Old 08-29-2012, 03:07 AM   #43
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Ps. An offset of +20 would be pushin it. Stay 8.5/9.5 30 -38
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 08-29-2012, 11:32 AM   #44
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
@DarrenDriven - Useful site for those interested in what a stretch will look like on their wheel widths. It shows about every combo you can think of and also within each category it breaks down by tire make. Might want to add to useful links.
http://tyrestretch.com/
digital_assassin is offline   Reply With Quote
Old 08-30-2012, 11:46 AM   #45
Delacruzmd
Drives: SSM BRZ
Looking to purchase 18x9.5 et38 all around. I was hoping to go 245/35 with a 1.5 drop and some neg camber. Is this going to work or should i go square 225/40 or staggered 225/40 in the front. Application is mostly daily driver, inputs appreciated.
Delacruzmd is offline   Reply With Quote
Old 08-30-2012, 01:29 PM   #46
ill86
ill86's Avatar
Drives: iG FR-S
If it were me I wouldn't stagger.
What kind of tire are you looking for?
Do you want to stretch a tire with 225 on 9.5?
Old 08-30-2012, 02:09 PM   #47
gmookher
My m3 is staggered, the 911 is also, but I dont think there is any benefit to staggering wheels on the brz. Why do you want to stagger aside from it looking cool? Do you feel too much turn in? is the tail coming around on you?
Old 08-30-2012, 02:56 PM   #48
Delacruzmd
Drives: SSM BRZ
I actually want to go 245/35 squared thus the inquiry if this setup would fit if lowered at 1.5. The other options were if that setup wont work.
Old 08-30-2012, 06:09 PM   #49
joso808
Drives: '13 FR-S (eventually :D)
I want to get 18x8 +45 front and 18x9.5 rear. Tire rack says it'll fit but star specs don't come in the recommended size of 235/35 but they do come in 235/40. Recommended size for the rear is 255/35 however star specs do come in that but not 255/40. My question is will the difference in sidewall height cause a problem or not? Thanks in advance
joso808 is offline   Reply With Quote
Old 08-31-2012, 12:00 AM   #50
ill86
ill86's Avatar
Drives: iG FR-S
It all goes by overall diameter. You do not have to match up the sidewall numbers. Sorry if i am misunderstanding your question.
Based on this: http://www.dunloptires.com/en-US/tir...starspec-tires
I would choose:
225/40 fr, 255/35 rr
Or
235/40 fr, 265/35 rr
Old 08-31-2012, 12:11 AM   #51
ill86
ill86's Avatar
Drives: iG FR-S
For an 18x9.5 the 245/35 is a better match imo. 225/40 is a bit of a stretch.
Old 08-31-2012, 01:01 AM   #52
whateatsrabbits
whateatsrabbits's Avatar
Drives: 2013"Road scalpel"FR-S MT
Question for the professional. I am looking to get some snow tires, I want my contact patch to be the same as stock but narrower in order to cut through the snow. DO 15 inch wheels clear the brakes on our car? I would prefer to put a 15 but I can go with a 16.
Picture of equal contact patches.
Say the tire on the right is stock, What size is the one on the left?
What size wheel and tire do I need to buy? Would a 185/65/15 do the trick? On a 6 inch wide wheel sound good?
NEVER LIFT
Originally Posted by Grishbok View Post
The 86 is a precision car, it does not compensate for driver error, on the road or on the track. This is the kind of car thats created to be the surgeons scalpal of the mass-consumer car world, not a drag car.
whateatsrabbits is offline   Reply With Quote
Old 09-04-2012, 12:35 PM   #53
thelegaCy
Drives: cbs brz limited - RIP
Guys would a 17x9 +35 on the stock tires be unsafe? I don't want to waste my stocks... is that too much stretch?
thelegaCy is offline   Reply With Quote
Old 09-04-2012, 02:50 PM   #54
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
That's a LOT of stretch. I'd only consider 8.5 max for a normal 215 tire, whereas our stock 215's are a narrow version. 8 to be safe, 8.5 rim for stock 215 would be max safely in my book.
boarder1995 is offline   Reply With Quote
Old 09-04-2012, 11:22 PM   #55
Bomb3r
Bomb3r's Avatar
Drives: Australian GT86
I had 215's on 9in VSKF's and the stretch wasnt excessive stretch.
Bomb3r is offline   Reply With Quote
Old 09-06-2012, 11:18 AM   #56
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Hey guys would 18x9.5 +45 all around with 235/40/18 tires fit? Stock height, planning to lower soon.
Thanks
shu5892001 is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
