| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: ExigeS,M3,S2k,MCpe,MR2T,T4R,Sienna
Using the nut to install the studs then take the nut off as it was used as a tool not as permanent install. Do I have it right? My Engrish is bad.
Current: 19 GT-R[]17 M2[]17 WRX[]14 T4R[]12 NV2500[]07 Exige S[]07 S2k[]05 M3[]03 M3[]02 MCoupe[]94 MR2T[]93 MR2 T[]92 MR2 T[]91 MR2 T[]95 SC400[]
Gone but not forgotten: 04 STI[]05 MR2 Spyder[]04 S2k[]03 IS300[]90 MR2[] |
#16 |
Drives: 1995 Nissan Sentra
#17 |
Drives: Argento FR-S
Id love to see more pics as well!
#19 |
Drives: mitsubishi evo 9
spacers do not ruin the handling, they make handling better by giving your car a wider track!!!. you obviously dont know anything about car set up for racing and autox
#20 |
Drives: BRZ(sold), STI
#21 |
Drives: 2013 hot lava FR-S
by any chance do you know the length of the stock studs and the new studs?
#22 |
Drives: Monkey-butt red FR-S
How did you remove the original ones? Did you drive them out?
#23 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
#24 | |
Even if the sign stays the same - you'll get less suspension bushing compliance, with less toe-out on cornering (read - more understeer) and less stability under braking. So no, it's not just steering feel. How much - depends on #s. |
#25 | |
Corner Junkie
Changing scrub radius by changing the length of the control arms can cause issues. That happens whenever you mess with suspension geometry. But just pushing the wheels out won't change the geometry. Now what will happen is increased off-enter forces on the bearings. Pushing the tire centers out by 15mm may increase bearing wear. |
#26 | |
Under heavy cornering suspension bushings compress. From what I've read about BRZ/FRS suspension, it is designed properly, and bushing compliance gives you toe-out up front when you corner. That compliance depends on the moment of the tire friction force around the (vertical) rotational axis of the strut. Given equal frictional force of the tire, that moment will be affected by the force couple, which will change more or less in line with scrub radius. So if you change the scrub radius, you also change the friction force moment, ergo you change the amount (or, in extreme cases, the direction) the suspension bushings dynamically compress under cornering, hence less toe-out. And again - this is all about dynamic alignment, not static angles. |
#27 | |
Corner Junkie
#28 |
Drives: subatoy
can you take some good pictures?
| 225/45/17 on stock 7" wheels? | ubersoph | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 04-09-2014 04:59 PM |
| Which 18" wheels will weigh the same or less than the stock wheels? | mickey177 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 32 | 05-16-2013 03:07 PM |
| SiriusXM installation to stock Scion FR-S unit | tonystewart | Electronics | Audio | NAV | Infotainment | 9 | 07-17-2012 08:10 PM |
| Aftermarket wheels on stock BRZ/86s | yajin | BRZ Photos, Videos, Wallpapers, Gallery Forum | 2 | 05-01-2012 02:52 AM |
| Why can't the BRZ GT300 or factory BRZ wheels have flush fitment? | switchlanez | BRZ First-Gen (2012+) — General Topics | 43 | 03-19-2012 12:50 PM |
