Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 04-10-2022, 11:47 PM   #1
Edkwok99
Drives: GR86
Brake rotor wear after 3 track days
After 3 track day with Hawk DTC 60, the front rotors look like this. The rotor surface is smooth
Should I replace them immediately?
Edkwok99 is offline   Reply With Quote
Old 04-11-2022, 02:48 AM   #2
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
gen3v8 is offline   Reply With Quote
Old 04-11-2022, 03:39 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
Lol, 'completely broken car', location:Germany
https://www.google.com/amp/s/nomoney...ur-rotors/amp/
Old 04-11-2022, 06:57 AM   #4
Varelco
Drives: '15 GT86 & '22 GR86
Originally Posted by kosh0r View Post
Did you look at the last 2 pictures? The cracks almost reached the outside.
I cannot believe that you cant feel them. They are almost a millimeter wide.
Yeah Germany, the country with the 1/3 death rate in traffic, compared to USA.
Indeed, you would not be allowed to run a car here with such discs (last 2 pictures).
But hey, its just about braking... Nothing important
Edit: But anyway: I'm a cautious person and would replace the replace the cracked one (i guess, they are the front discs).
And i dont want to argue with people, who may know better.
At the end, its your life you may play with. At least your car...
If you crash and have nothing else to worry about than the car, the insurance will try to find a reason not to pay. Discs with cracks (or exploded discs) look like a good reason to me.
I would not want to check the discs after/before every trip, but its my OPPINION.
The discs have 'crazing', hairline surface cracks caused by excessive heat. Its pretty normal from brakes which are used hard, its usually superficial and is definitely not considered dangerous.
Your hysteria is not welcome, especially as you do not completely understand what it is you are advising against.
Varelco is offline   Reply With Quote
Old 04-11-2022, 07:23 AM   #5
kosh0r
Drives: -
Ok. Then sorry fot that.
I deleted my posts to avoid further confusion.
Btw. I googled before i posted, i found several warnings, but i'm definivly not as deep into this, than others.
E.g. i found this is considered as "will break under load".
https://www.at-rs.de/files/blog/Scha.../Bild-3-T2.jpg
So whats the difference?
kosh0r is offline   Reply With Quote
Old 04-11-2022, 07:27 AM   #6
kosh0r
Drives: -
ok, i found some good explanation:
https://www.essexparts.com/news-blog...-my-iron-discs
Old 04-11-2022, 10:35 AM   #7
Edkwok99
Drives: GR86
Thanks for all feedbacks.
Does that mean the pad is too aggressive for the rotor? Or/and the rotor exceeded operating temperature?
If I upgrade to a better performance rotor, will the rotor have heat checking again from track use?
Old 04-11-2022, 12:28 PM   #8
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
1 possibly 2 did the rotors change color or warp? 3 Maybe (checking? I presume you mean the surface cracking/crazing)
what brake fluid, did they fade? Might change my answer to 1 maybe 2 but not 3
Old 04-11-2022, 02:21 PM   #9
Edkwok99
Drives: GR86
I use Castrol SRF racing brake fluid and Stoptech SS lines. Brake fluid is still light yellow after 3 track days.
I didn’t experience any brake fade / soft pedal feel at the track.
Old 04-11-2022, 03:21 PM   #10
staples323
staples323's Avatar
Drives: '22 GR86
Are you using any of the nannies, traction/ stability control? They use the brakes to control wheel speed and create a lot of excessive heat on the brake system.
2022 Toyota GR86 Halo NASA TT5
2015 Subaru BRZ Crystal White Pearl NASA TT5 SOLD
staples323 is offline   Reply With Quote
Old 04-11-2022, 03:49 PM   #11
norcalpb
norcalpb's Avatar
You should try cryo treated rotors for your next set. I heard after they sit in -300F freezers they can last up to 3x longer.
Old 04-11-2022, 04:42 PM   #12
Edkwok99
Drives: GR86
I use Track mode.
It could be from rt660 tires. I go full speed at the track; I really “drive” the car.
Old 04-11-2022, 04:48 PM   #13
staples323
staples323's Avatar
Drives: '22 GR86
Originally Posted by Edkwok99 View Post
I use Track mode.
Track mode still has some but minimal intervention. Long pressing the trac off button turns everything off
Old 04-11-2022, 05:19 PM   #14
Edkwok99
Drives: GR86
Yes. I know how to turn everything off.
But I am not ready yet
Brake pads to swap between for DD and Track Days jim985 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 12-25-2020 08:12 PM
Brake compound for Track Days fer3d Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 07-31-2018 08:47 AM
Brake Pads and Fluid For DD/AutoX/Track Days/HPDE ToyoburuBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 07-23-2016 03:59 PM
NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days 86_Insider Brakes, Suspension, Chassis 1 09-26-2013 01:39 AM
Brake pads for track days why Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-26-2013 06:42 PM
