Old 11-11-2014, 04:23 PM   #1
norcalpb
norcalpb's Avatar
BRZ HUD Gear Indicator Missing?
I know there's a gear indicator setting that is found under the odometer button, but I can't seem to find it on my 2013 BRZ. I recently adjusted the clutch but adjusted the clutch button as well so it made full contact. Still no luck.
I never checked to see if my car had this feature before I adjusted the clutch, so I was just making sure 2013 BRZs had this feature.
Thanks!
Old 11-11-2014, 04:29 PM   #2
PAbrz
PAbrz's Avatar
Drives: '13 DGM BRZ 6 M/T
[ame="https://www.youtube.com/watch?v=fB9dcC9dl3w"]Scion FR-S: How to set the Shift Light & Gear Indicator Display Settings (BRZ GT86) - YouTube[/ame]
PAbrz is offline   Reply With Quote
Old 11-11-2014, 05:07 PM   #3
wheelhaus
wheelhaus's Avatar
The FRS and BRZ gauge clusters are different, and I don't believe the BRZ has the gear indicator or economy shift indicator as the FRS. If it does, I haven't found it.
wheelhaus is offline   Reply With Quote
Old 11-11-2014, 05:31 PM   #4
Pkush
BRZ has both. At least the 2015 Series.blue does.
Pkush is offline   Reply With Quote
Old 11-11-2014, 05:33 PM   #5
bababooey
Drives: BRZ SWP Limited -6MT
my 14 does have both as well
Old 11-11-2014, 05:34 PM   #6
Foobar
SLO NO MO
Foobar's Avatar
It's just defaulted off, for whatever reason.
Old 11-11-2014, 05:36 PM   #7
wheelhaus
wheelhaus's Avatar
After watching that video I think I may be wrong. I hope I am, will try tonight on my way home from work.
Old 11-11-2014, 05:51 PM   #8
Akari
Drives: 2013 DGM BRZ
Yeah, my 2013 BRZ definitely has it. Defaulted to off from the dealership.
Akari is offline   Reply With Quote
Old 11-11-2014, 07:42 PM   #9
norcalpb
norcalpb's Avatar
I'm so dumb, thank you guys =)
Old 11-12-2014, 10:55 AM   #10
wheelhaus
wheelhaus's Avatar
confirmed, mine is 1st year and it does indeed have it. I thought it was in the shift light menu, not the odomoeter menu... Its there!
Old 11-16-2014, 05:51 PM   #11
pl1ght
Drives: 2015 Alfa Romeo 4C
Sweet, didnt even know i had this feature, turned it on my '14 limited.
pl1ght is offline   Reply With Quote
Old 11-17-2014, 09:57 PM   #12
gravitylover
I tried a few times and I don't think the gear indicator feature is on the premium model. I can set the rev limit beep but it doesn't go to the next step with the gear indicator. Wouldn't surprise me if I'm missing something...
Old 11-18-2014, 02:12 AM   #13
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Don't actually start the car. Just go to accessory power with your key, then you should be able to access the G-on/off when you press through with the ODO / TRIP button.
dhuang is offline   Reply With Quote
Old 11-18-2014, 07:58 PM   #14
gravitylover
Tried again and it goes odo/trip a/trip b and that's it. Am I supposed to hold the button down or ...?
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 08:42 PM
FT86 GT manual gear indicator KamalT Engine, Exhaust, Transmission 3 10-04-2012 09:43 PM
MT gear indicator WolfsFang Scion FR-S / Toyota 86 GT86 General Forum 19 07-02-2012 10:20 PM
MT Gear Indicator Issue civicdrivr Scion FR-S / Toyota 86 GT86 General Forum 28 05-21-2012 11:40 PM
Gear indicator Slick CANADA 18 05-20-2012 10:14 AM
