Old 03-15-2016, 12:05 PM   #1
GreenLightGo
Drives: 2013 Scion FRS Red
Mouse Nest hole air filter- Need to Clean intake manifold?
Hi I recently bought a garaged S2k with 17k miles. After driving home, I immediately did an oil change and then found this mouse nest in the air filter as well as a few small cuts in the air filter! I looked on the inside of the air filter and luckily it was clean and didn't see any mouse nest fibers sucked inside caught around the internal metal cage so i am hoping nothing signicant got sucked into the intake manifold or engine...
The car had a Honda dealer service check at 16k miles (assuming air filter was checked at that time) and then the car was parked mostly off and on for over a year until I bought it with 17k miles, and then drove it 300 miles home after buying it (now at 17.3k miles).. So at most it was driven for around 1000 miles like this and at the least 300 miles...
What do you think? Do you think there could be significant debree inside intake manifold from these small open cuts ? I was considering taking apart the intake manifold and looking it over just to check...? Picture to follow shortly .
(I also have an FRS. I would post this in s2k forum but just created a new account there and cannot post yet)
GreenLightGo is offline   Reply With Quote
Old 03-15-2016, 12:11 PM   #2
GreenLightGo
Photo 1
Old 03-15-2016, 12:12 PM   #3
GreenLightGo
Photo 2- note these are the only cuts in the air filter as the rest of the filter was ok. (I did order a new filter though and will not drive it until I install a new filter).
Old 03-15-2016, 12:13 PM   #4
GreenLightGo
Photo 3
Old 03-16-2016, 08:49 AM   #5
Ashikabi
Ashikabi's Avatar
Totaled.
You're probably alright I'd there wasn't a HOLE I doubt you'll find anything in the manifold. Probably too late now anyways since you drove it. I would replace the filter and move on
Hole in intake post air filter? ZionsWrath Other Vehicles & General Automotive Discussions 2 01-02-2016 12:18 PM
Perrin CAI air filter clean Hawk77FT Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 11-16-2015 11:56 AM
how to clean K&N filter without the kit? jarviz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 12-10-2014 04:07 AM
Best way to clean your dry filter intake? ScionFR-S Engine, Exhaust, Transmission 3 01-05-2014 02:25 PM
When to clean CAI filter Bg8780 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 10-25-2013 05:45 PM
