Drives: 2014 Scion FRS (Asphalt)
Rotor Warping/Deposit on Track
I have been experiencing a warped/pad deposit feeling on track leading me to change rotors almost every track day. The feeling is more notable when light/trail braking at high speeds. When I am on the brake 100% the issue is almost non-existent. The vibration becomes apparent from the second hot lap onwards. Pads have been bedded in and are warmed up before full brake application. A full 2 mile cool down lap after every session as well.
I run Carbotech XP12 in the front and XP10 in the rear on an OEM non-PP brake and rotor setup. The car has FI making about 270whp. Am I just running the rotors or pads too hot causing the vibration? I currently have no ducting.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
#2 |
Probably not hot enough, and not getting an even transfer layer.
| The Following User Says Thank You to Tokay444 For This Useful Post: | tyler_win_photo (06-06-2024) |
#3 | |
Drives: Toyota GT86
Not 100% sure how much extra power the stock brakes can handle. I see some track owners swap them for BBK even with stock power but most people seem to think that is overkill.
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
| The Following User Says Thank You to autoracer86 For This Useful Post: | tyler_win_photo (06-06-2024) |
#4 | |
Drives: 2013 Subaru BRZ
The whole point of this stuff is enjoyment for me and the idea of cutting corners on brakes just doesn't compute. If I'm willing to do that then I guess a helmet is optional too.
| The Following User Says Thank You to RT-BRZ For This Useful Post: | autoracer86 (06-03-2024) |
#5 | |
Drives: '13 BRZ Limited
Your situation sounds exactly like mine - hard braking eliminated the shudder, but lighter braking once the brakes were warm shuddered.
Do you have pics of the rotor - are there a bunch of little dots around it? I was desperate and just replaced the front hub on the one that had the worst "spots" on the rotors. Problem solved. There was no play in the hub when "cool" after a session that I could feel, but there apparently was enough play in the hub bearings once warm to cause the wobble. Clamping the rotor hard with the brakes gave it enough support to not wobble. If that's not it : lots of reports of issues with uneven transfer layers with carbotech pads resulting in brake shudder. I moved away from them while trying to fix my "brake" problems just to eliminate that as a variable. This was 2 driver front rotors from the same weekend. Changed after the first day, then after the 2nd day. Passenger front had a tiny hint of the same issue - but really hard to see. I ended up swapping that hub as well to completely fix any hint of shudder on braking. Quote:
#6 | |
| The Following User Says Thank You to tyler_win_photo For This Useful Post: | RT-BRZ (06-06-2024) |
#7 | |
Now that you mention it, it could by the hubs. My car has about 75k miles. There is no play when cold, but it might have play when it's warm. Thanks for the insight!
#8 | |
I did not log data to verify hub tone ring wasn't sending bad wheel speed data causing ABS activation - so I can't rule it out. In the end the new hubs (which include the wheel speed sensor tone ring) 1000% solved the issue though, so even if it was ABS the cure was the same - new hub. After replacing it was night and day better, dead smooth for all 4 sessions. I really didn't think replacing a hub would fix the issue. I did it out of desperation as I had tried most everything else short of buying the AP Sprint BBK. The hub was avail at a local Autozone, was a lot cheaper, and I could just swap it out that Sat night in an attempt to salvage Sunday. |
| The Following User Says Thank You to 86league For This Useful Post: | tyler_win_photo (06-06-2024) |
#9 |
With zero data or video, I'd be willing to bet you're getting your pads pretty hot, and then parking with insufficient cooldown, resulting in deposits.
The deposits are the vibrations. Step up to a better pad AND do way more cooldown. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | strat61caster (06-19-2024) |
#10 |
Drives: Crapcan
Ducting may help but I think with stock brakes you are over the limit of the amount of heat you can dissipate to keep those pads in their happy place.
#11 |
Pawn in game of life
Drives: 19 STX BRZzz
The dots on the rotor color align with the rotor vanes, not likely ABS related.
Autocross nut
| The Following User Says Thank You to AustinTX For This Useful Post: | strat61caster (06-19-2024) |
#12 |
| Uneven brake temps and warping after a light track day | imprezive | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 04-21-2022 12:21 AM |
| Brake rotor wear after 3 track days | Edkwok99 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 71 | 04-19-2022 10:41 AM |
| Replacement 'stock' rotor suggestions for track? | Open Loop | Tracking / Autocross / HPDE / Drifting | 10 | 10-17-2018 06:00 PM |
| Brake disc warping patterns | Strat | AFRICA | 12 | 04-02-2015 07:05 AM |
| Buddy Club Taillights warping | chimmy | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 01-13-2015 03:50 PM |
