Old 09-10-2012, 07:43 PM   #1
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
BRZ HID Bulb Swap
Has anyone done a bulb swap on their BRZ ? Couldn't find any info in DIY section
UPDATE: Figured it out for anyone thinking of changing bulbs. There are two small retention clips on either side of the bulb. Just push these forward and up toward the bulb and this will allow you to pull the bulb plug assembly outward towards the engine bay. Remove bulb and replace with desired bulb. Reverse steps to reinsert. Done
There's a bit of a learning curve when re-attaching the retention clips. Took me 20 minutes to figure it out, second one took me a minute or so once I got my head around it. Take your time to examine the clips before removal and re-attaching, refer to other HID if you need too. Also pay attention to bulb installation as there are two small notches on the bulb plug, one is rectangular and the other is half moon shaped. Make sure that the rectangular opening is too the top of the bulb plug as it fits over a metal or plastic tab when reinserting plug
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following User Says Thank You to JPxM0Dz For This Useful Post:
kevinnivek8877 (09-28-2012)
Old 09-10-2012, 07:47 PM   #2
GregV
Drives: Kia Stinger GT2
Check the owners manual on replacing bulbs? HIDs are standard, what's there to replace them with?
GregV is offline   Reply With Quote
Old 09-10-2012, 07:50 PM   #3
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Done that, manual refers HID bulb replacement to be done by Subaru dealer. At least from what I could see
I'm swapping out the stock bulbs for some 4DS Philips 6000K
2URGSE
SkAsphalt (10-01-2012)
Old 09-11-2012, 12:56 AM   #4
michael317
michael317's Avatar
Drives: BRZ Limited
if you are looking for the what type of hid bulb in our car it is 4DS. its in our owners manual if you look under specifications
michael317 is offline   Reply With Quote
Old 09-11-2012, 10:08 AM   #5
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Nope sorry, I knew that and I have the bulbs in hand. My question was, has anyone done a bulb swap yet as I was curious about the clamp mechanism within the HID assembly and how easy it was to remove and replace bulb
Thanks
2URGSE
Old 09-11-2012, 04:04 PM   #6
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
No one's done this ?? Wow, guess I'll be the first LOL
2URGSE
Old 09-11-2012, 04:41 PM   #7
speed6sam
Drives: SWP BRZ Limited 6 Spd
Factory light output has been absolutely fantastic for me so I have had no need to change it.
speed6sam is offline   Reply With Quote
Old 09-11-2012, 05:03 PM   #8
jskurucz
Yep!
jskurucz's Avatar
Drives: 2015 WRX Sti
The bulbs SHOULD be a direct fit. My old Rx8 had stock HID and the bulbs were a direct fit. As long as it's the same size you won't have a problem. The reason it says dealer is because the risk of electrocution.
jskurucz is offline   Reply With Quote
Old 09-11-2012, 05:31 PM   #9
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Yeah I realize that, my question was more inline with the clamp mechanism that holds the bulb in place. I didn't wanna toy with it too much until I had an idea how the bulb plug is removed.
2URGSE
Old 09-11-2012, 05:36 PM   #10
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Yeah I found the output very good also, however I also swapped out foglamp bulbs for CREE SMD w/6000k temp and wanted to match it up nicely with my HIDS
2URGSE
Old 09-11-2012, 10:04 PM   #11
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Sent from my GT-I9300 using Tapatalk 2
2URGSE
Old 09-11-2012, 11:12 PM   #12
jpit
Drives: Subaru BRZ
Does anyone know the temp of the OEM HID bulbs. Most OEM are 4300K (provides maximum output) but these look a little whiter - maybe 4800K?
jpit is offline   Reply With Quote
Old 09-12-2012, 09:21 AM   #13
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
4300k
2URGSE
Old 09-28-2012, 10:34 AM   #14
kevinnivek8877
thanks. I was thinking about doing this. make a DIY with pics!
did you unplug the battery before doing this?
kevinnivek8877 is offline   Reply With Quote
Fog light bulb size? huma Cosmetic Modification (Interior/Exterior/Lighting) 19 01-22-2015 05:57 PM
BRZ Stock HID Bulb Info - D4S kanundrum Cosmetic Modification (Interior/Exterior/Lighting) 9 10-05-2012 10:55 AM
bulb size for frs brichard0625 Exterior Parts - The Rest 4 07-23-2012 03:33 PM
which H11 replacement bulb 7thgear Cosmetic Modification (Interior/Exterior/Lighting) 13 07-18-2012 10:23 AM
BRZ D4S bulb ? MRZ415 BRZ First-Gen (2012+) — General Topics 82 06-28-2012 07:18 PM
