Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 09-03-2012, 02:17 AM   #15
davey90
Akina Speed Stars
davey90's Avatar
Drives: White 86 GTS Auto [CID- ***]
Send a message via Yahoo to davey90
Originally Posted by Matthung View Post
mine stays where is left off .....however i have another problem....
when it goes from track 1 to track 2 i get one of three scenarios:
1. it moves to the next song fine
2. it does a read index thing ....
3. it stops all together.....
any ideas ?
Originally Posted by Nardi330 View Post
this happens on mine randomly as well. i just need to select another song via "search" and seems to be ok again.
have you checked to see if the mp3 file on the USB works on a PC or another device like mp3 stereo or TV with USB ports?
if it does play then maybe the unit in the car can't read something embedded inside the mp3 file? (just taking a shot in the dark)
davey90 is offline   Reply With Quote
Old 09-03-2012, 03:07 AM   #16
dangerfield
dangerfield's Avatar
Drives: Toyota 86 GTS 6AT (Tornado Grey)
Originally Posted by davey90 View Post
(off topic) Just want to add that the GPS is so slow! Example, when you're making the left turn or just made the left turn, the GPS will go "turn Left on to blah blah road". I'm like "wtf? I already did that..."
I don't think the GPS was programmed to keep up with drifting around corners :P
dangerfield is offline   Reply With Quote
The Following User Says Thank You to dangerfield For This Useful Post:
davey90 (09-03-2012)
Old 09-03-2012, 04:16 AM   #17
Eightsex
Eightsex's Avatar
Drives: 86(soon!), JZX100
Originally Posted by nzer View Post
Any GT owners in Oz that can see if your head unit is the same as ours in kiwi-land and if it is do you have the same USB going to the first track after power off?
Yeah mine is GT spec and I can confirm that it does the same thing, getting sick of going through the song list every time I turn off/turn on car...argh another first world issue??? lol
Eightsex is offline   Reply With Quote
The Following User Says Thank You to Eightsex For This Useful Post:
nzer (09-03-2012)
Old 09-03-2012, 04:57 AM   #18
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Damn, that means our top spec car has the same stereo as your GT. Oh well.
nzer is offline   Reply With Quote
Old 09-03-2012, 05:05 AM   #19
Panman
Panman's Avatar
Drives: 86 GTS
Other way round, I think it's _always_ expecting you to be drifting.
Panman is offline   Reply With Quote
Old 09-03-2012, 06:20 AM   #20
nzer
nzer's Avatar
Damn it. Works fine with a burned MP3 disc. Starts from where you left off after powering off the car. Looks like it's a problem with just the USB system.
I'll ask Toyota if there's a software upgrade that might fix it.
Thanks for all your help everyone.
Old 09-03-2012, 07:45 AM   #21
Nafe
Nafe's Avatar
Drives: Mt Fuji Red 86 GT
I haven't used the usb input yet, but that sounds annoying. So far I have grudgingly used Bluetooh stream. While the quality isn't great, I have never had bluetooth streaming so at the moment it is a novelty lol
Nafe is offline   Reply With Quote
Old 09-03-2012, 08:17 AM   #22
Nardi330
Nardi330's Avatar
Drives: 86
For those with the GTS, do u use the USB port on the head unit or the one on the dash?
I can only get the one on head unit to play songs.
Nardi330 is offline   Reply With Quote
Old 09-03-2012, 08:42 AM   #23
davey90
Akina Speed Stars
davey90's Avatar
I've yet to try the USB port next to the AUX in port. I've only tried the one on the head unit. from your post it seems like the USB port next to the audio port is power only for recharging phones or docking apple stuff (read it some where in the manual).
Old 09-03-2012, 09:18 AM   #24
Nardi330
Nardi330's Avatar
Drives: 86
I haven't tried pluging in my iPhone into the USB port on the dash. Maybe I should.
Old 09-03-2012, 09:22 AM   #25
proficience
proficience's Avatar
Drives: Velocity Orange 86 GTS M/T
Nope, both are fully functional usb ports for data and charging.
I have been using the one near the centre console aux thingo, not the one on the headunit, works exactly the same as the headunit one
proficience is offline   Reply With Quote
The Following User Says Thank You to proficience For This Useful Post:
Old 09-03-2012, 11:38 PM   #26
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
Have you tried another flash drive with different music on it? Also did you "eject the flash drive" from the computer or just remove it? Had a few issues myself of late because I hadn't "safely removed hardware". Had to format my drive & put the music back on.
Not sure playlist will work via usb either. I'd take it back to the dealer if the problem persists.
SXE10 is offline   Reply With Quote
Old 09-03-2012, 11:46 PM   #27
Skorov
Skorov's Avatar
Drives: 86 GTS White
In the day that I've had my car, I've already noticed some HU bugs.
1. In the USB menu I switch to Video Mode. It starts to index my USB, gets to 5%, then the software crashes and needs to reboot the HU. After reboot it AGAIN tried to index. And this cycles forever. (I had to quickly switch it back to Audio Mode)
NOTE: This might be due to the large video files on my flash drive, but still. Power cycling is not really acceptable as a "release" product. I might have to call up and see if this is a known issue.
2. Cannot play m4a files (I know they are rubbish anyway). Trying to play one will result in USB playback freezing in such a way that nothing is playing, and switching to another track does not work. It will continue to try to play the m4a file until you actually delete it from the flash drive.
Skorov is offline   Reply With Quote
Old 09-11-2012, 11:36 PM   #28
nzer
nzer's Avatar
Further to the original post.
Toyota no help so contacted Fujitsu Ten, the manufacturer.
They responded - "What you are experiencing on USB playback is normal operation. There is a difference between CD and USB however this is the specification of the unit."
And, when I asked it there was a firmware upgrade to fix it they responded - "No, not at this stage. Should there be any changes in the future though, your dealer will be your best contact."
So, looks like other than upgrading the head unit this is an issue that can't be solved.
Music Artwork? serith Electronics | Audio | NAV | Infotainment 4 08-25-2012 01:29 PM
Music with Obama Silverdub Off-Topic Lounge [WARNING: NO POLITICS] 1 07-25-2012 01:03 AM
classical music anyone? serialk11r Off-Topic Lounge [WARNING: NO POLITICS] 20 04-07-2011 03:08 AM
The Music Thread aliphian Off-Topic Lounge [WARNING: NO POLITICS] 13 03-28-2011 12:35 PM
