| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: Some rust bucket
DIY JDM frameless mirror install
You can purchase the JDM frameless mirror from the vendor section or Japanparts.com.
What you'll need: 1. flat head screw driver 2. JDM frameless mirror 3. JDM frameless mirror clip Begin by twisting the base of the OEM mirror clockwise. Make sure you're twisting the mirror base and not the actual mount that sticks to the windshield. Once the mirror is rotated about 45 degrees, slide the mirror down. ![]() Pry out the OEM clip with a flat head screw driver. It should come off relatively easy. Install the JDM frameless mirror clip into the same location. ![]() Install your JDM frameless mirror by reversing your steps. Mount the mirror at about 45 degrees and make sure that the metal clip is hooked onto the mirror base. Push it up about an inch and then rotate it counterclockwise.
#2 |
2 wheel member
Drives: JZA80, 997.1, Taco
How much was the mirror?
#3 |
#4 |
#5 |
NW Region Moderator
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
| The Following User Says Thank You to DarrenDriven For This Useful Post: | roddy (01-23-2014) |
#6 | |
Engineer
Drives: WRB 2022 Subaru Brz
#7 |
#8 |
Engineer
| Toyota Japan 86, FRS, Air Bag, Frameless Mirror, Knee Pad, Sun Visor, Door sill, MOR | nigel-jdmparts | Interior Parts (Incl. Lighting) | 89 | 02-01-2013 04:00 PM |
| Blue Engine Cover & Frameless Rearview Mirror where to buy? | JDM-dono | AUSTRALIA | 19 | 07-26-2012 08:41 AM |
| JDM 86 Mirror Installed on FR-S | Trojan_SC | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 07-25-2012 04:02 PM |
| How to install Homelink mirror? | Grimlock | Electronics | Audio | NAV | Infotainment | 10 | 06-10-2012 06:07 PM |
