Old 06-25-2012, 08:05 PM   #1
huma
Drives: ITR
Fog light bulb size?
What bulb size is the fog lights in the brz?
huma is offline   Reply With Quote
Old 06-25-2012, 10:28 PM   #2
huma
Drives: ITR
Come on...nobody knows? My brz should be coming in Thursday or Friday...and I want to install yellow fogs asap!
Old 06-26-2012, 12:26 AM   #3
percyng
Drives: White BRZ 6MT
PSX24W 24W according to manual. But not sure if it compatiable with any H4, H7 type, etc...
Sorry not familiar with this type of blub
percyng is offline   Reply With Quote
Old 06-26-2012, 12:31 AM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
PSX24W as stated above.. it is in the manual after all
There are LED setups available and cheap HIDs.. the bulbs run at a lower wattage and high wattage bulbs could melt the housings.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-26-2012, 01:11 AM   #5
Silver Bullet BRZ
Silver Bullet BRZ's Avatar
This is a situation where I would love to get the fog lights to match the headlights in color.
"The Silver Bullet" / 2013 Subaru BRZ Limited / Sterling Silver Metallic
Silver Bullet BRZ is offline   Reply With Quote
Old 06-26-2012, 02:55 AM   #6
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Aww, so much for upgrading the bulbs with slightly whiter color and more output. I hear these lamps are cheap plastic and can't handle much. At least they're grams lighter, use less energy, and last longer... -_-
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 06-26-2012, 08:27 AM   #7
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm still considering putting HIDs in them :P I am worried about the housings a bit though.
Or I could do LEDs.. unfortunately I want them to function still but I also would like for them to match the color of the headlights. I have no idea if the LED bulbs I've seen are really functional or not.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-26-2012, 08:33 AM   #8
Bristecom
Bristecom's Avatar
Well HID's still get pretty hot. LED's would work but then they'd drop the lumen output quite a bit and end up being mostly cosmetic. Oh well, I guess I'll just stick with the stock bulbs.
Toyota + Subaru =
Old 06-26-2012, 08:34 AM   #9
DantKR
Drives: Subaru BRZ LT
I hate when people roll around with fog lights on. Looks stupid. Also, they're useless. The car rides so low anyways when you have them on they show about an inch more light on the ground than the normal lights.
DantKR is offline   Reply With Quote
Old 06-26-2012, 09:00 AM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I leave them on because the car looks better with something on the bottom. If the DRLs stayed on I'd have them off, but just to two headlights and no other markers just looks strange to me.
I agree they are functionally worthless.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-26-2012, 09:05 AM   #11
DantKR
See, I disagree, I prefer the look of just head lights. I think it looks silly and spiderish with 4 lights on.
Old 06-26-2012, 09:07 AM   #12
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
On dry days they are useless. (Personally, I like the look so I keep them on. As you pointed out, they're aimed at the ground so they don't blind.) But the reason why they're aimed so low is because on wet foggy days the light is designed to bounce off the wet pavement and illuminate signs further down without reflecting back off the fog ahead and into the driver's eyes. Like low beams vs high beams in the fog, but even lower.
I want to change the color of the bulb too, but it's a hard one to match. I haven't found a reliable source for LEDs, and I can't get confirmation that HIDs (H16 conversion) wouldn't melt it. The other option would be to replace the foglight entirely with a pair of Hella aftermarket fogs (Micro DE or similar).
Old 06-26-2012, 09:43 AM   #13
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
I leave mine off unless it's foggy. I plan to wire up the rear red fog light to the same switch.
boarder1995 is offline   Reply With Quote
Old 06-26-2012, 10:46 AM   #14
DeepHunta
Drives: '05 Outback Wgn, '05 Lotus Elise
I couldn't find any PSX24W online but the equivalent of it is a 9009 bulb. I wanted yellow bulbs for my fogs so I went with a 9009.
BUT BE WARNED: there are some DIY on the 9009 bulb to make it fit into the BRZ fog lamp housing. Pretty simple though. I was able to chip off the extra plastic flaps with a flat head.
Also, I'm not sure if 9009's will fry my wirings. The output is 55W compared to the 24W that is stock. So far no fires on the car
Proud ex-owner of GBS 6MT BRZ Limited. Pre-ordered on Feb-29-2012, got VIN on 5/19 with ETA 6/6, arrived early on 6/2, but still didn't pick it up until Jun-6-2012. Recently sold the Buuurz as of 4/21/2014
DeepHunta is offline   Reply With Quote
BRZ LED Strip in Headlights (bulb) R0ME0 Cosmetic Modification (Interior/Exterior/Lighting) 15 05-26-2014 11:57 PM
BRZ Stock HID Bulb Info - D4S kanundrum Cosmetic Modification (Interior/Exterior/Lighting) 9 10-05-2012 10:55 AM
BRZ D4S bulb ? MRZ415 BRZ First-Gen (2012+) — General Topics 82 06-28-2012 07:18 PM
BRZ signal light bulb ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 8 06-20-2012 01:26 AM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 12:34 PM
