
Old 04-12-2013, 01:50 PM   #14
DNAPoPo
GreddyBRZ meets GreddyFRS
DNAPoPo's Avatar
Drives: SSM Limited BRZ
subscribed
CO>CA|Greddy Intake + EVO 3|Enkei Raijin|KW V3|BeatSonic
SoCal 86 OC Club
Tuesday Night Irvine DJ Meet Thread
Irvine FR-S & BRZ Car Meet(FaceBook)
DNAPoPo is offline   Reply With Quote
Halo ODST Commercial (Epic)!! MR2fan Off-Topic Lounge [WARNING: NO POLITICS] 7 09-14-2015 01:29 PM
FRS Ignition Key ft86Fan Scion FR-S / Toyota 86 GT86 General Forum 120 07-22-2014 09:23 PM
Halo Light Logic Modification? feedbag Cosmetic Modification (Interior/Exterior/Lighting) 9 01-28-2013 11:33 PM
New test from Ignition. zoomzoomers Scion FR-S / Toyota 86 GT86 General Forum 9 04-30-2012 11:31 PM
*** Front Lighting Modifications HID Headlights LED Angel Halo Custom Housing *** zAnSh1n Cosmetic Modification (Interior/Exterior/Lighting) 21 04-04-2012 04:41 PM
