Old 09-06-2012, 10:47 PM   #29
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Originally Posted by michael317 View Post
So i have seen a lot of debate on this and i would like to end it! so what type of source would you like ? would you like me to video tape for about 100 miles and put it up to say that these sensors DO NOT require rotation? Like i stated before this is not your subaru system its a toyota system..... the pipe bomb method will not work due to the fact that you need 30PSI (pound per square inch. ) you can throw those sensor in the pipe hook up the scan tool and i can bet you that the light is on because there is not enough pressure in it. unless you make a decent size one. BUT if the sensor see 30 psi or more in that pipe then your light will be out. You can go on the nasioc forum and ask them how fast does the tpms light come on if they dont have their sensors. i will bet you they will tell you within 10 miles. why? Because i have a 2011 legacy GT with aftermarket wheelsthat i did my research on how to fool the system. you cant becuase it need rotation. BRZ is using toyota system which does not require rotation. Like i said... me being a subaru tech for 5 year and now a lexus tech for the past 6 years on my 7th now dont have much credit to your knowledge and i have no clue what i am talking about right? The reason i bought this car is because its the best of both worlds to me. only thing i cant access on my brz through my lexus tech stream is smart access because scion do not offer that option. BUT i can do everything else including looking up TSIBs, shop manual. I am here on this forum to share what i have found useful and i think i have enough experience to back me up. I am so confident because i have throw my set of tpms sensor into my spare knowing that i dont plan on using my spare and if i do oh well... the sensors break and i can fix it. BUT i do know is that i dont have a TPMS light and i have driven my car 50miles already more around 60miles to be exact. I will anti up.... IF you still dont think my theory works... fly over to NY.... i will drive you around for a few days... if during the time of your stay my light comes on i will cover your airfare and your stay at the hotel of your choice for the time you are here. BUT if the light stays off.... then that trip will be out of your own pocket...
how bout that?
cheers everyone
Whoo there, relax... Take a breath...
If you had just said that yes you have put them in your spare and it's working that would have been enough for me.
The only reason some of us were questioning it is because way to many people have been stating speculation, or opinion as fact without having done it themselves, or being able to site there source.
If you've acutally done it I'm good with that. May I suggest doing a separate thread with a good write up on what you did and how? That may help put this issue to rest.
The Following User Says Thank You to neutron256 For This Useful Post:
xjohnx (09-06-2012)
Old 09-06-2012, 10:56 PM   #30
jdmitr
jdmitr's Avatar
Drives: BRZ Limited - '85 Corolla GTS coupe
REALLY GUYS???? Did none of you read my post? NO tpms light...PERIOD with my wheels and tires installed and the sensors are no where near the car with over 1500 miles with all sorts of driving. Vsc and all works and deactivates like it should!
2013 Subaru BRZ - Satin White Pearl 6mt - HKS v3 GT Supercharger running 93 octane at 270whp -
1985 Toyota Corolla GTS coupe - F20c swapped
BK Industries
jdmitr is offline   Reply With Quote
Old 09-06-2012, 11:10 PM   #31
jdmitr
jdmitr's Avatar
They bill this car as being a driver's car and from day one since we have seen the near completed car they have bragged about being able to put 4 wheels and tires in the car to haul to autox and track days. Dont you think they would want to make it so some how when you put wheels on at the track that dont have sensors and still be able to use the functions of vsc etc? That would be really dumb if they hyped driving it at the track and have you get there and not be able to use the functions critical to what type of driving your doing!
BK Industries
The Following User Says Thank You to jdmitr For This Useful Post:
davesrave (09-12-2012)
Old 09-06-2012, 11:28 PM   #32
neutron256
neutron256's Avatar
You are the exception. There are several people on here who have changed to wheels without sensors and had the light come one. Some right away, some took a while.
Some who don't want to pay for sensors are in need of a work around, and that's what threads like this are about.
