Old 10-10-2025, 07:45 PM   #1
Teseo
Drives: frs
ABS Module
I took the car to dealership to diagnose the infamous ABS/Traction control light. The mechanic said it threw
The code C1246, ABS Module.
How often or prone to be defective the ABS Module (SU00305757)?
Old 10-15-2025, 10:52 AM   #2
norcalpb
norcalpb's Avatar
Not that often as far as I know...have you considered just buying a completed, used abs unit from a newer vehicle that has the updated abs control module for track mode?
Old 10-15-2025, 08:01 PM   #3
Teseo
Drives: frs
Yes, I could buy a used module (junkyard?), but wonder what year and if i need to reprogram the system.
Old 10-16-2025, 09:18 AM   #4
smoltz
Drives: 01 911 Turbo, 03 G500
It's pretty much plug and play. First, you need to get a module from a car with the same transmission as you have. Also, if you get a module from a facelift car you'll need to swap a few pins.
Lots of details, part numbers, etc. in this thread:
https://www.ft86club.com/forums//sho...d.php?t=140946
smoltz is offline   Reply With Quote
Old 10-16-2025, 04:29 PM   #5
Teseo
Drives: frs
If I manage to get the module pre-facelift, same transmission...
just plug n play?
Old 10-17-2025, 10:44 AM   #6
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
just plug n play?
Are not able to read or are you bot?
They posted a link with "Lots of details, part numbers, etc."
Click the link.
smackrel is offline   Reply With Quote
2017 abs module on 16 down solidsnake11 Software Tuning 92 04-21-2025 03:30 PM
Used ABS module programming? BPM Software Tuning 19 11-05-2019 10:45 AM
ABS Module specific to transmission type? iiTz-PeRSiaN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 02-08-2018 01:42 AM
BRZ/FRS ABS Module/Pump/Valving Grambi Brakes, Suspension, Chassis 4 08-22-2015 02:59 PM
WTT - 2014 Scion Bespoke Nav Module for Toyota AHA Nav Module Danklvr Audio/Visual, Electronics, Infotainment, NAV 1 09-04-2014 05:57 PM
