Old 08-27-2012, 08:26 AM   #1
itdansharpe
itdansharpe's Avatar
Sub + Amp Questions
Hi guys, looking for advice on a couple of things. Love the stock look when it comes to sound systems. I ordered an amp that will fit in the trunk in the top right corner under the carpet if I cut out a section of foam... as seen on other threads.
Couple quick questions!
1. Where's the best location to run the power line from the battery through the firewall?
2. Does anyone know if the upgraded FR-S HU has a trigger (turn-on) wire? If not, could it be run off the amp in the back? (I'd almost prefer to do that anyway since it is closer.)
3. Lastly, I'd love to hear from guys who've already done this... are you running power up the right side of the car and RCA'S up the left?
Just picked up my car last Friday... what a machine!!!
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 08-27-2012, 11:57 AM   #2
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
1. Grommet on passenger side, do a search, my thread has pics too I believe.
2. The amp in back has a remote wire, check the service manual for a full breakdown.
3. Power on passenger side, speakers and rca's on the driver side. I think everyone has done it that way so far. All on the floor too, don't know that anyone has gone through the pillars...
michaelahess is offline   Reply With Quote
Old 08-27-2012, 12:30 PM   #3
Plxdjake89
Plxdjake89's Avatar
Drives: 2013 Scion FR-S-white out
If you look on the drivers side of the car, you will see a grommet there as well, get some scissors And cut of the nipple looking piece. That's where I fed my power wire
Plxdjake89 is offline   Reply With Quote
Old 08-27-2012, 01:22 PM   #4
itdansharpe
Thanks for the quick response guys! Appreciated. As for the remote wire off the amp: Here's a diagram of the amp from the service manual. I'm don't fully understand what is going on, but I don't see a line out for it, unless you are referring to AMP?
Old 08-27-2012, 01:59 PM   #5
Plxdjake89
Plxdjake89's Avatar
That would be it
Old 08-27-2012, 02:00 PM   #6
Plxdjake89
Plxdjake89's Avatar
I did mine from behind the head unit itself, just tapped into one of the 12v wires.
Old 08-27-2012, 02:15 PM   #7
cnk
Drives: '13 DGM BRZ Limited
You tapped the 12V from behind the HU for your amp? If so, that's a big no-no. You should be taking 12V directly from the battery with a fuse inline. You run the risk of drawing more power than the wires to the HU are able to support and causing a wire to melt or worse, a fire.
Old 08-27-2012, 02:16 PM   #8
itdansharpe
I'll see if I can get power off the rear amp otherwise I'll do the same as you and run it off the HU. Although, it makes sense to run it off the rear amp for obvious reasons: less wiring = big weight savings = faster 1/4 mile times. Wires are heavy! ha ha...
Old 08-27-2012, 02:16 PM   #9
itdansharpe
We are talking about the trigger wire.
Old 08-27-2012, 02:19 PM   #10
Plxdjake89
Plxdjake89's Avatar
Correct, I can't remember which wire it was off the top of my head, but I can help once I get home. I believe it was a red cable with a white stripe. Anyway, I believe if you tapped into the green wire on that amp in the rear, it would pretty much be the same difference.
Old 08-27-2012, 02:22 PM   #11
cnk
Good to hear. Just making sure. Didn't want someone to be posting up that their car burned down.
Old 08-27-2012, 02:30 PM   #12
Plxdjake89
Plxdjake89's Avatar
Lol, seriously. I knew a kid who had this 20th gti....burned down to the ground.
Old 08-27-2012, 03:00 PM   #13
Foobar
SLO NO MO
Foobar's Avatar
Which pin on the stock amp carries power? Is it switched with the audio or is it always on with ACC? I'd like to tap into it for a rearview camera if I can, since it's right there anyway.
Old 08-27-2012, 03:13 PM   #14
Plxdjake89
Plxdjake89's Avatar
I believe it's always on with acc, and it should be the green wire
E85 questions Grishbok Engine, Exhaust, Transmission 17 08-08-2012 10:49 PM
Drifting the 86 Questions HATED1 Scion FR-S / Toyota 86 GT86 General Forum 9 07-06-2012 03:31 AM
FR-S NAV Questions Dan86 Electronics | Audio | NAV | Infotainment 6 07-01-2012 02:24 PM
Questions Do Boy Engine, Exhaust, Transmission 4 06-22-2012 02:33 PM
A Few Stereo Questions... BigJyoungblood Electronics | Audio | NAV | Infotainment 1 06-14-2012 07:18 PM
