Old 11-09-2023, 11:32 AM   #1
nicholaswhj
nicholaswhj's Avatar
Drives: Toyota 86
Exclamation Toyota 86 2014 : Gear Indicator Missing
Hello from Malaysia.
I drive a 86 GT Limited Manual 2014 and my gear indicator is on. I was a bit careless today and went pass a hump without stopping. So there was a huge knock. The hump is lower than my car by few centimeters and I went down and check all is ok.
I continue driving and I notice my gear indicator is missing. A quick check when I restart the car, the Gear indicator mode is on. Anyone have any idea? Something broken?
Thanks in advance.
Nic
nicholaswhj is offline   Reply With Quote
Old 11-09-2023, 01:30 PM   #2
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
The only thing I've known to reset the gear indicator is a dead battery. Any chance you had to jump-start the car on the same day?
Otherwise, so long as the car drives straight and behaves normally, I wouldn't worry about it.
alex87f is offline   Reply With Quote
Old 11-09-2023, 08:05 PM   #3
Grady
Grady's Avatar
Gear indicator is a calculation between engine RPM and vehicle speed, except reverse. I would disconnect the battery for 30 min and reset everything.
Old 11-09-2023, 10:52 PM   #4
nicholaswhj
Drives: Toyota 86
If its just reset then is ok. I am only worried if any socket broken or something like that.
[QUOTE=alex87f;3596201]The only thing I've known to reset the gear indicator is a dead battery. Any chance you had to jump-start the car on the same day?
Otherwise, so long as the car drives straight and behaves normally, I wouldn't worry about it.[/QUOTE
Gear indicator not registering 5 th gear on 6mt sroby Engine, Exhaust, Transmission 20 03-19-2020 12:43 AM
Gear indicator (G-on) shows 2 when in 3rd gear c8Face BRZ First-Gen (2012+) — General Topics 31 07-07-2017 08:23 PM
BRZ HUD Gear Indicator Missing? norcalpb BRZ First-Gen (2012+) — General Topics 25 06-15-2015 07:55 AM
MT gear indicator WolfsFang Scion FR-S / Toyota 86 GT86 General Forum 19 07-02-2012 11:20 PM
Gear indicator Slick CANADA 18 05-20-2012 11:14 AM
