F Z1LLA
Drives: Lexus IS-F Series 2
BRZ HID Bulb Swap
Has anyone done a bulb swap on their BRZ ? Couldn't find any info in DIY section
UPDATE: Figured it out for anyone thinking of changing bulbs. There are two small retention clips on either side of the bulb. Just push these forward and up toward the bulb and this will allow you to pull the bulb plug assembly outward towards the engine bay. Remove bulb and replace with desired bulb. Reverse steps to reinsert. Done ![]() There's a bit of a learning curve when re-attaching the retention clips. Took me 20 minutes to figure it out, second one took me a minute or so once I got my head around it. Take your time to examine the clips before removal and re-attaching, refer to other HID if you need too. Also pay attention to bulb installation as there are two small notches on the bulb plug, one is rectangular and the other is half moon shaped. Make sure that the rectangular opening is too the top of the bulb plug as it fits over a metal or plastic tab when reinserting plug
2URGSE Last edited by JPxM0Dz; 09-13-2012 at 06:10 PM. Reason: UPDATE |
| The Following User Says Thank You to JPxM0Dz For This Useful Post: | kevinnivek8877 (09-28-2012) |
#3 | |
F Z1LLA
Done that, manual refers HID bulb replacement to be done by Subaru dealer. At least from what I could see I'm swapping out the stock bulbs for some 4DS Philips 6000K
2URGSE Last edited by JPxM0Dz; 09-11-2012 at 05:45 PM. Reason: UPDATE |
| The Following User Says Thank You to JPxM0Dz For This Useful Post: | SkAsphalt (10-01-2012) |
#4 |
Drives: BRZ Limited
if you are looking for the what type of hid bulb in our car it is 4DS. its in our owners manual if you look under specifications
#5 | |
F Z1LLA
Nope sorry, I knew that and I have the bulbs in hand. My question was, has anyone done a bulb swap yet as I was curious about the clamp mechanism within the HID assembly and how easy it was to remove and replace bulb Thanks
2URGSE |
#7 |
Drives: SWP BRZ Limited 6 Spd
Factory light output has been absolutely fantastic for me so I have had no need to change it.
#8 |
Yep!
Drives: 2015 WRX Sti
The bulbs SHOULD be a direct fit. My old Rx8 had stock HID and the bulbs were a direct fit. As long as it's the same size you won't have a problem. The reason it says dealer is because the risk of electrocution.
#9 | |
F Z1LLA
Yeah I realize that, my question was more inline with the clamp mechanism that holds the bulb in place. I didn't wanna toy with it too much until I had an idea how the bulb plug is removed.
2URGSE |
#10 | |
F Z1LLA
2URGSE |
#11 |
F Z1LLA
![]() There's a bit of a learning curve when re-attaching the retention clips. Took me 20 minutes to figure it out, second one took me a minute or so once I got my head around it. Take your time to examine the clips before removal and re-attaching, refer to other HID if you need too. Also pay attention to bulb installation as there are two small notches on the bulb plug, one is rectangular and the other is half moon shaped. Make sure that the rectangular opening is too the top of the bulb plug as it fits over a metal or plastic tab when reinserting plug Sent from my GT-I9300 using Tapatalk 2
2URGSE Last edited by JPxM0Dz; 09-13-2012 at 06:09 PM. Reason: UPDATE |
#12 |
Drives: Subaru BRZ
Does anyone know the temp of the OEM HID bulbs. Most OEM are 4300K (provides maximum output) but these look a little whiter - maybe 4800K?
#13 | |
F Z1LLA
2URGSE |
#14 |
thanks. I was thinking about doing this. make a DIY with pics!
did you unplug the battery before doing this? |
| Fog light bulb size? | huma | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 01-22-2015 05:57 PM |
| BRZ Stock HID Bulb Info - D4S | kanundrum | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 10-05-2012 10:55 AM |
| bulb size for frs | brichard0625 | Exterior Parts - The Rest | 4 | 07-23-2012 03:33 PM |
| which H11 replacement bulb | 7thgear | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 07-18-2012 10:23 AM |
| BRZ D4S bulb ? | MRZ415 | BRZ First-Gen (2012+) — General Topics | 82 | 06-28-2012 07:18 PM |
