Drives: 2017 BRZ (Sold), 2023 GR86
Difference between Whiteline Diff Outrigger Bushings and Diff Cradle kits?
Can anyone shed some light on the differences between the two kits? I'm looking for an engine and diff mount solution to go along with my transmission mount insert, but I can't quite tell the difference between these two since they claim basically the same net effect.
http://www.ft86speedfactory.com/whit...nsert-846.html http://www.ft86speedfactory.com/whit...t-kit-473.html |
Wes
One is mount, one is bushing. Bushing reduces the slop by a good amount (about 40% for me), and mount is I think a replacement? I imagine a lot stiffer with more NVH.
Could be wrong!
Instagram: @gt86ws
Wes
Yes I have the outrigger support and can confirm they're just bushings. The other one does indeed look like a mount replacement
Instagram: @gt86ws
Wes
I found it wasn't really enough. Car is still jerky. Definitely feels like it takes itself more seriously though. Putting in the rear subframe bushings in a couple of weeks and I think that's what will make the most difference.
Instagram: @gt86ws
#7 | |
I thought about the Spoon rigid collars as well, but I'm not sure its worth the cash. |
#8 | |
Drives: 2013 Raven FR-S
Did you consider these instead of the rigid collars? |
#9 | |
#10 |
Whoops, I'm in idiot lol. Didn't see you mentioned the subframe bushings earlier
![]() The way you're doing it is the way I plan on doing mine as well. Wanna stiffen things up but still keep it streetable without too much NVH. This car doesn't have much sound deadening as it is. |
#11 | |
| Which is better? Reaplcing rear diff bushings? or installing rear diff brace? | Frs30 | Engine, Exhaust, Transmission | 22 | 04-13-2020 10:23 AM |
| FS: Whiteline Diff Insert Bushings (KDT925) | bombardius | Brakes, Suspension, Chassis | 2 | 04-16-2016 10:50 AM |
| Who has the Whiteline diff insert bushings? | unsurety | Northern California | 4 | 09-08-2014 11:11 PM |
| Whiteline Diff cradle mount, steering rack bushings, etc.. | Thongpocket | Engine, Exhaust, Transmission | 4 | 02-25-2014 05:26 PM |
| Whiteline diff bushings and trans mount insert. | Simmons | Transmission and Driveline | 7 | 06-09-2013 08:45 PM |
