Old 01-02-2016, 12:00 PM   #1
ZionsWrath
Thanks
ZionsWrath's Avatar
Hole in intake post air filter?
This is on my other car. Picture below for reference, the hole is between the flexible part above the positive battery terminal in the picture.
For now I just wrapped the intake with gaffer tape. Don't know how long it has been like that could be for about a year. It blends in there noticed it by chance today changing transmission fluid.
How bad could that be for the engine, sucking in dirty air and potentially water?
It's kind of dry rotted and wondering if I should replace it with an OEM piece or delete the whole airbox assembly and get an ebay "short ram" (hot air) intake.
Old 01-02-2016, 12:04 PM   #2
D_Thissen
D_Thissen's Avatar
I would just go to an auto wrecker and see if you can find a car that has that OEM intake. Shouldn't cost more than 50 bucks.
Old 01-02-2016, 12:18 PM   #3
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Is this an Accord?
Don't you live around Brooklyn? Should be plenty of wreckers over in Larchmont that will have what you need.
Any type of open hole in your air filter is bad, the whole purpose of the air filter is to filter out contaminants, that hole is doing the exact opposite.
Okada / Ignition Projects / Cusco / Megan / aFe Intake & Filter / Agency Power Intake eauto Engine, Exhaust, Bolt-Ons 299 10-15-2014 01:44 PM
Oil Sender Pre or Post Filter sam69 Engine, Exhaust, Transmission 7 10-10-2014 01:28 AM
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 06:06 PM
