Northern California NorCal
Old 06-11-2023, 03:41 AM   #141
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
Originally Posted by JDMChris View Post
It shouldn't matter. Vortech obtained their CARB EO before the whole CAL ID for the ECU tune. CARB has no information on a CAL ID for older products. As long as the pulley size matches, and the SMOG parameters are met, they have to pass you.
The plugged their device into my OBD and the system returned a fail result. There was no serial number entry or entry about pulley size or CARB number. Its just straight from the OBD to the DMV.
mrha is offline   Reply With Quote
Old 06-15-2023, 01:42 PM   #142
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
They're supposed to lookup the EO. If their scanner is returning a fail, then you have something in your system that is not entering readiness.
JDMChris is offline   Reply With Quote
Old 06-16-2023, 10:30 PM   #143
mrha
#1819
mrha's Avatar
Everything was in the ready state according to my obd reader and theirs. They showed me there was no where in the system to enter an EO number. We tried everything.
Old 10-26-2023, 01:45 AM   #144
enomadra
Drives: 2016 FRS-RS
I'm in the same boat. I have a Vortech carb legal supercharger that I bought used from someone. I've called Vortech, gave them the serial numbers of the supercharger and they told me they won't give me the tune because the supercharger was originally sold for a 2013 frs and mine is a 2016.
I think my solution going to be, pulling all the Vortech crap off my car and get rid of it.
Then make sure to never give my money to them again for future builds.
enomadra is offline   Reply With Quote
Old 11-20-2023, 04:10 PM   #145
NaturallyAspirated
NaturallyAspirated's Avatar
Drives: 2019 BRZ w/ PP
For the time being, are people still able to pass smog by swapping back their headers to stock, flashing from their custom tune to stock, and driving for a while to ensure the system is "ready"?
Looking to swap in an aftermarket header and pair it with a custom EcuTek e-tune from CSG. My car's a 2019, so I won't have to smog for years but I intend to keep this car for a while. Having said that, I know it hard to predict if/how emission standards will change in another 4 years.
NaturallyAspirated is offline   Reply With Quote
Old 11-20-2023, 05:52 PM   #146
dpfarr
Drives: BRZ ts
I thought the law was 5 years after purchase for smog inspection. Starting 2019 there was change to being able to pay a smog abatement and defer inspection for 8 years. Hope that I’m ready to move on from this car by then.
dpfarr is offline   Reply With Quote
Old 11-21-2023, 11:46 AM   #147
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yes swap flash to stick and put some miles works.
It’s been 8 years for the first smog for new cars for about a decade now, no fees.
ineedyourdiddly
Old 07-13-2024, 07:20 PM   #148
Lav
Drives: Frs
Just trying to contribute:
I went to a smog place, the guy would fail me for the intake tube. Mishimoto Silicon Induction Hose "needs" a carb number. I have it attached to stock air intake, just the hose was replaced.
I dont know if thats necessarily true by law but Mishimoto does not provide one, and your smog guy will probably think the same
Tube: https://www.mishimoto.com/silicone-i...n-fr-s-13.html
Lav is offline   Reply With Quote
Old 07-15-2024, 11:32 PM   #149
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
That would be correct. Its after the MAF so would need CARB EO. No elbow has it afaik
Old 05-28-2025, 04:42 PM   #150
se7en_force
Drives: BRZ 2013
Ignorant question incoming...
I don't have to take the visual portion of the smog test, but I read the first page and it sounds like I have to take off my ACE 350 header and put my OEM header and ECU back to pass? If I don't have to do a visual inspection, is it a possible to have a tune that passes SMOG while keeping the aftermarket header on? Thanks for answering my dumb question.
se7en_force is offline   Reply With Quote
Old 05-28-2025, 06:45 PM   #151
2.2Lude
2.2Lude's Avatar
As long as there are no CEL's on you should be good to go without considering a visual inspection. The only thing I can think of is if the OBDII readiness check doesn't pick up of the secondary o2 sensor, generally disabled on tunes, then you might have an issue.
2.2Lude is offline   Reply With Quote
Old 05-29-2025, 06:02 AM   #152
finch1750
finch1750's Avatar
HOw do you not have to do the visual? What will they be checking exactly then? Just plugging into the OBD?
That last part will be the problem. It won't pass with a tune if they plug into it.
Old 05-29-2025, 10:24 AM   #153
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
He is in TN. In Idaho they used to do OBD only check, no visual. They didn't even open the hood. I would pass with JRSC, flex fuel kit, and custom tune.
Thankfully Idaho stopped doing even that. 98% of cars passed the first time, so they rightfully decided the program was a waste of money. So now, no more smog checks.
If I was in Cali I would have to remove flex kit, change injectors, fuel pump, and load CARB tune each time.
Old 05-29-2025, 01:55 PM   #154
2.2Lude
2.2Lude's Avatar
Unless things have changed as of recent, I've passed with previous cars on a tune. Hondata Flashpro - before the CARB tunes came out - but all readiness monitors were active.
The Following User Says Thank You to 2.2Lude For This Useful Post:
finch1750 (06-20-2025)
California Smog Check Phantobe Southern California 144 06-20-2025 05:16 PM
California owners : smog question Adam_L Engine, Exhaust, Transmission 5 10-14-2016 12:47 PM
Need advice on passing smog in California rmak321 Northern California 7 07-12-2014 01:52 AM
SMOG Issues SkullWorks Engine, Exhaust, Transmission 8 10-04-2012 02:23 PM
