Old 04-16-2019, 02:39 AM   #1
BPM
Drives: A Blue One
Used ABS module programming?
Long story short, used abs module is 1/10 the price of a brand new one. Has anyone ever swapped in an ABS module (same part number and comes from a vehicle with the same transmission) successfully onto their 86?
My story:
2013 BRZ Limited MT - malfunctioning ABS module
Will buy another "known" good ABS module from a 2013 BRZ MT.
If you have successfully done this, can you please provide the steps you took in order to get the ABS module to pair with the ECU?
If impossible to do and a new module is absolutely needed, this information is also good to know.
BPM is offline   Reply With Quote
Old 04-16-2019, 07:14 AM   #2
steve99
My story:
You shoukd be fine, not actualky done one myself, but abs module not part of security set so should be plug and play.
To be sure use one from another manual car, i think the auto may be different to manual. Same year should ve fine. I suspect 2012-2016 probably same. Pretty sure 2017 onwards will ve different.
BPM (04-16-2019)
Old 04-17-2019, 12:25 PM   #3
BPM
Drives: A Blue One
So I've got hold of a used ABS module and installed it. The used ABS module came from another 2013 BRZ MT with the same part number. Followed the typical brake bleeding procedure and let the car sit a bit with the battery disconnected. Fired up the car and now the ABS and Traction control lights are on everytime I start the car. I asked a shop to take a look at why the abs module isn't working and they saw that the abs module was unable to communicate with the ecu. They told me they think it needs to be reprogrammed by the dealer. Any ideas on this? I'm a bit skeptical whether a dealer can fix this let alone work on a part that was installed used.
Old 04-17-2019, 01:02 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
My story:
What was the faulty module doing and how do you know the new module is working properly?
Old 04-17-2019, 01:44 PM   #5
BPM
Drives: A Blue One
Original ABS module would throw the abs/tsc/brake light on me randomly when I was driving. I took it into the dealer a year ago when the car was still under warranty to look at and they told me it was throwing the code c1288 and they recommend that I replaced the abs module, not covered by warranty. Didn't get to it until now. The used unit was actually bought off ebay from a pick and pull parts store. I bought this 2 weeks ago preparing for the install. The seller said it was tested and functional, not sure how to go about testing it myself. The shop i brought it to after the install didn't suggest the used module wasn't functioning, but at the same time never confirmed it was functioning lol. They only told me they saw that the ecu couldnt pair with the abs module. I'll have to go back and see whats the code its throwing again. I don't have this visibility on my current obdii reader.
Old 04-17-2019, 08:48 PM   #6
BPM
Drives: A Blue One
Got the shop the grab the code for me, another c1288 code. I'm not quite sure how to go about validating whether the abs unit itself is actually in working condition.
Old 04-17-2019, 09:43 PM   #7
steve99
Check rright rear wheel speed sensor, could even be dirty conbector or dirt and crap on sensor or detection ring
https://www.autocodes.com/c1298.html
Old 04-17-2019, 10:57 PM   #8
BPM
Drives: A Blue One
Shouldn't I be looking at the code for c1288?
https://www.autocodes.com/c1288.html
Old 04-18-2019, 02:10 AM   #9
steve99
Yes my bad , read number wrong
Old 04-18-2019, 05:24 AM   #10
BPM
Drives: A Blue One
Looks like I maybe back to square one. I'll look into validating the ABS module but I believe the ABS module codes the vehicles VIN number, rhe used module still having the old vehicles VIN. The reason why I'm gettin the c1288 code this time is due to a VIN mismatch, I just can't confirm this since I don't have enough info/evidence. Any experts out there that know ABS modules for our platform, how to test them, and how to program them?
Old 04-18-2019, 08:44 AM   #11
Bolobao
Drives: 2022 GR86, 2013 BRZ (sold)
Interesting that with the original ESP ECU the C1288 code came on randomly and not consistently. Since your linked fault code description mentions Steering Angle Sensor have you checked:
-Steering Angle Sensor is functioning & outputting correct values?
-Loose SAS connector?
-Checked for continuity between SAS and ESP ECU in the vehicle harness?
-Are are the pins themselves bent or misaligned at all?
Bolobao is offline   Reply With Quote
Old 04-20-2019, 02:56 PM   #12
BPM
Drives: A Blue One
No loose connections, steering angle sensor is working, the tech was able to do a zero point calibration. Nothing looks bent. Would this code come on due to improper bleeding when the used abs module was installed? The subaru techs told me the modules do need to be reprogrammed if a new unit goes in but unsure about a used unit (whether it can be reprogrammed).
Old 04-26-2019, 12:39 AM   #13
BPM
Drives: A Blue One
Anyone happen to know the OBD II pin layout? Which one is CG and which one is TS? Going to try a zero point calibration on my own, not sure if the shop did it correctly.
Old 04-26-2019, 01:29 AM   #14
Ultramaroon
not playing cards
Ultramaroon's Avatar
Link to service manuals in sig line
abs, module, tsc, vsc
EcuTek programming kit h@zmat Engine, Exhaust, Bolt-Ons 4 03-09-2017 08:15 PM
Key FOB programming milkesfrs Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 10-21-2015 03:56 PM
Key fob programming sambrz BRZ First-Gen (2012+) — General Topics 4 10-08-2015 10:08 AM
WTT - 2014 Scion Bespoke Nav Module for Toyota AHA Nav Module Danklvr Audio/Visual, Electronics, Infotainment, NAV 1 09-04-2014 05:57 PM
