Old 07-26-2013, 06:57 PM   #1
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
Perrin rear shifter bushing = sloppier shifts?
I installed the perrin rear shifter bushing a couple weeks ago and it seemed ok for the first day or so but then started encountering much more sloppiness and resistance, mostly in the lower gears. Going into 1st from a stop the shifter feels like it's rubbing all over everything. 3rd gear is especially annoying... feels like it's hitting the corner of a wall and makes a bit of a knocking noise as it goes in. Sometimes it's nice and smooth but sometimes it feels like crap. Anyone else have this issue? Should i try the kartboy bushing instead?
abutterman is offline   Reply With Quote
Old 07-26-2013, 07:20 PM   #2
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
Have you tried lubing up the part where the rod goes in? If so, and you're still getting this issue, it could be that you just ended up getting a funky part from us.
This is not normal and I have never heard of it happening before.
If you'd like, you can PM me your information, and I can get a new one sent out to you!
Thanks!
PERRIN_Mladen is offline   Reply With Quote
Old 07-26-2013, 07:21 PM   #3
abutterman
abutterman's Avatar
Thanks!
i put a fair amount of the lube in the center hole when it was installed. everything went together without a problem. not sure if something's misaligned or what i'll pm you
Old 07-26-2013, 07:23 PM   #4
PERRIN_Mladen
Drives: '11 535i
Yeah, as I said, it may have been just a funky part.
Looking forward to your PM and to get you taken care of
Old 07-27-2013, 01:18 AM   #5
abutterman
abutterman's Avatar
replacement part on its way
in the meantime, anyone have any similar experience? I might put my stock bushing back in tomorrow to make 100% sure that's the problem. figure might as well since it's becoming a huge pain to drive. It feels way more crunchy than ever before
Old 07-27-2013, 08:42 AM   #6
wparsons
wparsons's Avatar
It *could* be that the perrin bushing is just transmitting more of the feel to your hand than the OEM part did. If that's the case, anything stiffer than stock is going to have the same effect.
To me it sounds like it feels worse sometimes because you're not hitting the gate dead on, but other shifts you nail it so it feels better.
There might be something wrong with the part you have, but that's my guess at the issue.
flickr
Old 07-27-2013, 10:36 AM   #7
abutterman
abutterman's Avatar
yea i expected it to make bad shifts feel more noticable but i could just be parked in front of my house, turn the car on and hold the clutch pedal down and if say i try 1st gear, it'll feel like it's knocking all over the place. Last night just going from 1st to 2nd which i actually usually don't have much of a problem with, it felt like it got stuck half way through the gate and i had to pull back to neutral and try again. I'm going over to Real Auto Dynamics which luckily is down the block from me later this afternoon so they can take a look. If it's just a matter of the lube not spreading evenly or a screw coming loose then problem solved. Otherwise the stock ones going back on for now to see if it's at least the way it was before all this which would be fine for the time being
Old 07-27-2013, 06:22 PM   #8
abutterman
abutterman's Avatar
Just put the stock one back on and as of now it seems to be better (as good as this thing is going to be). The inside of the Perrin bushing seems to be all shredded and torn up. I guess something was slightly off and that was probably the reason for it shifting so poorly. I'll give the replacement a try when it comes in
Old 02-25-2016, 07:52 PM   #9
IEATBOX
IEATBOX's Avatar
REAR SHIFTER BUSHING FOR FR-S
Did you have any trouble with the replacement REAR SHIFTER BUSHING from Perrin?
H
IEATBOX is offline   Reply With Quote
Old 02-26-2016, 12:41 AM   #10
RJasonKlein
RJasonKlein's Avatar
Wow - this thread got resurrected from the dead - I have the part and my car shifts very well. The galling inside the receptacle indicates the part was either misaligned or starved of lubrication.
RJasonKlein is offline   Reply With Quote
Perrin Rear Shifter Bushing Install F1point4 DIY (Do-It-Yourself) Guides 55 10-21-2021 02:39 PM
FS: Perrin Rear Shifter Bushing green_comet Australia Classifieds 2 11-07-2012 02:04 AM
