Old 08-08-2012, 04:33 AM   #1
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
E85 questions
Question for fuel map tuners: The D4 engine under the hood of these incorporate a direct injection fueling system capable of:
240cc DI flow (est)
2.4ms pulse width
Is there a capable tuner able to play with the fuel map to use E-85 with the stock fueling system? It would be conservative to assume we would see an increase, potentially dramatic increase with more aggressive tuning. Is this a safe assumption and possible with the system, or does the added port injection flow rate screw up the potential, why or why not?
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 08-08-2012, 06:39 PM   #2
Crawford
Crawford's Avatar
Drives: 2013 Subaru BRZ
To run E85 you need to increase the fuel flow by at least 60% to maintain the same power level. There is room in the stock system for more power, but not that much.
Team Crawford
Crawford is offline   Reply With Quote
Old 08-08-2012, 06:53 PM   #3
coyote
coyote's Avatar
Drives: Slowly
Whilst I have the greatest respect for some of your company's engineering skills, that figure of 60% is almost double what is actually required.
coyote is offline   Reply With Quote
Old 08-08-2012, 07:33 PM   #4
Allch Chcar
Drives: N/A
^This. While the actual fuel amount varies a bit with each engine and how aggressive/conservative it's tuned, it only needs 39% more fuel for E85.
Just do the math. Ethanol has 67% of the energy of Gasoline. E85 is 85% Ethanol and 15% Gasoline. 1 / (.85 x .67 + .15) = 1.389854065 which means 39% more fuel. Winter blend takes less since it's 70% Ethanol and 30% Gasoline
My guess is Crawford is thinking of pure Methanol. A very common mistake.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 08-08-2012, 07:36 PM   #5
Crawford
Crawford's Avatar
http://horsepowercalculators.net/e85...e85-calculator
They are saying 48%
Old 08-08-2012, 07:59 PM   #6
Allch Chcar
Drives: N/A
That's because they're talking about air:fuel ratio which is measured by Mass and fuel flow is measured in Volume. Ethanol and Gasoline have slightly different mass due to a different composition. The distinctive trait in alcohols is the presence of oxygen. Ethanol is 1/3 oxygen which makes it heavier per gallon than Gasoline.
http://en.wikipedia.org/wiki/Stoichi..._of_combustion
I had to look this is for an easy explanation.
-Allch Chcar
Old 08-08-2012, 08:03 PM   #7
coyote
coyote's Avatar
Drives: Slowly
Please forgive me if that website is some kind of trusted source, but I'm very surprised that a company like Crawford would reference some random url rather than pour some fuel into a car and test for themselves. That's what I've done many, many times with this fuel and can tell you from first hand experience that the figure of 48% is less wrong than "at least 60%", but still wrong.
Old 08-08-2012, 08:08 PM   #8
knapper
knapper's Avatar
Drives: '13 Scion FR-S - Whiteout
So, where did you get 60% from?
And why don't you simply use math and logical reasoning to show what the figures actually are. Not only is your statement misleading for those viewers who may be less than educated about the matter, it's just plain wrong.
Coming from a personal business owner, be careful with what you write. Especially if it isn't first hand information.
knapper is offline   Reply With Quote
Old 08-08-2012, 08:18 PM   #9
coyote
coyote's Avatar
Drives: Slowly
240cc DI flow (est)
2.4ms pulse width
To the OP, I don't know the answers to your questions ... but as soon as I can get my hands on a car I will be attempting to find out.
Old 08-08-2012, 08:34 PM   #10
Allch Chcar
Drives: N/A
How about we start with the easier question of how much fuel flow the stock injectors use and then we can extrapolate the maximum fuel we can run stock.
-Allch Chcar
Old 08-08-2012, 08:37 PM   #11
PRORICAN
PRORICAN's Avatar
I have always thought it was about 30-40% and not 60%.
PRORICAN is offline   Reply With Quote
Old 08-08-2012, 08:45 PM   #12
coyote
coyote's Avatar
Drives: Slowly
If we were just dealing direct injectors or just dealing with port injectors, I agree that it would be easy.
Has anyone been able to log IDC of both sets of injectors through a pull to redline? That could tell quite a lot.
Old 08-08-2012, 08:56 PM   #13
serialk11r
Drives: '06 AM V8V Coupe
When you throw significant amounts of alcohol into the mix you really want as much going through the direct injectors as possible. Best to find out how much fuel you can send through the DI first.
Old 08-08-2012, 09:45 PM   #14
Allch Chcar
Drives: N/A
With E85 in the fuel tank it doesn't matter. Plus you can't swap out the Direct injectors, that I'm aware of. Port injectors are much easier to swap out and much cheaper as well.
-Allch Chcar
FR-S NAV Questions Dan86 Electronics | Audio | NAV | Infotainment 6 07-01-2012 02:24 PM
Oil Change Questions #87 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 06-28-2012 11:06 PM
Questions Do Boy Engine, Exhaust, Transmission 4 06-22-2012 02:33 PM
A Few Stereo Questions... BigJyoungblood Electronics | Audio | NAV | Infotainment 1 06-14-2012 07:18 PM
Drifting Questions Shin Scion FR-S / Toyota 86 GT86 General Forum 56 05-30-2012 07:22 PM
