Old 09-20-2012, 01:32 AM   #1
Filipino Royale
Got Rice?
Filipino Royale's Avatar
Drives: 37J BRZ-L
Talking Motul fluids
Hi guys, been reading a lot of things that the oem fluids on our precious cars aren't that good, so been searching for the whole package to change all the fluids.
Here's my list for Motul.
Engine: Motul 8100 xcess 5w40
Brake: Motul DOT 3/4
Transmission: Motul Gear 300 75w90
Diffential: Motul Gear Comp 75w140.
I'm oPen for all suggestions and comments.
Thank you.
Be a Leader, Be a Friend, Be at Service. -AɸΩ
Filipino Royale is offline   Reply With Quote
Old 09-20-2012, 01:53 AM   #2
midenginebias
Drives: 2001 Mr2 Spyder
Read the oil label and tell me what it says...
Member of Heya Project for Fr-S/BrZ.
Tire choice, Dash, Options list, Engine, Chassis, Suggestions; My fault
Owned N/A '93 Mr2, N/A '91 Mr2, '98 Corolla, Mazdaspeed Mx-5, '07 Legacy Wagon, E90 328i well maintained and lit up on fire while driving on the freeway in traffic.
midenginebias is offline   Reply With Quote
Old 09-20-2012, 02:26 AM   #3
donutfilling
donutfilling's Avatar
Drives: frs
i thought motul brake fluid was a dot 4?
Why not use motul 300v instead of 8100? and why 5w-40?
the toyota oem 0w-20 is probably one of the best for cold starts so oil preference can change depending on what type of driving you do the most.
Do you track the car? Motul is pretty expensive if it's never going to be pushed.
donutfilling is offline   Reply With Quote
Old 09-20-2012, 02:44 AM   #4
gmookher
Thank you.
I disagree with your choice of motor oil, unless youre trolling, which I think you are, do a search on motor oil, and find one other recommendation for 5w-40 before embarrassing yourself, or wasting anyones time
I think you should explain why motul 75w90 is a good lube for my tranny. whats its cSt?
I think you couldnt choose a worse diff oil. I use that in my truck that weighs 6000 lbs
You brake oil choice appears vague. dot 3? dot 4? whats your target boil temp?
The Following User Says Thank You to gmookher For This Useful Post:
RRnold (09-20-2012)
Old 09-20-2012, 03:38 AM   #5
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Yeah, I really hope you're not serious with this... If so, you need to do a lot more research before changing any of your oils/fluids. Thicker does not equal better. And Motul isn't the best in the world at everything. And read your owner's manual.
BTW, I just saw this on their website: http://www.motul.com/us/en-US/products/632
It's a 0W-15 oil... Apparently, there are 0W-10 and 0W-15 oils out there now, albeit only recommended for short term runs.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 09-20-2012, 07:14 AM   #6
roddy
roddy's Avatar
Drives: '13 Ultramarine
...way too thick on the gear oil. There is no need for 75W140 in this car.
Old 09-20-2012, 09:10 AM   #7
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Use 0W20 300V or 8100 Eco-lite for the engine. Do a 0W-30 (8100) or 5W-30 (300V) if the car has forced induction.
Gear300 75W90 for the transmission and rear end
RBF600 or RBF660 brake fluid, or Castrol SRF (if your a real baller @ $65 a liter)
No Limit Motorsport is offline   Reply With Quote
The Following User Says Thank You to No Limit Motorsport For This Useful Post:
Mathewgzlz (10-13-2013)
Old 09-20-2012, 12:35 PM   #8
Hanakuso
When it comes to 0w-20 oil, Toyota is one of the highest recommended on oil forums.
Hanakuso is offline   Reply With Quote
Old 09-20-2012, 01:15 PM   #9
diirk
diirk's Avatar
Drives: 4Runner
Personally, I think I'll be running Amsoil throughout.
Motor oil: 0w-20 ASM
Brake: Series 500 DOT3 or Series 600 DOT4
Transmission: SVG 75-90
Diff: SVG 75-90
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 09-20-2012, 01:39 PM   #10
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Whats the difference between the 300v and the 8100? I noticed the 300v isn't much more expensive but is it overkill for non track use?
Old 09-20-2012, 01:42 PM   #11
empower-auto
Kouki-Monster
empower-auto's Avatar
It is grossly overkill.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 09-20-2012, 01:49 PM   #12
JoeBoxer
JoeBoxer's Avatar
Thanks i'll stick with the 8100 then.:happy0180:
Old 09-20-2012, 01:59 PM   #13
diirk
diirk's Avatar
Drives: 4Runner
Price difference is only about $10. But I'm not really sure about the differences.
There's a package deal thaat was recently listed that looks like a good deal.
http://www.ft86club.com/forums/showthread.php?t=17759
diirk
The Following 2 Users Say Thank You to diirk For This Useful Post:
Filipino Royale (09-21-2012), JoeBoxer (09-20-2012)
Old 09-20-2012, 02:37 PM   #14
bluesubie
Drives: 2004 Subaru Forester 2.5XT
The 300V has higher levels of anti-wear additives like zinc and phosphorus than 8100 and very high levels of the friction modifier moly. The new 300V ester core actually has reduced levels of calcium (detergent) because they're focusing more on being a track oil and less on extended drains for the street.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2742759
300V is also made with ester base stocks. I probably wouldn't run the new ester core much past 4,000 miles without a used oil analysis.
Why would you recommend a GL5 for the transmission? Isn't GL3/4 speced?
-Dennis
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
diirk (09-21-2012)
Motul Oil's & K&N oil filter deals! No Limit Motorsport Mechanical Maintenance and Tools 1 09-18-2012 02:20 PM
Delete driver01 CANADA 5 08-30-2012 04:58 PM
Fluids change after break-in yomny Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 08-05-2012 01:18 PM
Service Parts! Motul Oil / Oil Filters vividracing Mechanical Maintenance and Tools 8 06-20-2012 12:46 AM
