Old 03-17-2014, 01:52 PM   #1
SCharged
Drives: asphalt fr-s
Transmission kick under accel
Anyone experiencing transmission knocking under wheel spin off a start?? I get the usual shifter shake, but also some ''dry'' knocking of the tranny underneath..
anyone else?? fixes?? tranny support/mount maybe?
Thanks
SCharged is offline   Reply With Quote
Old 03-17-2014, 02:08 PM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
auto or manual?
Old 03-17-2014, 02:23 PM   #3
SCharged
Sorry, should've specified... it's manual
Old 03-17-2014, 02:38 PM   #4
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
Thanks
If it's what I and a couple others have experienced then it's actually "wheel hop." I say that because I'm not sure the wheels are actually hopping, but that's what it feels like. If you watch some Whiteline videos on YouTube the entire rear subframe of the car moves an incredible amount. What I think actually happens is that the whole system moves, binds/unloads the wheels, then wheels stop spinning/system moves again.
Based on my hunch, I've bought diff outrigger bushings, diff mount bushings, and subframe bushing inserts. I'm hoping that's enough to keep everything where it should be.
Travisty75 is offline   Reply With Quote
Old 03-17-2014, 03:23 PM   #5
SCharged
Makes sense.. Although I 've had this on the wet too.. I've never seen wheel hop on wet i think..
Old 03-17-2014, 04:51 PM   #6
Travisty75
Travisty75's Avatar
I've experienced it in wet and dry. Dry was under spirited acceleration at the start of an AutoX, wet happened leaving stop lights with a bit if a clutch side-step.
Old 03-17-2014, 04:57 PM   #7
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Yup, it's wheel hop. It's pretty intermittent in our cars and it really isn't too bad compared to some other cars I've launched in. Like@Travisty75 said, there's a few things you can get to alleviate it, but it's really just something you gotta live with when you have IRS.
- The Ancient BRZ Sacrament
by Zaku
Old 03-17-2014, 04:59 PM   #8
GotMunchies?
Drives: '14 WRB BRZ 6MT Limited
This is likely wheep hop if it felt like a juddering from the rear end with vertical vibrations. Its a common issue with RWD cars with many different types of suspension set ups. I get it in my Mustang with a stick axle - its worse in the wet. Older CTS-V's could axle hop so badly they would blow up differentials. Fixes range from driving adjustments to adjusting suspension geometry.
GotMunchies? is offline   Reply With Quote
Old 03-18-2014, 09:53 AM   #9
SCharged
Thanks for input everyone. I'm kind of relieved... will still keep an eye open and update thread if it ends up being something that may be of interest to the community.
Old 03-18-2014, 10:09 AM   #10
OrbitalEllipses
Drives: Attitude
There are mounting points you can stiffen to prevent slop (engine mounts, trans mount, rear diff mount, rear subframe inserts, 1pc driveshaft) and minimize wheel hop, but as others have said it's the nature of the beast.
Old 03-18-2014, 11:20 AM   #11
Mikem53
Drives: FR-S 6MT
How is this car with wheel hop..? My old age mentally prevents me from doing too many abusive launches.. My last car was a C6 vette, I had terrible wheel hop issues.. I aliveiated most of the wheel hop issues by replacing the stock GY Runflats with some non-runflat pilot sports.
IRS set ups aren't good for abrupt hard burnouts. At least in my experiences..
Mikem53 is offline   Reply With Quote
Old 03-18-2014, 11:24 AM   #12
OrbitalEllipses
Drives: Attitude
I haven't addressed it, but this thread might have good information: http://www.ft86club.com/forums/showthread.php?t=29020
Short search link (LMGTFY, forgive me): http://bit.ly/1ooDBaL
Automatic Transmission Kick/Choke when shifting gears Tech Gremlin Engine, Exhaust, Transmission 13 06-16-2015 01:54 AM
PTUNING Summer Kick Off meet & dyno Freddy@PTUNING Mid-Atlantic 13 05-20-2013 03:41 PM
for socal (405/605fwy) people. does the HD Radio kick in and out often? tracerit Southern California 16 04-10-2013 08:55 PM
Knock/valve slap/crick noise under accel yomny Issues | Warranty | Recalls / TSB 47 01-07-2013 08:53 PM
Apexi SMART Accel Controller 808Raven Engine, Exhaust, Transmission 2 10-11-2012 07:54 PM
