#141 |
#1819
Drives: Lightning Red Subaru BRZ
The plugged their device into my OBD and the system returned a fail result. There was no serial number entry or entry about pulley size or CARB number. Its just straight from the OBD to the DMV.
#142 |
They're supposed to lookup the EO. If their scanner is returning a fail, then you have something in your system that is not entering readiness.
#143 |
#1819
Everything was in the ready state according to my obd reader and theirs. They showed me there was no where in the system to enter an EO number. We tried everything.
#144 |
Drives: 2016 FRS-RS
I'm in the same boat. I have a Vortech carb legal supercharger that I bought used from someone. I've called Vortech, gave them the serial numbers of the supercharger and they told me they won't give me the tune because the supercharger was originally sold for a 2013 frs and mine is a 2016.
I think my solution going to be, pulling all the Vortech crap off my car and get rid of it. Then make sure to never give my money to them again for future builds. |
#145 |
Drives: 2019 BRZ w/ PP
For the time being, are people still able to pass smog by swapping back their headers to stock, flashing from their custom tune to stock, and driving for a while to ensure the system is "ready"?
Looking to swap in an aftermarket header and pair it with a custom EcuTek e-tune from CSG. My car's a 2019, so I won't have to smog for years but I intend to keep this car for a while. Having said that, I know it hard to predict if/how emission standards will change in another 4 years. |
#146 |
Drives: BRZ ts
I thought the law was 5 years after purchase for smog inspection. Starting 2019 there was change to being able to pay a smog abatement and defer inspection for 8 years. Hope that I’m ready to move on from this car by then.
#147 |
Drives: '13 FRS - STX
Yes swap flash to stick and put some miles works.
It’s been 8 years for the first smog for new cars for about a decade now, no fees. |
#148 |
Drives: Frs
Just trying to contribute:
I went to a smog place, the guy would fail me for the intake tube. Mishimoto Silicon Induction Hose "needs" a carb number. I have it attached to stock air intake, just the hose was replaced. I dont know if thats necessarily true by law but Mishimoto does not provide one, and your smog guy will probably think the same Tube: https://www.mishimoto.com/silicone-i...n-fr-s-13.html |
#149 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#150 |
Drives: BRZ 2013
Ignorant question incoming...
I don't have to take the visual portion of the smog test, but I read the first page and it sounds like I have to take off my ACE 350 header and put my OEM header and ECU back to pass? If I don't have to do a visual inspection, is it a possible to have a tune that passes SMOG while keeping the aftermarket header on? Thanks for answering my dumb question. |
#151 | |
#152 | |
That last part will be the problem. It won't pass with a tune if they plug into it. |
#153 | |
Famous Potatoes
Drives: '15 ultramarine
Thankfully Idaho stopped doing even that. 98% of cars passed the first time, so they rightfully decided the program was a waste of money. So now, no more smog checks. If I was in Cali I would have to remove flex kit, change injectors, fuel pump, and load CARB tune each time. |
#154 |
Unless things have changed as of recent, I've passed with previous cars on a tune. Hondata Flashpro - before the CARB tunes came out - but all readiness monitors were active.
| The Following User Says Thank You to 2.2Lude For This Useful Post: | finch1750 (06-20-2025) |
| California Smog Check | Phantobe | Southern California | 144 | 06-20-2025 04:16 PM |
| California owners : smog question | Adam_L | Engine, Exhaust, Transmission | 5 | 10-14-2016 11:47 AM |
| Need advice on passing smog in California | rmak321 | Northern California | 7 | 07-12-2014 12:52 AM |
| SMOG Issues | SkullWorks | Engine, Exhaust, Transmission | 8 | 10-04-2012 01:23 PM |
