Old 11-03-2019, 12:01 AM   #1
solidsnake11
Drives: brz
2017 abs module on 16 down
Censored
solidsnake11 is offline   Reply With Quote
Old 11-03-2019, 12:06 AM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Odd. I thought that the only difference was the VSC logic.
Old 11-06-2019, 11:11 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by solidsnake11 View Post
The track mode is supposed to be less intrusive starting in 17.
I wonder if that’s coded in the ABS module or somewhere else. If it’s in the abs module this could be a sweet upgrade.
Old 11-07-2019, 01:39 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
IIRC there was separate VSC ecu, no? But yes, if anything to retrofit from MY2017, "track mode" is highest in my wishlist, as vsc sport is one i drive car at most during all the time of DD and even on track, if it's one i've visiting first time & it's rainy wet.
Old 11-07-2019, 06:41 AM   #5
Yoshoobaroo
TRACKBREAD
Pretty sure it in the abs module like the hill assist is.
It looks to be one module. @solidsnake11 you appear to have found a Track mode retrofit! Would you mind creating a DIY for the community’s benefit?
Props for deciphering the wiring diagram, my eyes started glazing over past page 25.
Old 11-07-2019, 11:26 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
solidsnake11: "all in one" - including abs & hillclimb assist? There was no separate control module for ABS? And i wonder if having restyle dash changes things. Anyway, would appreciate, if you would actually road-test "track mode" now on yours on some parking lot or gravel road , if it actually now works as on kouki, as in - at higher slip angles & in less abrupt/intrusive way, not just if it iluminates as switched on on dash.
Old 11-07-2019, 11:39 AM   #7
Yoshoobaroo
TRACKBREAD
Trac button has to be held for a second or two where on the old it was instant.
This is promising. Suggests the VSC logic is actually changed.
Old 11-07-2019, 04:45 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Well, however it is, looks promising to what i'd wish to get.
Hopefully someone will follow your footsteps and make DIY guide for less tech savvy ones on retrofitting MY2017's track mode. What needs switched (maybe even with PN), what-how needs repinned, if it will work w/o MY2017 dash, if road-test shows track mode functioning as on other Kouki twins.
Old 11-08-2019, 08:39 AM   #9
Yoshoobaroo
TRACKBREAD
Just ordered a 17 ABS module off eBay.
I’ll report back with my findings with my stock 13 cluster. I don’t care about hill start, but it’s a good way of ensuring the module works as intended.
Old 11-08-2019, 09:42 AM   #10
wparsons
wparsons's Avatar
^^ How much was the module roughly?
Following, 2017+ track mode would be a nice upgrade for a relatively easy mod.
flickr
Old 11-08-2019, 09:47 AM   #11
Yoshoobaroo
TRACKBREAD
$100 shipped
Old 11-13-2019, 06:50 AM   #12
Yoshoobaroo
TRACKBREAD
Attachment 182617
Picture of the chip inside the abs
Neat! How does the cover come off the circuit board side? I tried prying a bit but it’s stubborn and I didn’t want to break it in case there’s a hidden tab lock.
Old 11-13-2019, 05:34 PM   #13
Yoshoobaroo
TRACKBREAD
Which way does the lock slide? Do you push all 4 tabs at the same time? Also my connector has no pin 9, that slot is labeled ‘CLSE’
Old 11-13-2019, 09:57 PM   #14
Yoshoobaroo
TRACKBREAD
I just installed the 2017 MT module in my 2013 MT BRZ.
I figured out the lock, it slides to the side where the wiring comes out of the connector, backshell comes off by prying 2 tabs on the backshell itself.
I used the same repin pattern as @solidsnake11, pink from 27 to 9, white from 32 to 8.
Upon startup, no codes but the ABS light was on for about a mile. After that everything appears normal. No hill start, VSC sport mode activates like normal (immediately upon pressing). If this is what track mode feels like it’s a very subtle difference, at least on the street. I couldn’t get crazy on the backroads but the limit feels similar as before. Maybe the difference will show at autocross. Keep in mind I haven’t driven a 2017+ to compare.
CSCS Mid Summer DRIFT 2017 - Round 3 - SUN July 23 2017 @ TMP CAYUGA SB LAYOUT DTrouble CANADA 0 07-19-2017 08:42 PM
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 08:59 AM
Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift ModinJapan Southern California 1 01-25-2017 12:46 AM
WTB BRZ Always On Module Jordan Silveira Want-To-Buy Requests 3 08-08-2016 01:30 AM
WTT - 2014 Scion Bespoke Nav Module for Toyota AHA Nav Module Danklvr Audio/Visual, Electronics, Infotainment, NAV 1 09-04-2014 05:57 PM
