Old 03-10-2020, 02:22 PM   #1
M0nk3y
Whiteline Rear Transmission Insert Noise in Decel Only
Pretty much what the title states.
Installed whiteline transmission mount insert bushing in addition to STi Engine Mounts this off-season. Went to go drive around the block and I was greeted with this noise on deceleration:
[ame]https://www.youtube.com/watch?v=bCDWsh5iKAI[/ame]
The video is some nasty noise happening on decel only. Kicking in the clutch or coasting/accel the noise is no longer apparent.
Swapped back to OE bushings and noise no longer there, thinking I torqued something wrong I reinstalled the insert bushing and once again bad noises crept up instantly.
Currently back on OE bushing, just trying to figure out why I’m having such a dramatic impact. Only other thing changed out are STi Engine mounts. Everything else is OEM within the drivetrain.
One last thing, car has 15,000 miles on it. I bought it new/I’m original owner
Kyle H. - #89 STX
Old 03-10-2020, 02:27 PM   #2
StraightOuttaCanadaEh
Wes
I have the Perrin engine mounts, the Whiteline shifter bushing and perrin trans insert and I have very similar noises. I wouldn't worry, although it'd be good to check
Instagram: @gt86ws
Old 03-10-2020, 03:06 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
With less compliant bushings usual thing is that vibrations/noises don't just dissapear if you remove one of dampening elements, it usually just gets transfered elsewhere and sometimes amplified, if in contact with some other parts.
So unless it's track specialized build, i'd probably choose which parts in drivetrain seem more worthy candidates for stiffer bushings, and leave rest alone.
At one point i had TRD engine mounts, perrin shifter bushing and trans insert, whiteline diff inserts (probably to completely make it unbearable only one-piece driveshaft missing ). Reverted only to perrin gearbox related ones. Not completely w/o NVH impact (slight SC like gear whine in 1st & 2nd of telerable levels), but they still provide better shifting feel (together with redline MTL oil), but at least i get less noise of clutch related/grip change related tranny shocks induced and engine vibrations produced noises. If one removes all damping, all possible noises are passed to car body acting as resonator :/, nowhere "to go"/to be passed for vibrations/noise. The more bushings you replace, even if by reviews from others many of them may have very little individual impact on NVH, the much worse multiplied "sum" of NVH impact results, so i can only advise to choose what you want to change most, not all.
Old 03-10-2020, 03:49 PM   #4
Alpha86
Drives: 2013 Firestorm Red FRS
I have this same issue after installing the Whiteline insert. Its completely normal, stiffer bushings will pretty much always increase NVH in some way.
Alpha86 is offline   Reply With Quote
Old 03-10-2020, 04:44 PM   #5
86TOYO2k17
Drives: 2017 toyota 86
i have sti mounts, whiteline trans insert, whiteline support outrigger insert, carbon fiber driveshaft, and i have zero added NVH under any scenario.
however when i installed whiteline positive traction kit as soon as i hit 70mph my rear end felt like a washing machine, vibrated so bad i could barely see straight. Drove straight home and took them off, back to zero NVH. i know many people have used the traction kit with no issues so i think it was the straw that broke the back so to speak.
Also i have an AUTO not an MT so maybe that makes a difference why i have no NVH.
Old 03-10-2020, 06:09 PM   #6
Grady
Grady's Avatar
Same thing here. No issue for me I knew going in NVH would increase.
Old 03-10-2020, 06:11 PM   #7
Grady
Grady's Avatar
The bushings will not cause a vibration they will just show you you have a vibration that the other bushings are hiding. I would but the bushings back in and find the issue. Probably the CF driveshaft.
Old 03-10-2020, 06:18 PM   #8
M0nk3y
I guess my question/issue is that NVH is only apparent on decel. Nothing has changed or at least noticeable on acceleration and coast.
Reverse as well is a nightmare, it sounds like the transmission is seizing. I realize it appears like it’s overreacting, but it’s a terrible noise.
Coming from someone who did 80A durometer bushings on my previous 128i, along with black power flex race differential bushings, I’ve never experience a noise specifically related to one specific portion of driving. If that makes any sense at all
Kyle H. - #89 STX
Old 03-10-2020, 06:42 PM   #9
86TOYO2k17
None of them will cause a vibration alone because none of them are causing an issue/vibration now nor thousands of miles before or after install/removal of the rear subframe inserts. And the least beneficial of those mods is the rear subframe inserts. So putting them back in would be pointless. The issue is the combined stiffness across the entire drivetrain including the rear subframe insert. Removing any of the mounts/inserts/cf ds could and possibly would eliminate it but why remove something more beneficial when the issue is resolved from eliminating the least beneficial. My car before install and after removal is butter smooth no NVH beyond what it was from factory at any speed 0-130+mph cruising, accelerating , or decelerating, up hill or down hill doesn’t matter.
Old 03-10-2020, 07:51 PM   #10
cueball89
Drives: 15 Impreza
Had a similar experience with my old wrx. Sti engine and transmission mounts with some poly bushings thrown in yielded deacceleration noises similar to what you are experiencing. Never had noise under any other circumstances. I happened to be in MD and had Andrewtech Automotive take the car for a test drive, they said it was normal. I put 100,000 more miles on the car without any issues.
cueball89 is offline   Reply With Quote
DIY - Whiteline Rear Crossmember Mount Insert Bushings F1point4 DIY (Do-It-Yourself) Guides 91 01-17-2021 02:23 AM
FS: Whiteline KDT926 Transmission insert Andy2002a Transmission and Driveline 0 10-12-2019 08:16 PM
Whiteline Transmission Insert norcalpb Transmission and Driveline 2 03-12-2018 03:00 PM
Rear Shifter/Transmission Mount Insert Bushings TheseColorsDontRun Mid-Atlantic 7 08-30-2013 10:29 AM
Whiteline Rear Crossmember-Mount Insert Bushing: Great pricing b2autodesigns Brakes, Suspension, Chassis 1 02-18-2013 11:41 AM
