Old 09-26-2023, 04:42 PM   #1
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Energy Suspension Shifter bushing
Has anyone tried to install this brand of rear shifter bushing? I could not get the thing to slide onto the shifter rod even with dish soap as a lubricant.
In videos of other brands, the thing seems to slide on with minimal effort.
Energy Suspension is going to send me some of their special lube, but any other suggestions would be appreciated.
Old 09-26-2023, 05:05 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
Transmission in neutral and parking brake released? I struggled for half an hour until I realized that.
Old 09-26-2023, 05:07 PM   #3
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I didn't use that brand, but I found it easiest to lube it up, sort of jam it between the shifter bracket and body, then bench press the shifter bracket up into place which pushed the bushing onto the bracket.
I couldn't get enough force into to push it onto the bracket otherwise.
Old 09-26-2023, 09:20 PM   #4
blsfrs
blsfrs's Avatar
Thank you these ideas but I'm not understanding either of them.
The rod and bushing are horizontal so I can't make sense of the bench press scenario and I don't see what influence the parking brake will have.
Energy Suspension is sending their grease and suggested heat the bushing with a blow dryer.
Old 09-26-2023, 09:57 PM   #5
Ohio Enthusiast
Drives: 2018 BRZ
I'll ask again, is the transmission in neutral and parking brake released? If not you won't have enough room to slide the bushing on, no matter how much lube you use. It will feel like it can't go on, but that's just due to misalignment between the shifter carrier shaft and the transmission tunnel and driveshaft. Note that leaving the transmission in gear and having the parking brake engaged doesn't interfere with removing the stock bushing.
Old 09-27-2023, 09:39 AM   #6
blsfrs
blsfrs's Avatar
I was installing the bushing during my transmission reinstall. The driveshaft was still out of the car. There was plenty of room to line up bushing with the rod. The problem seems to be the size of the hole and hardness of the hardness of the bushing material.
Old 09-27-2023, 10:29 AM   #7
Ohio Enthusiast
Drives: 2018 BRZ
Interesting. So I guess the different makes do make a difference. This concludes my usefulness here. Best of luck with your problem.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
blsfrs (09-27-2023)
Old 09-27-2023, 11:21 AM   #8
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
When you remove the bushing, the bracket assembly can swing down a bit. Grease up the bushing and place it on the end of the bracket. Push the bracket upwards and the sloped rear end of the tunnel will push the bushing onto the bracket.
I'm not sure how else to explain it.
Are you sure you're installing the bushing right side up?
The Following User Says Thank You to DocWalt For This Useful Post:
blsfrs (09-27-2023)
Old 09-27-2023, 01:15 PM   #9
blsfrs
blsfrs's Avatar
Thanks guys. I'll give it another shot this weekend and let you know how it goes.
Old 09-27-2023, 02:16 PM   #10
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
FWIW it was *not* easy at all, definitely harder than I expected.
blsfrs (09-27-2023)
Old 09-30-2023, 05:42 PM   #11
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Yeah I just did this, it takes some great force to get it past that first "wall". Did it with a lift and it still kicked my butt a little
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following User Says Thank You to nickmerronesucks For This Useful Post:
blsfrs (09-30-2023)
Old 09-30-2023, 10:40 PM   #12
cueball89
Drives: 15 Impreza
Is the shifter bushing a worthwhile modification? I've changed it out on other subarus but was under the impression it didn't make a huge difference on these cars.
cueball89 is offline   Reply With Quote
The Following User Says Thank You to cueball89 For This Useful Post:
blsfrs (10-01-2023)
Old 09-30-2023, 11:43 PM   #13
Ohio Enthusiast
Drives: 2018 BRZ
Hard to measure the impact of any single drivetrain mod. Most people add a bunch at a time or add them in different order and it skews the impressions.
I will say that I find replacement bushings and inserts for the transmission and differential to be very noticeable, eliminating all the movement of the shifter. I was unhappy with the amount of slop and lash it had stock, particularly when letting off the gas in lower gears and higher engine RPM.
I did most (if not all) drivetrain bushings (except engine mounts) and am very pleased with the result, but it wasn't until the last mod that it really made a big difference. It might be that the last one (the diff bushings) are the important ones, or that all the bushings/inserts are needed together.
I did Perrin rear bushing, Whiteline front insert, Torque Solutions front carrier bushings, Whiteline rear subframe inserts and Whiteline diff inserts.
The Following 3 Users Say Thank You to Ohio Enthusiast For This Useful Post:
blsfrs (10-01-2023), cueball89 (10-01-2023), nickmerronesucks (10-01-2023)
Old 10-01-2023, 04:18 PM   #14
cueball89
Drives: 15 Impreza
Agreed, those bushings and inserts make a huge difference. Rear subframe, rear diff and transmission insert are what I've done. I'd like to get some stiffer engine mounts in the future.
blsfrs (10-01-2023)
FS: Energy Suspension Rack And Pinion Mount Bushing Set Jtrem Brakes, Suspension, Chassis 1 02-26-2018 12:04 AM
Energy Suspension front arm bushing kit Satanasso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 02-08-2017 09:56 AM
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 10:57 PM
Perrin Shifter Bushing rebranded Energy Suspension? BRZach Engine, Exhaust, Transmission 10 01-12-2016 03:17 PM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-09-2012 09:40 PM
