Old 08-04-2023, 07:50 PM   #1
Lav
Drives: Frs
How bad is it that I've had a 2 inch hole in my air filter resonator for 2 weeks?
CEL came on after I changed the air filter 2 weeks ago. It was a K&N high flow one that was red. Codes were P0171, P1170, C1201.
I reclamped the air filter box 3 days ago, double checking that the tabs on the bottom lined up well, and figured itd go away.
It didn't so today I did some inspecting and found a golf ball sized hole in the resonator thats attached to the bottom of the intake, after the air filter box. About parallel to the outlet that goes to the cabin sound generator tube. https://imgur.com/a/C9D4HnD
It must have happened during my first install, when I was moving pieces around. I dont see how, but the CEL coincided with the first attempt at install so it must have happened then
I'm gonna buy a replacement resonator and put it in but my question is, how bad is driving around with a golf ball sized hole in your intake?
I haven't driven through any particularly dusty areas but I've probably driven 200 miles or so on highways and cities. Its on the back of the resonator, the side not visible when looking at your engine from the hood. Is there anything preventative I should do to help mitigate damage? Or is the damage done and Ill find out in a few days/months/years when my engine needs rebuilding prematurely.
Lav is offline   Reply With Quote
The Following User Says Thank You to Lav For This Useful Post:
humfrz (08-06-2023)
Old 08-04-2023, 08:05 PM   #2
Lav
Drives: Frs
Also, it looks like its not easy to find a new OEM Intake Resonator, so I'll probably be going with this plug
https://tecnocraftcomposites.com/pro...or-delete-plug
unless anyone has a experience with a different one.
Edit: nvm, this resonator and the one thats broken on mine are not the same.
Edit2: Looks like my best bet is just to buy a new inlet tube without the box
Old 08-04-2023, 08:14 PM   #3
Lav
Drives: Frs
last addendum/bump:
the one thats broken is the small dangly one, AFTER the filter. Here is a picture of the resonator on a for sale tube: https://imgur.com/a/C9D4HnD
Below the T junction where the sound tube is. It is NOT the bigger one on the left that people talk about deleting, which is before the air filter
So definitely I have been raw dogging unfiltered air into my engine.
Old 08-04-2023, 08:21 PM   #4
Grady
Grady's Avatar
Sand and such will scratch the cylinder walls. If if did any major damage you will start to consume oil. I would not worry about it you will spin a bearing before you wear out the cylinders.
Just throw all that garbage away and install A Perrin intake tube.
The Following 2 Users Say Thank You to Grady For This Useful Post:
humfrz (08-06-2023), Lav (07-09-2024)
Old 08-04-2023, 09:42 PM   #5
Unless you've been following other cars along dirt roads, you're fine. On a related note, I'm not a fan of the high flow aftermarket air filters for the same reason. Less resistance to air flow across the same cross-sectional area by definition means less filtration. Also those serviceable oiled filters can foul the MAF sensor. [cue the hate]
Good call replacing the resonator instead of just plugging the hole.
soundman98 (08-05-2023)
Old 08-04-2023, 09:52 PM   #6
Lav
Drives: Frs
Yeah i wanted stock air filter for the same reasoning (the power gains are tested to be virtually non existant and the platform has already been decently optimized for performance) but they only had this high flow one available
Im gonna get an aftermarket inlet tube because i cant find the resonator for sale and i dont wanna buy used/go to a scrap yard lol
Thanks for the reassurance guys. Ill keep an eye on oil consumptiom though theres not much to do regardless
humfrz (08-06-2023)
Old 08-05-2023, 02:16 AM   #7
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Gatorade cap mod
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
Lantanafrs2 (08-05-2023), Ultramaroon (08-05-2023)
Old 08-05-2023, 02:23 AM   #8
Old 08-05-2023, 02:31 AM   #9
EndlessAzure
Wheels for Brains
Somebody else's filthy outside air has touched it
DarkPira7e (08-05-2023), soundman98 (08-05-2023)
Old 08-05-2023, 02:53 AM   #10
Old 08-05-2023, 04:03 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
this is the exact reason scrap yards exist... they'll probably charge you $40 for the ENTIRE intake system.
Old 08-05-2023, 04:08 PM   #12
Lav
Drives: Frs
Yeah im thinking about it. Ive just never done a scrap yard before. Can i expect to confirm that they have frs/brz before i go?
Btw your posts on sound deadening were great.
Old 08-05-2023, 04:24 PM   #13
Row 52 has been a great resource for me. I just need to get off of my ass when the email notifications come in.
EndlessAzure (10-25-2024)
Old 08-05-2023, 04:32 PM   #14
soundman98
soundman98's Avatar
there's really 2 variants of scrap yard.
pick-your-part yards= you can confirm they have 'a' vehicle(usually with a picture of the vehicle as it was coming into the yard), but they won't confirm anything on it still exists, you must visit the location, and remove the part yourself with your own tools. depending on the popularity of the yard, and the vehicle, i've seen entire cars nearly stripped down to the frame in a matter of 2-3 days.
i've done a ton with LKQ pick-your-part yards, but they're all about the same. it basically kept my old ranger on the road. all the oem window switches failed, and there's zero replacements for those.
standard scrap yards= they don't allow anyone into the yard, you call/email them about the year/make/model you want to discuss with them, as well as the part/color you need. they'll give a quote, and if you want it, they send someone out to the yard, pull the part, then you can either pick it up, or they can ship it to you.
my local yards that do this generally are closer to MSRP of new parts, so i just plain avoid this route if possible. but i've done a ton of this through ebay. i'll search for the make/model of car, then specify the part i'm looking for, as well as highlighting 'used' items.
in this case, i'd jump to this listing:
https://www.ebay.com/itm/12603809785...Condition=3000
no, it's not the right part, but then i message them asking for the related component that they don't have listed. most times they're very reasonable on pricing. i do this a lot for parts that i'm going to alter. i order the replacement, modify it, then keep the original on the shelf for the case where i want to, or need to return the vehicle to stock, or something goes wrong with my modification.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Lav (08-06-2023), Ultramaroon (08-05-2023)
air filter, damage, hole, resonator
drain hole oil filter housing? sneaky_pete Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-06-2020 05:21 PM
APR GT250 67 Inch wing w/ 7 Inch risers on SEIBON CSL Style CF Trunk Tony.86_ Exterior Parts (Aero, Lighting, Etc.) 5 01-03-2020 11:03 PM
Mouse Nest hole air filter- Need to Clean intake manifold? GreenLightGo Other Vehicles & General Automotive Discussions 4 03-16-2016 09:49 AM
Hole in intake post air filter? ZionsWrath Other Vehicles & General Automotive Discussions 2 01-02-2016 01:18 PM
Blowout Sale Ambit Wheels 5x100 17 Inch & 18 Inch!! JonMotoring Wheels and Tires 14 11-16-2015 07:24 PM
