Old 08-11-2012, 11:10 PM   #183
Yruyur
Yruyur's Avatar
Are both of your cars vin numbers less than I posted earlier in the thread? If you don't have the problem but you do have the older ecu you can just ask them to change one if the custom options that are listed on page 369 of your manual. I THINK these settings require the new ecu but have not been able to confirm this yet.
Sent from my PH44100 using Tapatalk 2
Old 08-12-2012, 09:15 AM   #184
Zadkiel
Drives: CBS BRZ Limited 6MT
Do you know if any of this stuff is coming down the pipe as a recall or TSB?
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Old 08-12-2012, 07:36 PM   #185
soconfoozed
Drives: 2013 BRZ Limited 6MT WR Blue Pearl
Add me to the list, 3.5k miles. Between this and crickets...grrr...angry phone call coming your way tomorrow, Subaru!
Edit: you know, this whole experience is really just rubbing me the wrong way. I feel like now that the dealership and thereby Subaru have my money, I'm forgotten. You have to make so much damn noise just to get them to pay attention to you again. I'm not trying to get a free this or a comped that. I just want the god damn car I bought to work as advertised. My end of the bargain is easy to uphold: pay money. Subaru needs to get behind their friggin' product. As a customer service experience, this has been just completely miserable. I could rant for hours and hours about what kind of organizational beliefs and culture lead to this kind of result, but that isn't going to make the crickets or the CEL go away, I suspect.
soconfoozed is offline   Reply With Quote
Old 08-12-2012, 08:06 PM   #186
soconfoozed
And another thing...
Why the hell in an age of multiline displays do we even HAVE a single "check engine" light. That is such a hateful user interface. "Something is wrong. It could be big, it could be small, we give you no indication." Really? REALLY? How about telling me what's ACTUALLY wrong with my car. Assholes.
The Following User Says Thank You to soconfoozed For This Useful Post:
alrashwa (08-12-2012)
Old 08-12-2012, 08:45 PM   #187
NickFRS
Drives: 2013 Asphalt FRS
So there is another thread about a TSB for getting a new ecu to enable a bunch if features on the car like disabling the day time running lights, fixing the cell phone on the passenger seat air bag buzzer issue, changing the horn on setting the alarm opening the trunk with a single click and possibly rolling down your windows on a double click. In the thread it mentions the vin ranges that need to have the new ecu. I think it would be the same vin range that is getting the check engine light.
"if your VIN is above 6034 then you have the new gateway ECU already"
I hope this means that below this range means you have the old ecu. Hope that helps anyone else.
So the last 4 of my vin is 3647.... How would I find out if I have a new or old ECU? Don't want my engine to grenade.... Also what thread had the info about the TSB?
NickFRS is offline   Reply With Quote
Old 08-12-2012, 11:44 PM   #188
oxygen
Drives: 2013 Scion FR-S whiteout MT
I just got that same CEL and slip light today, 2700 miles on car
oxygen is offline   Reply With Quote
Old 08-12-2012, 11:52 PM   #189
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Has any of these codes popped up on a auto yet?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-12-2012, 11:58 PM   #190
Yruyur
Yruyur's Avatar
According to the thread you quoted that I quoted from another thread ... You have the old ecu since you are well below 3647. Do a search to drl tsb that should get you to the thread, I'm driving right now so can't find it.
I wouldn't worry about it grenading. I wasn't, the dealer said the car puts itself into safe mode.
Old 08-13-2012, 01:03 AM   #191
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
What's your last 5 digit VIN #? Sad to hear that man. I'm gettin mine fix starting tomorrow. My service rep told me that it's a two day job and hopefully it is. Did not drive my car for 4 days now and another 2 more days for the fix. Crossing my fingers that that will be it for the issue to be resolved.
tintumz22 is offline   Reply With Quote
Old 08-13-2012, 01:06 AM   #192
tintumz22
tintumz22's Avatar
Yup you can feel that it goes to safe mode when the CEL turns on. The push of the engine that you feel when all things are normal is there but in safe mode you'll not feel that.
Old 08-13-2012, 02:50 AM   #193
siXXtoes
Ohh Snap
siXXtoes's Avatar
Drives: Argento FR-S
my vin is 6645 and i threw a CEL. I had the new ecu and still had issues with the cam. The dealership replace the bad part and ecu.
based on that, i dont believe if u have the old ecu it is the sole issue...
siXXtoes is offline   Reply With Quote
Old 08-13-2012, 03:03 AM   #194
tintumz22
tintumz22's Avatar
There is a newer ECU that relates to the CEL problem specifically based on the posts of the guy who had a fix to his car.
Old 08-13-2012, 09:28 AM   #195
oxygen
My VIN is 00876
Old 08-13-2012, 09:55 AM   #196
brufleth
Drives: 2007 WRX
A number of reasons. First they don't want to overwhelm a driver with too much info. If they had half a dozen lights come on while you're on the highway it could distract to a dangerous degree. This is something that's actually pretty carefully considered by various agencies and the car makers themselves.
Then they also don't want to give just enough information to be dangerous. An engine code may or may not have an obvious sounding cause but even given an obvious name it might be caused by something else. Would you be more or less pissed if you replaced a sensor yourself that an indication seemed to point to and it didn't fix anything?
Another reason is that manufacturers don't want to give away all the information about what's going on in the ECU. If you start getting into the nuts and bolts of what sets a specific code (which would be the next step) they have to tell you more and more about their software. This gets dicey concerning intellectual property and international exports. This is all commercial (non military) so that's not as bad but still can be a pain.
Source: I design and support ECU software for engines.
brufleth is offline   Reply With Quote
My car is in and still 1,304 miles away! joshua BRZ First-Gen (2012+) — General Topics 16 06-28-2012 08:02 PM
Some Miles White_OUT_FR-S Scion FR-S / Toyota 86 GT86 General Forum 0 06-22-2012 02:00 PM
Check Engine Light b.e Scion FR-S / Toyota 86 GT86 General Forum 9 06-17-2012 09:50 PM
Check Engine Light directly after pickup Stu L Tissimus BRZ First-Gen (2012+) — General Topics 27 06-15-2012 05:07 PM
Check engine light code reader FRSCoupe Engine, Exhaust, Transmission 14 06-13-2012 05:06 PM
