Old 06-03-2025, 05:25 PM   #15
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
I actually did the swap last Friday evening. I ran a local autocross event on a smaller lot and the difference was noticeable. The car felt a little closer to the way it used to feel though getting tail happy was still a minor issue, it wasn't something unmanageable like it mostly was with the 4.30. I am going to try to run Mid-Ohio at the beginning of July so I'll know for sure then.
RongTurnRacing is offline   Reply With Quote
Old 07-24-2025, 06:33 PM   #16
Koba
Drives: 2020 BRZ
Originally Posted by DocWalt View Post
I did 3.73s on mine, no regrets.
Please share more info... very interested in a 3:73 idea.
Koba is offline   Reply With Quote
Old 07-25-2025, 09:41 AM   #17
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I bought a diff out of a ~2014 IS250 RWD and installed my OS Giken LSD into it, pretty simple swap!
Old 07-27-2025, 08:08 AM   #18
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I second the 3.73. it's called the m85, I have sold a couple on here- you need to remove the axle stubs, and most of them could do with a new breather (easy to find and cheap)
Old 07-27-2025, 09:15 PM   #19
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Oh, interesting. Mine was Y32 I believe and had no stub axles to pull.
I definitely second the tip on the breather, mine was clogged and smashed.
Old 07-28-2025, 01:17 PM   #20
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Calcs
Deleted
Forum not letting me upload the calculations
Stonehorsw is offline   Reply With Quote
Old 08-13-2025, 05:52 PM   #21
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Used 3.7 direct swap with a good diff seemed almost impossible to find, just switched the ring and pinion in mine to 3.7, still no traction until 70
B T is offline   Reply With Quote
GR86/BRZ Diff Mounts Jianlun GR86 General Topics (2nd Gen 2022+ Toyota 86) 16 06-17-2022 12:25 PM
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
Difference between Whiteline Diff Outrigger Bushings and Diff Cradle kits? mistople Engine, Exhaust, Transmission 10 09-21-2018 06:01 PM
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 12:07 AM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 02:59 PM