Old 09-06-2012, 11:35 PM   #33
camelflage
Drives: pinto power
open cluster, remove bulb, no more light. problem solved.
camelflage is offline   Reply With Quote
The Following User Says Thank You to camelflage For This Useful Post:
artizhay (09-06-2012)
Old 09-07-2012, 12:45 AM   #34
jdmitr
jdmitr's Avatar
I briefly looked for a poll on this. Maybe someone should start a "poll" to include anyone with aftermarket wheels. We should have them post:
Model/package if applicable (premium/limited): BRZ Limited
Transmission: MT
Build date: 4/12
Experiencing problems without sensors in the car: No
- If "yes" explain experience and how many miles until issues:
- If "no" then how many miles without issues: 1500 mi
By getting as much info as possible we may be able to get some insight on if it is a build date or model difference as to why some have issues some don't and sticky it!
BK Industries
Old 09-07-2012, 03:02 AM   #35
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
I have aftermarket wheels without the TPMS's in my car. If I drive around town for a short drive, the light doesn't come on. If I do a longer drive, the TPMS light blinks and then goes solid.
I need to do more testing, but it seems like once the light comes on, then the next time I start the car, the light will automatically blink and then stay solid...even if my next drive is a short one. However, once I park back in my garage near the stock wheels with TPMS's in them, I THINK the light reverts back to OFF until I do another long drive. If this is right, which I believe it is, then michael317 seems correct that rotation is not required for our TPMS's.
Phaedrus29 is offline   Reply With Quote
Old 09-07-2012, 08:39 AM   #36
HunterGreene
Hail Magnet
HunterGreene's Avatar
Holy crap, someone has experience driving on the Toyota system!
I have had a similar experience for the past six years driving my tC, when I would swap my summer tires for my snows (the snows had the original rims and the TPMS system). The light would normally not come on on a daily commute/short drive. Any time I went on a longer road trip, the TPMS light would come on as described above.
Based on my real-world experiences (and some of the posts in this thread) and since the twins' TPMS system is a Toyota system, I am almost completely sure that the sensors won't require rotation to report normal operation.
Old 09-07-2012, 03:21 PM   #37
RavSpec
Drives: Rx7
Just confirmed ... Using OP method, we are able to keep the TPMS light off.
So confirmed BRZ/FRS doesn't use rotational type sensor like the Subaru STI / Legacy.
RavSpec is offline   Reply With Quote
The Following 2 Users Say Thank You to RavSpec For This Useful Post:
HunterGreene (09-07-2012), neutron256 (09-07-2012)
Old 09-07-2012, 04:46 PM   #38
jeebus
here's the thing though...
If you are willing to throw the TPMS into the spare (there by making the spare totally unusable), you might as well just build a TPMS bomb and take your spare out.
jeebus is offline   Reply With Quote
Old 09-07-2012, 05:54 PM   #39
RavSpec
Drives: Rx7
Just need to make sure TPMS bomb can pressure at least 30 PSI.
Old 09-07-2012, 06:07 PM   #40
empower-auto
Kouki-Monster
empower-auto's Avatar
these do not require rotation. I deflated my tire. the sensor tripped. I inflated it, the light turned off. No rotation in the sequence.
I hated the idea of TPMS before I had them ... now I like them. I get a heads up when pressure is low. It also alerted me to having a screw stuck through my tire before I drive around and wrecked something.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 09-07-2012, 06:59 PM   #41
neutron256
neutron256's Avatar
I agree that they dont need rotation now that several people have tested it. Your test however is a little flawed. A rapid change in pressure will cause the sensors to immediately transmit. This is so you know if you've had a blowout or your tire is quickly going flat. Apparently some people can't tell which is why the safety nazis required TPMS in the first place.
Old 09-07-2012, 07:34 PM   #42
Phaedrus29
Phaedrus29's Avatar
UPDATE: OK interesting experience today...I had the TPMS light yesterday after a long drive. Last night, I parked in my garage right next to the stock wheels. To my surprise, this morning the TPMS light started in the ON position, even though I was parked next to my stock wheels.
When I got back to my garage, I left the car running next to the stock wheels for one minute and the light went OFF!! I turned off the car and restarted and the light was in the OFF position. So I can confirm 100% that rotation is not required. You just need to make sure that you have your car running for at least 1 minute near the stock tires to reset the light back to OFF. Hope that helps!!
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 10:17 AM
Blocking Your TPMS Light DarrenDriven DIY (Do-It-Yourself) Guides 77 03-29-2017 11:18 PM
Update on TPMS - No light without sensors! trueno86power Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 05-11-2014 03:45 AM
TPMS warning light **New Info** sdiver68 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 10-11-2012 07:25 PM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
