Old 07-21-2012, 04:12 PM   #15
Mr. Mcoupe
Mr. Mcoupe's Avatar
Drives: ExigeS,M3,S2k,MCpe,MR2T,T4R,Sienna
Using the nut to install the studs then take the nut off as it was used as a tool not as permanent install. Do I have it right? My Engrish is bad.
Current: 19 GT-R[]17 M2[]17 WRX[]14 T4R[]12 NV2500[]07 Exige S[]07 S2k[]05 M3[]03 M3[]02 MCoupe[]94 MR2T[]93 MR2 T[]92 MR2 T[]91 MR2 T[]95 SC400[]
Gone but not forgotten: 04 STI[]05 MR2 Spyder[]04 S2k[]03 IS300[]90 MR2[]
Mr. Mcoupe is offline   Reply With Quote
Old 07-21-2012, 04:26 PM   #16
StevenEngage
StevenEngage's Avatar
Drives: 1995 Nissan Sentra
Originally Posted by vividracing View Post
Matt who posted for me above was talking about seating the new wheel stud. Not using washers to space the wheels. That would be really bad.
THANK GOD you cleared that up lol, for a while there I was thinking good god people are going to shun them instantly.
StevenEngage is offline   Reply With Quote
Old 07-21-2012, 08:06 PM   #17
philstar
philstar's Avatar
Drives: Argento FR-S
Id love to see more pics as well!
philstar is offline   Reply With Quote
Old 07-21-2012, 08:19 PM   #18
dsgerbc
Drives: BRZ(sold), STI
Congrats on ruining your handling.
The Following User Says Thank You to dsgerbc For This Useful Post:
F3dzo (08-14-2012)
Old 07-21-2012, 08:46 PM   #19
adamturbo
Drives: mitsubishi evo 9
spacers do not ruin the handling, they make handling better by giving your car a wider track!!!. you obviously dont know anything about car set up for racing and autox
adamturbo is offline   Reply With Quote
Old 07-21-2012, 08:52 PM   #20
dsgerbc
"Scrub radius", google it.
The Following 2 Users Say Thank You to dsgerbc For This Useful Post:
ImAwesome (11-17-2012), Stu baru (09-07-2012)
Old 08-02-2012, 12:35 PM   #21
FRS8SIX
Drives: 2013 hot lava FR-S
by any chance do you know the length of the stock studs and the new studs?
FRS8SIX is offline   Reply With Quote
Old 08-13-2012, 03:28 PM   #22
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
How did you remove the original ones? Did you drive them out?
Evil86 is offline   Reply With Quote
Old 08-13-2012, 03:51 PM   #23
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
"Scrub Radius" has become an evil term to decry low offsets and spacers. The thing is, it isn't all that bad. It will make the steering heavier and kill some of the feel, but that's about it.
Old 08-13-2012, 04:08 PM   #24
dsgerbc
Effects depend a lot on what the OEM scrub radius is. If you manage to change the sign of this radius (I haven't seen any actual info on the OEM radius) - the effects will be quite a bit beyond what you described.
Even if the sign stays the same - you'll get less suspension bushing compliance, with less toe-out on cornering (read - more understeer) and less stability under braking. So no, it's not just steering feel. How much - depends on #s.
Old 08-13-2012, 04:51 PM   #25
Draco-REX
Corner Junkie
Draco-REX's Avatar
Changing how far out the wheel is from the hub, while keeping the hub in its original location will not change any of the angles. A 1 degree change of toe at +48 offset is still 1 degree of change at +33 offset.
Changing scrub radius by changing the length of the control arms can cause issues. That happens whenever you mess with suspension geometry. But just pushing the wheels out won't change the geometry.
Now what will happen is increased off-enter forces on the bearings. Pushing the tire centers out by 15mm may increase bearing wear.
Old 08-13-2012, 06:20 PM   #26
dsgerbc
You're talking static, I'm talking about dynamic.
Under heavy cornering suspension bushings compress. From what I've read about BRZ/FRS suspension, it is designed properly, and bushing compliance gives you toe-out up front when you corner.
That compliance depends on the moment of the tire friction force around the (vertical) rotational axis of the strut. Given equal frictional force of the tire, that moment will be affected by the force couple, which will change more or less in line with scrub radius.
So if you change the scrub radius, you also change the friction force moment, ergo you change the amount (or, in extreme cases, the direction) the suspension bushings dynamically compress under cornering, hence less toe-out.
And again - this is all about dynamic alignment, not static angles.
Old 08-13-2012, 07:35 PM   #27
Draco-REX
Corner Junkie
Draco-REX's Avatar
Ok, I see what you're getting at. But I think the actual difference in this case is going to be so small that it won't matter. Given time I could come up with the numbers, but I think we're looking at less than a degree difference of the thrust forces against the bushings.
Old 08-13-2012, 08:48 PM   #28
subatoy
subatoy's Avatar
Drives: subatoy
can you take some good pictures?
subatoy is offline   Reply With Quote
225/45/17 on stock 7" wheels? ubersoph Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 04-09-2014 05:59 PM
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 04:07 PM
SiriusXM installation to stock Scion FR-S unit tonystewart Electronics | Audio | NAV | Infotainment 9 07-17-2012 09:10 PM
Aftermarket wheels on stock BRZ/86s yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 2 05-01-2012 03:52 AM
Why can't the BRZ GT300 or factory BRZ wheels have flush fitment? switchlanez BRZ First-Gen (2012+) — General Topics 43 03-19-2012 01:50 PM
