Old 05-06-2024, 01:50 PM   #1
White64Goat
Rear End Shifts on Accel/Decel
Been a long time since I posted here.......have a 2013 BRZ and recently I have noticed when driving the car and accelerating up through the gears that when I shift and let off the gas and then get back on the gas, the rear end is changing directions. Can also make it do the same thing by hitting and letting off the gas. Have visually looked at the rear bushings and don't see anything wrong by the eye. Wondering if anyone else has had this problem and what it was?
Thanks.
Old 05-06-2024, 02:28 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
I'd check all drivetrain bushings - rear subframe, diff mounts, transmission and shifter mounts and engine mounts. All of these contribute to the rear being squarely.
In addition, check your suspension links, especially toe arms. Make sure everything is tight, bushings are in good shape and toe isn't out of whack (slipping or loose toe adjuster, for example).
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
RedReplicant (05-06-2024), strat61caster (05-07-2024)
Old 05-06-2024, 06:22 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
What are your tire pressures? What you describe is how a Torsen diff behaves when you have rear tires of different diameter, or one is at lower pressure.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
RToyo86 (05-07-2024), Turdinator (09-05-2024)
Old 05-07-2024, 07:38 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I’ve also seen this when cross weight is jacked, ignore if on non adjustable spring perches.
ineedyourdiddly
Old 05-23-2024, 05:21 PM   #5
grippgoat
Drives: 2023 BRZ, 2018 Golf R 6MT
I'd check wheel bearings and axle nuts, too.
grippgoat is offline   Reply With Quote
Old 05-24-2024, 09:42 AM   #6
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I experienced this. My right rear tire was worn significantly more than the left. The rear of the car stepped right during hard accelleration. No effect noticed during braking however.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 05-24-2024, 09:52 AM   #7
White64Goat
Tire pressures were the first thing I checked and all were good. Wear is even on all tires as well. Car is also puling to the right as well and it has driven straight as an arrow since I've had it. As far as I know there has been no curb contact to knock alignment out of whack. Going to take it to the dealer next week probably as driving it out on the interstate it has a constant tug to the right which is annoying as hell.
Old 05-26-2024, 09:51 PM   #8
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
something is loose, broken, worn significantly, or both/all 3. I'd take it to see a known good professional who knows these cars or similar types of cars, not just "the dealer" unless your specific dealer has a guy who really knows what he is doing, and the service manager allows him to work that way, not just typical dealership flat rate. I am a professional tech and have worked at dealerships in the past. Just my advice.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 05-28-2024, 02:15 PM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
You might confirm which way the car zigs when on the gas, and which way it zags when off the gas, and then swap the rear tires left/right and see if it behaves the same way or the opposite (i.e. zig on gas becomes zag on gas). If behavior flips, perhaps a bad tire with internal defect like delamination or some such...
Old 08-02-2024, 03:49 PM   #10
White64Goat
All Good Now........
Installed 4 new tires and the issue went away. Didn't think the tires were all that bad but when I jacked the car up and spun them, boy were they not in good shape. So, issue solved.
The Following 2 Users Say Thank You to White64Goat For This Useful Post:
strat61caster (08-03-2024), Wally86 (08-05-2024)
Slight pull to the left on accel, pull to the right on decel mightaswell Issues | Warranty | Recalls / TSB 18 01-12-2021 07:50 PM
Whiteline Rear Transmission Insert Noise in Decel Only M0nk3y Engine, Exhaust, Transmission 9 03-10-2020 07:51 PM
Perrin rear shifter bushing = sloppier shifts? abutterman Engine, Exhaust, Transmission 9 02-26-2016 12:41 AM
Transmission kick under accel SCharged Issues | Warranty | Recalls / TSB 11 03-18-2014 11:24 AM
Apexi SMART Accel Controller 808Raven Engine, Exhaust, Transmission 2 10-11-2012 07:54 PM
